Question about Sony KP-43T90 43" Rear Projection Television
Which ic's replacement
Convergance IC Replacement which? see picture in kp-43t90 section
  • nozz shaw Apr 06, 2007
    here it is
  • Anonymous Dec 28, 2007
    convergence problem. How caN i fix it
  • 105 Answers
I dont see them on this pic
i just looked at the schmatics and they are stk392-150. they are located on the G board ic1502 and ic1506
Posted on Oct 13, 2007
  • Troy Shull
    Troy Shull Oct 13, 2007
    should be on the board that you have pictur of as that is the g board. looks like they might be on bottom right of pic.
    thanks for the pic bye the way
Distorted picture and color
This kind of problem occurs due to failure of convergence output ICs in Sony KP-51HW40 tv.
Replace convergence output ICs to solve tv problem.
This set uses two of the STK-392-570 IC chips for this (convergence problem)
Local tv repairman will do this job if you have no experience of electronics stuff repair.
Dec 22, 2010 | Sony KP-51HW40 51" Rear Projection...
I bought a used Sony TV that I love, but the picture had a double vision. It does not line up and it has a shadow vison all the time. I tried the Flash Focus but it doesn't change anything. the Model NO...
Your best bet is to have a professional come out and align the guns professionally. It runs 100-150$ for them to come to your house and do it. If you need anything else let me know.
Thanks,
Lee
Aug 24, 2008 | Sony Televison & Video
Tip
Replacement of Convergence IC'S
If your picture looks 3D then you most likely have a CONVERGENCE IC that is bad or a fuse that supplies 12vdc or 25vdc to that IC IS OPEN. Also keep in mind it could be a FRACTURED solder connections. The cost of the IC varies depending on which one it is.
on Feb 18, 2008 | Sony KP-46WT500 46" Rear Projection...
My sony tv model # KP-46WT510 is showing a three D Picture with a red outline
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 17, 2009 | Sony Televison & Video
The blu display on my sony 65" tv is arched, making the convergence adjustment in-effective.
its failure of Convergence Out IC chip and requires replacement.
TV has 2 IC chip in convergence circuit and I would recommend to replace both at same time.
Let me know exact model of Sony 65" TV to provide you more technical info.
Mar 14, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony KP-53XBR45 convergence
Hey, found the problem. Your Convergence IC chip went bad. Buy one at Bluestar International Components (bluestar-online.com) - order part number STK392-010 for 6.99. I've read that there are two in the system and replacing them both at same time is a good idea...so, order 2. Now, if you are handy, it will require you to open the back of the TV and solder out the old chip and replace with new. If not, then you might as well call a TV repair person and have them fix. However, every place I've called works on a minimum fee for "large screen TVs" - the cheapest I could find in Atlanta was $399 minimum service fee. So, I'm going to risk the home sodering job .... it's a 10 year old TV and as good as it's been to me, if I screw it up, I feel I've gotten my money out of it. Good luck with your repair. My parts are on order.
Oct 15, 2008 | Sony KP-53XBR45 53" Rear Projection...
KP43T90 convergence
Check the resistors that are right next to the ICs one or two of the resistors will usually go open along with The convergence ICs.
May 10, 2008 | Sony KP-43T90 43" Rear Projection...
I have No picture but I have audio
have the tech look at your tv once again your problem is in the video section.the ic that controls that and the related circuit are not working parts needs to be replaced.good luck.
Apr 01, 2007 | Sony KP-53V45 53" Rear Projection...
Sony KP-43T90 43" Rear Projection Television Logo
98 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
