Question about Kirby Ultimate G Bagged Upright Vacuum
Vacuum brush roller with belt attached is off
I am attempting to shampoo my rug. This is the first time. The roller with the belt for shampooing came off. I do not know how to put it back on. Can you help me?
  • 3 more comments
  • Anonymous Mar 02, 2008
    I am trying to shampoo my carpet, and I didn't receive a manual. How do I get started?
  • tommyt0534 May 25, 2008
    yes i can not put the belt back on and do not know which way to put it on can you help
  • JACK32654 Jun 08, 2008
    I RECIEVIED AKIRBY FROM E-BAY WIYH YHE BRUSH HEAD REMOVED AND I CANN'T SEEM TO MAKE THE BRUSH TURN AFTER REATTACHING THE BRUSH HEAD .HELP
  • chefchef Jun 11, 2008
    hi i have a kirby g2 i won it off ebay and i am a blank has i can not get the kirby to blow can some one help i am wanting to shampoo a carpet can you reply at pepelittle@aol.co.uk thanks for your help and time
  • Anonymous Mar 13, 2014
    how to put the belt on the vacuum shampoo
I just need to print instruction on how to us my Kirby Ultimate G to Shampoo my carpet.
Posted on Aug 25, 2008
  • 357 Answers
Here is a very clear online instruction guide for the shampooer. Hope this helps!
Marci
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Posted on Nov 09, 2007
    Problem Solver:
  • 3 Answers
It is meant to come apart for cleaning it up afterwards. Slip the belt over the roller. One triangular end of the roller is bigger than the other, so keep this in mind when sliding it into the cleaning head. Turn the knob to pick up the belt, just like on the vacuum's regular nozzle. Mount the cleaning head, then turn the knob to set the belt onto the motor spindle.
Posted on May 29, 2007
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Feb 14, 2015 | Kirby Ultimate G Bagged Upright Vacuum
How to assembel the kirby accesories to manually shampoo
I just did and it's multiple steps but not too hard.
There are complete detailed explanations if you do a search engine on kirby shampooer instructions. I found one explanation on Ebay, and another on EHow. www.goodvac.com/Articles.asp?ID=153
Step one - vacuum your carpet more thoroughly than you usually do. Each back and forth pass - four times.
Take off the dirt bag and the head off of your Kirby.
Where the dirt bag attaches to the Kirby is where the shampoo mixing container goes. Before you attach the mixing container on there take your container and fill it to the 1st line for a very small area, 2nd for a medium sized area, and to the third line for an average sized bedroom. A large living room may need a second container. For the solution - you must use Kirby shampoo. If you fill to the first water line - use one capful, 2nd line 2 capfuls, and etc. Make sure the sponge filter is positioned on the mixing container in the spot where it hooks onto the vacuum (mini-emptor).
The shampoo brushhead I find to be the biggest challenge because that L-shaped tube attachment gets in the way of the belt lifter when you try to hook on the belt. The belt is going to hook on the brushroller the same way it does on your vacuum head. Pop the brush roller in the head of the shampooer and then sit that head onto the tray mechanism.
Once you puzzle piece everything together and now ready to shampoo. Let me tell ya this - after the hassle of putting everything together - just do the whole room and make it worth the bother.
Turn the machine on, and lower the shampoo head ALL THE WAY DOWN, unless your carpet is ultra thick and then maybe just one click up. Turn the dial on the shampoo mixing container to on. Push the machine forward rather quick and pull back slow. Do overlapping passes.This will spread the foam nice and evenly. Let the foam sit for about 5 minutes, then turn the dial to off and go back over it slowly forward and backwards massaging the foam solution deep into your carpet fibers. Then let it sit for 2 - 3 hours. Then vacuum really thoroughly. Right after I go through the shampooing process and the carpet is still moist - I use a carpet brush and I scrub the foam even deeper into the carpet.
Good luck. Hopefully you will be motivated in the fact that I just did mine and the high traffic carpet looks really good. I just had clients come in and they noticed the difference right away, as it looks like a pro came in and did the job.
Mar 21, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Rollers don't turn and pump doesn't put out any shampoo or rinse water
You need to replace the Pump belt and the roller brush belt. You can get both belts and view the manual which has instructions here:
Bissell Proheat Replacement Belts and Manual
Nov 24, 2009 | Bissell 1699 ProHeat Clear View Upright...
Can NOT get Kirby G6 shampooer system lowered to use
take the attachments off and see if you can lower it then..if so .lower the vacuum and put the attachmens on then try
Apr 11, 2009 | Kirby G6 Bagged Upright Vacuum
Does my kirby come apart to where i can shampoo furniture . can i use kirby on berber carpet. i have the G series
YES there is Kirby upholstery shampoo attachment that comes in a standard set of attachments - HERE is the instructions. Try it on inconspicuous area first just to make sure that this is going to work on your upholstery. But I would just buy a can of upholstery foam. If you can not find it in a store - try automotive store - they definitely have it. Spray can is just much more simple. Still try it somewhere where you would not be afraid to damage the color first.
Using shampoo attachment on berber carpets is not as effective as on the regular carpet. Brush cant get to brush the fiber from all sides. You may have to shampoo berber rugs from several directions to get the better result.
Mar 12, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G rug shampoo attachment
If you still have not shampooed your rugs - here is the Kirby Shampoo Manual ONLINE
Sep 13, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G6 attaching fluffer brush on shampooer
Sure can,
You have two choices,
1.) To use your shampoo attachment, you'll need the fluffer shield, To set up the attachment seperate the tray assembly (the part that holds the roller brush) from the nozzle assembly (the part that attaches to the machine). Now seperate the roller brush from the tray (easiest way is to pull the belt). Insert the roller brush into the fluffer shield (it only goes one way). Insert the fluffer shield with the roller brush installed into the nozzle assembly the plastic shield will be faced towards the front of the machine. Turn belt lifter to where the red arrows match and attach to the front of the machine. Turn belt lifter to where the green arrows match and you should be in business.
2.) Your using the floor buffing attachment it the easiest method just put on like the floor nozzle (thing you vacuum with).
Jul 21, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
361 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
