Question about Compaq Presario Notebook
Restarting problem I have Presario V6000. while turn on the computer suddenly hanged, I switched off it, restarted again and again but every time it automatically switch off. I tried removing the battry and inserting the recovery disc but problem reamins same. Help me to out of this problem.
    Problem Solver:
  • 6 Answers
This sounds like an overheating problem.
Check the exhaust slots on the back and or bottom of the laptop and remove and clogged up dust.
Posted on Dec 20, 2008
My laptop compaq presario v6000 does not switch on but the power light comes on when the chager is on. when i try to turn the computer on it just flick the light on then back off. can anyone yep me to
The DC pin on your laptop is bent/broken/loose. Look at where your power adapter plugs in on your laptop. Get a paper clip, bend it out to make a long paper clip and slightly push its tip on the pin inside your laptop. If the pin moves chances are either the DC pin needs to be soldered down or needs to be replaced. The part is usually cheap around $10 but the labor can cost more than $50.
http://www.chargerbuy.com/original-compaq-presario-v6000-ac-adapter-65w.html
Dec 16, 2012 | Computers & Internet
I have Compaq V6000 series laptop with AMD Processor & nvidia graphic card ,my laptop?s lower half of screen becomes blurred & will become ok after some adjustments & again become blurred when...
There was a TSB about the motherboards on the V series describing severe video issues and Nvidia GPU failures. Many consumers got a motherboard replacement. Try using a laptop cooler in the meantime and see if that helps a little. Also try googling V6000 video and see how many others got nuked by this poor design.
Mar 13, 2010 | Computers & Internet
My v6000 presario will not turn on when power cord in the blue light on input just flashes nothing switches on at all
Unplug the power cable and pull out the battery.Wait 10 min and put the battery back again.If this not help your computer need service.
Oct 26, 2009 | HP Compaq Presario V6000T Notebook
V6000 won't start back up
If the computer is not even showing the splash screen you have a hardware failure or a corrupted BIOS. The first things to try are reseating the memory and other components (hard drive, optical drive, battery again, etc.). If it still will not start and you are very computer savvy, go over to hp.com and see if your unit is capable of flashing the BIOS from a USB drive. If it is not you are probably going to require a computer repair shop.
Sep 09, 2009 | Compaq Presario 5000 PC Desktop
Hp laptop presario V6000 can't startup. Black Screen.
its a common problem with these models.
try and keep away from hp
Jul 24, 2009 | HP Pavilion dv6000z Notebook
Hang up
Possibly due to corrupted graphics driver, or resolution changed to one unsupported by your laptop. Try restarting in safe mode by tapping F8 key on boot and select "safe mode" press enter then enter again. If it gets to windows in safe mode log on as an administrator and go to "display" in control panel, select adapter and change the driver by rolling back to a previous version or simply uninstall, which is what i did! Then restart the computer, it should now boot to windows but the resolution will be naff, get on the internet find the latest driver from your laptop manufacturer download this to the desktop and install from there. Worked for me, hope it does the same for you.
Jul 05, 2009 | HP Compaq for Presario V3000 Motherboard
Computer never continue to start up, it just continue restarting at least 2 times then it hang. when i try to reboot monitor never display any images anymore and what i noticed when that happens is that...
run it in safemode with networking and install safemsi.exe and then run malawarebytes which is free to download ,update it and run this will fix the problem
May 08, 2009 | Microsoft Windows XP Professional for PC
Compaq Presario V6000 dvd rom drive disapeared.
This has happened to me since I bought the machine. You need to reinstall your DVD driver. Go to your systems window, selected devices, select drives. You should see the DVD drive (probably a Toshiba). Uninstall the drive. You will be prompted to restart the machine. When it restarts the DVD will operate normally. I use my DVD-R alot and I have to reinstall the driver every couple of weeks.
Sep 05, 2008 | Compaq Presario 12XL 104-106 Series 6X...
It actually sounds like you might have a hardware problem. If you're comfortable with opening the computer, remove any recently added hardware. If no hardware was added, then it may be necessary to remove each of the components in the following order and retest the boot process until it functions, and replace the last part removed.
Pressing F8 and/or reading the CDROM that early in the BOOT sequence is not possible, so it's in a hardware check.
Floppy, CDROM, SoundCard, Network Card, <any other cards>, extra RAM, except one or two to be able to boot.
It is also possible that either internally or externally, a cable may be loose. If you are able reseat all the cables, this may make it work. Stuff can come loose and the computer freaks out.
Lastly, if you feel like making sure that component is the problem, start plugging all pieces back in and all may work. This would mean that something was loose.
Nov 26, 2007 | Compaq Presario s4020wm (DK214AR#ABA) PC...
Compaq Presario Notebook Logo
120 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
