Question about Nextar X3-03 Car GPS Receiver
Will not take a charge
I have had on charger for 8 hours
    Problem Solver:
  • 6 Answers
Replace battery. The body and the battery is same for X3-02, for which I've posted the solution.
Posted on Dec 26, 2008
HOW DO YOU CHANGE THE BATTERYS
Depends on what battery. car battery I charge with i 10 means with a current 1 / 10 of the capacity in Ampere hours for 14 hours. So a 80 Ah battery with 8 A for 14 hours.
A camera battery in the charger I got with the camera. Or a good universal charger from GP. A NiMH AA or AAA battery, with a quick charger that at least needs 2 hours to charge. The quick chargers I have that can charge in less than 2 hours (one can manage in 15 minutes) all kill batteries after a few charge cycles. Hope this helps.
Mar 15, 2015 | Cameras
When the walkie on full charge the charge light is not going to off ?
If your battery is flat or close to, then a complete charge is ussually 23 hours. or thereabout, so this is why the light on your charger is still on. The light for a flat battery is red and when the battery is fuuly charges light is green.
8 hours of charging a flat battery, isn't enough, hence the light staying on RED, if I'm not wrong and I doubt that I am.
I hope this has answered your query.
Best regards,
Peter
Oct 09, 2012 | Kenwood KSC-15 - 8 Hour Charger
Will it charge thru my pc?
Yes you can charge your satnav through your pc using the mini USB lead. It will take approx 8 hours to charge fully compared to 4 hours using a car charger or a mains charger.
Feb 20, 2011 | Garmin Nuvi 265W GPS Receiver
How long do I charge my new 265wt initially with ac adapter
It should be fully charged after 4 hours with the ac charger. It also takes 4 hours with a car charger or 8 hours through a USB connection to a computer.
Feb 17, 2011 | Garmin GPS
Just got a Mag One BPR battery delivered to me and i put it on the charger. After about an hour the green light is on. I thought the battery needed to be charged for 8 hours the first time? Why the green...
The charger which comes with the BPR40 is a rapid charger. (The book doesn't indicate if it is a 90 min. or 3 hour charger.) None-the-less, your battery is fine. When your charger is displaying green it will continue to trickle (slow) charge the battery to keep it topped off, so to speak. The first 3 charge cycles you should leave the battery on the charger the full recommended time. On most Motorola radios it is 10-12 hours. This will assure your battery is charged to full capacity and initiated properly. In most cases, your traditional charging of the radio should be overnight. When you go to bed, put the radio to bed on the charger.
FYI: All batteries come from the factory with some charge in them. It is a small test charge to assure the battery's funcationality.
If for some reason after the first week or so, you think your battery or charger is not functioning properly, contact the dealer where you purchased the unit. They can replace it under warranty.
Best regards.
Dec 29, 2010 | Motorola Mag One BPR40 Two Way Radio
How can we charge the Garmin in the house and how long does it take to charge in the car ours is the 1350 model
You can buy a mains charger from any shop that sells garmin satnavs to charge it in the house. Or you can charge it by connecting it to your computer with the mini USB lead. Charging with a computer takes about 8 hours while charging with a car charger or a mains charger takes about 4 hours.
Dec 19, 2010 | Garmin GPS
DSealed Lead Acid Batteries: 12v 7ah; belongs in a Liftmaster LA400 gate control box. Can these batteries be charged using a trickle charger? I'm trying to find out if it's the battery not holding a charge...
Yes you can charge the 12 volt bttery on a trickle charger. You should use a 1 amp or less charger. Check the battery every 1/2 hour or so for heat. If it get's hot you should stop charging. Power packs that have a 12 volt rating will charge your battery safer and better but will take longer (like a cell phone charger) look at the voltage ratings on the charger. You will have to adapt the plug to hook it up and test for correct pos. and negative connections. The 7amp hour batery should be fully charged by a .5 amp (500ma) charger in about 14 hours (multiply the amps times hours of charge and do not go over the 7amp hours of the battery when deciding how long to charge). After charging check voltage, it should be around 12. Let the battery set for a few hours (overnight) and check the voltage again. It should be around 12 still. A fresh charge will usually show a higher reading (called a surface charge) than a battery sitting around. 4.5 v will not operate your device, 9.5 v or higher should.
Aug 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Peg perego battery charger
Normally, you would need to charge overnight- 12 hours.
Jul 30, 2009 | Peg Perego 12 Volt Rechargeable Battery
S-750DD
Not sure if this will help... however an altmeter will allow you to test along your electrics for any faults. You can check at the lights for example and throught the system.
Oct 11, 2007 | Transport Schwinn Rechargeable Portable ...
Nextar X3-03 Car GPS Receiver Logo
101 people viewed this question
Top Nextar GPS Experts
Marvin
Marvin
Are you a Nextar GPS Expert? Answer questions, earn points and help others
