Audio adjust screen pop up
My viewsonic vx-2255 wm-2 monitor frequently pops up the audio adjust menu in the middle of the screeen. I can get rid of the small blue screen by pressing the 1, 2 or up and down buttons on the side of the monitor but the screen comes right back. I purchased last year recently. what can I do to fix this? I tried reloading the drivers and switching power cords. I have vista as my operating system. my viewsonic monitor frequently pops up the audio adjust menu in the middle of the screeen. How can I fix it.
  • 2 more comments
  • mrs_utt Dec 29, 2008
    Please anyone know how to help? I have the same problem!!!! I am running Windows XP, so this is not a vista problem. Thanks!!!!
  • mochiboy Jan 27, 2009
    I have the same blue screen "Audio Adjust" popup.
  • Anonymous Mar 28, 2009
    Audio adjust constantly pops up on relatively new viewsonic. Running Windows xp. Manufacterer very little help. If someone figures this out please post
  • Anonymous Apr 07, 2009
    I have the same problem .... Windows XP
    Please help!
I contacted ViewSonic with the same problem. They told me to turn off the monitor and unplug all the cables. Then hold the power button on the monitor for 10 seconds. Turn it back on and it should be gone.
If that doesn't work, I was told to do a memory recall on the monitor by pressing the 1 button and selecting memory recall from the list. It sets the monitor back to factory settings.
I haven't tried any of these yet but hopefully they work for someone.
Posted on Jul 19, 2009
Yes, I made it!!!
I had worked on this annoying problem for two hours. Tried all methods I can find online. most methods work only for 2 or 3 seconds, then it came back. However, I noticed that while I hold the "1" and "up" for more than ten seconds, the power button was blocked by showing a blue window with "Power .... locked" after the blue window disappeared. Once the pop up window came back again, I pushed the power button down and held, while the monitor remained powered, the autio adjust window disappeared as long as i remains the power eye pressed. Now you have the opportunity to solve the problem. I used a tiny clamp to hold a small rubber block against the power button. Haha, it works!! it is really a ugly way, but it is hundreds time better than you seeing the annoying window that right at the center of the monitor you cannot get rid off it. It makes me almost crazy. I am going to change a small nice spring clip to replace the clamp.
Linn
Posted on Jul 27, 2009
I used a ball of aluminum foil and duct tape to keep the power button pressed down!... thanks for the information :)
Posted on Jun 18, 2013
Why does everyone rednec* their monitor instead of getting this issue fixed by Viewsonic?? lol
Posted on Feb 01, 2015
  • Matt Gleason
    Matt Gleason Feb 01, 2015
    I just found a fix on another website..
  • Matt Gleason
    I called Viewsonic and they solved my problem. For those who have this problem, here is the solution. Turn off your monitor and unplug it. Press and hold in the power switch in the front for more than 30 sec. Release the power switch and plug the monitor back in. Turn on the monitor. Problem should be solved. It seems this must be a hard reset if things go astray with the monitor. It solved my problem and I hope it solves anybody else who has this problem. It might even solve the same problem with other monitors.
2 Suggested Answers
SOURCE: audio adjust screen pop up
audio adjust pop up
Posted on Dec 06, 2008
I have a small screen which appears in the middle of my main screen which is for adjusting contrast ect. I keeps popping up I can not remove it there are buttons in the front for exit ect which will not...
Sounds like the monitor menu is popping up. If so, it is not your computer but the monitor that is causing the problem. Is the monitor menu button stuck?
Aug 03, 2010 | E-Machines eMachines Desktop PC
Contrast window pops up and dims the screen.
You are not alone. I have a Viewsonic monitor that does exactly the same thing. Wasn't sure if it was the monitor or a "bug".
Dec 10, 2009 | ViewSonic VX910 19" LCD Monitor
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor keeps displaying model and serial information
@ baller98_199; did you ever get a solution to this? I'm having the same problem with the same monitor!
Mar 13, 2009 | Sony SDM-HS75 17" LCD Monitor
Increasing resolution higher than 800x600
the screen res is adjusted through windows not through the monitor.the pop up you speak of is only informing you the current screen res as set up through windows.
Dec 15, 2007 | ViewSonic VA721 17" LCD Monitor
Viewsonic E70 - Menu Popup
This is a builti n feature on the monitor of course- not PC driven
A repair is not likely
Buy a nice new Flat screen
Oct 25, 2007 | ViewSonic E70 17" CRT Monitor
Blinking main menu of the monitor!
i also have the same problem dude,these f...ing view sonic doesnt support customers,specially for asia..........please help me ,i am very poor and i cant buy another one........please help me brothers........mail me djarunagamage@yahoo.com
thank you and god blesses you all.........greets from sri lanka
Jul 11, 2007 | ViewSonic 17" CRT Monitor
Monitor problems
You need to change down the res. to a minor mode. i.e. 800x600 low quality. For Windows enter the protected mode - i.e. after POST (bootup) press F8 then enter with your account, or the administrator. Right-click anywhere on the empty desktop and enter "Properties" menu. Turn the screen resolution down in there (i.e. 800x600); also, check whether your current monitor is recognized by model in there. Re-adjust to a suitable working resolution. If all fails, you can also de-install the video card driver in admin protected mode to go back to basics. Of course You need to re-install it again afterwards when in your original Windows.
Jan 28, 2007 | ViewSonic VP191b 19" LCD Monitor
Computers & Internet Logo
9,888 people viewed this question
David Payne
David Payne
