Question about Nikon N8008 AF 35mm SLR Camera
Wire harness for eurovox 92047975
Could some one please tell me what the colour of each wire, I connected up a single panasonic unit, got power but no sound
Eurovox wiring diagram
The black stripes are typically the negative wires for each speaker. So your blue will go to one positive speaker output from the receiver, and the blue/black to the speakers negative.
If you want to check them manually, so that you know which speaker should connect to which wire, use the front to back fader, and left to right fader on the kenwood.
Remove the keys from the ignition, and ensure the radio is off.
Tape up all eight speaker wires coming out of the headunit with electrical tape to nothing at all.
Remove the tape from one pair of corresponding colors, and connect it to any single pair of wires that run to the speakers. Tape them separately with electrical tape.
Turn it back on, and set the fader all the way to the front and left. Listen to what speaker it's coming out of. You now know two things. Which color from the deck is the front left, and which speaker wires in the dash goto the speaker making sound.
Turn everything off, and rinse and repeat.
Even easier is to go to a sound shop where they sell harness, or buy one online. Then you just connect per the instructions and you're done. Don't forget to make good strong connections, and tape up everything well.
Good luck.
Apr 21, 2014 | Car Audio & Video
I have bought a 16 pin iso lead power wiring harness adapter to enable me to fit a panasonic stereo in my old BMW. Please could you tell me why the adapter has a brown wire which is not connected at one...
Harnesses are made for many vehicles. The harness you bought may fit another year model where the brown wire might be used. If you are not using this wire, just tape it up and secure it. It will be fine as long as everything is working on the stereo you have installed. good Luck.
Sep 08, 2011 | Panasonic 16 Pin Car Cd Wire Harness
I need to replace the stereo in my 94 saab 9000CS it is Eurovox 1479 & I an having trouble matching the wiring colours from the cars plug to my ISO adapter for my Sony aftermarket unit
use a 9volt battery and grab only speaker wires only and touch them to the 9vt battery this will tell witch speaker is witch. for mor help please call 419 689 1114 for futher assistance i will be more then happy to help you
Apr 18, 2010 | 1994 Saab 9000
I need the pin out for the wiring harness for the vrcd 500 sdu stereo i have the unit but no harness i can make my own if some one can tell me what wire gos were it has 2 rows of 8 pins top and bottom i...
it would be easier to remove the harness from the car and wire direct red and yellow from headunit to car live, black to earth,4 coloured pairs (eg purple/purple and white, blue/blue and white) will be speaker wires single blue is your remote wire (not needed unless adding an amp) hope this helps
Aug 12, 2009 | Car Audio & Video
Conection
to install this unit in your car........as a beginner i would strongly recommend buying a aftermarket radio harness (this harness will attach to the wire plug in your factory deck simply unhook the factory player and attach this harness to the plug you just pulled out of the factory unit) once this harness is installed on the factory plug it will be a simple colour match (just attach wires to pioneer wires IE. red - red, white - white........once all the wires are attached install in dash recommend buying a mounting unit for this net part it will hold the deck in place in your dash...........after that is done install your pioneer unit push it in place apply power by turning car on..........pioneer deck should turn on and work if it does not turn right on look for a source button on the pioneer unit and hold it down till the unit turns on
good luck
hope i was able to help
Mar 05, 2009 | Pioneer KEH-P6600 Cassette Player
Looking for manual for ''nec n-3480'' TV, missing power cord
Colour code Standard wire colours for flexible cable
Such as Extension cords, power (line) cords and lamp cords World Region, country
or other entity(ies) Live Neutral Protective earth/ground EU, Australia & South Africa (IEC 60446) brown blue green & yellow Australia & New Zealand (AS/NZS 3000:2000 3.8.1) red black green/yellow United States and Canada black (brass) white (silver) green (green) Standard wire colours for fixed cable
(In or behind the wall wiring cables) Region Live Neutral Protective earth/ground EU (IEC 60446) including UK from 31 March 2004 brown blue green & yellow Australia and South Africa red black green & yellow (core is usually bare and should be sleeved at terminations) United States and Canada black, red, blue(brass) white (silver) green (green)
or bare copper wire Note: the colours in this table represent the most common and preferred standard colours for single phase wiring however others may be in use, especially in older installations.
Nov 19, 2008 | Televison & Video
I need the colour wire description for a 2000 dodge caravan Im removing the the factory stero and installing after market stero and need wring diagram , what each wire is for ,speakers ,power etc.
HI.
In the caravan are 2 types of Radio.
1. Normal sound system.
1 Premium sound system.
Note: If you don't want to cut the original wires,
You can buy a harness connector to install the aftermarket Radio. The connector are made by aplication, and are plug in.
The colour of the connector are the same colour with the Aftermarket Radio. Just you need to soldering or just put joint connectors.
Normal: colour of wires.
Pink = Battery voltage.
Red/withe = Ingnition Voltage.
Brown/red and Dark green. = Left front speaker.
Dark bku/red and Voilet = right front speaker.
Brown light blue and brown/yellow. = left rear speaker.
Dark blue/orange and dark blue white = right rear speaker.
Ground is a single wire behind the radio.
If you have a premium sound. You need to use the front speaker out to connect the speaker on the door and the speaker on the dash. To complete the 6 speaker.
OK... I hope this information work for you.
Thank you , For use fixya. Rate please.
Jul 17, 2008 | Car Audio & Video
No Power to the unit
Hi perkyfridge,
You may have a problem with the faceplate connection not making good contact. Tell me what model Radio you have, that will help in determining what is wrong. Thank you.
Nov 22, 2007 | Pioneer DEH-P6400 CD Player
Wiring Installation - Satellite Radio
The wire that runs along with the P-bus cable connects to constant power; the other wire needs to be grounded.
Jan 08, 2007 | Pioneer GEX-P910XM Satellite Radio...
Nikon N8008 AF 35mm SLR Camera Logo
160 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
