Question about Connect3D Radeon X800 / 256MB GDDR3 / PCI Express / VGA / DVI / TV Out / Video Card Graphic Card
Using my panasonic remote to control my sky box
I have a panasonic tx32 -lzd85 tv with panasonic cinema/tuner system. I want to make use of the viera link to extend it to control my sky+ box. I can use the sky+ remote to swith tv on off and volume but not anything else which is a pain having to swap remotes all the time.
Connecting Panasonic SC-PT550 to TX-L42E5B
I have a pansonic tv that i brougt last winter ,All you have to do to get audio from it is use a optical cable,
Nov 26, 2012 | Audio Players & Recorders
I have a panasonic TC-P50ST30 and viera link will not work with my charter HD DVR cable box. I have a HDMI cable connecting them.What can I do?
Unfortunately, your charter HD DVR cable box is not a Viera link device that is compatible with the TC-P50ST30. Viera Link only works to control Panasonic HDAVI devices that are Viera Link ready (and that use the same Viera link coding) when using the HDMI cable. Thus some Viera link devices of different generations will not work with the same Viera link remote.
The manual for the TC-P50ST30 is available here: . See page 32 for details on the Viera link controls.
I wish that I had better news for you. However, you will need to use separate remotes for your cable box and the TV.
Oct 21, 2011 | Televison & Video
Panasonic viera TH50PZ700B 4yrs old. will turn on and begin auto search however does not find channels, sky aerial cables connected. the screen goes to customer id but as soon as a button on the remote...
Tries tv unplug,replug it back like about an hour later for the tv to do a resetting itself back to the factory setting.Go into the tv menu go to PICTURE to go down to do a resetting to the tv Tuner signal board.Tries scanning for channels again.The tv should be work again,if it still have the same result.The tv main board,the tv Tuner signal board is bad.Can u do some mechanicals work like take things aparts and putting it back together again?Yes?Try website like to buy a whole refurbish tv Tuner signal board for the replacement.
Apr 15, 2011 | Panasonic VIERA TH-65PZ700A 65 in. Plasma...
Does the viera th-42pe50b have a port to plug in a sky HD Box?
This particular model of Viera does not have HDMI connectivity.
Hopefully your Sky HD box will have Component Video available (The three Blue, Green, and Red) as this TV does have provision for that source
Feb 28, 2011 | Panasonic Televison & Video
Unabel to use sky control for sound
You have to programme the correct code for your TV into the Sky remote.
You can get these via "Sky Active" (if your box is connected to a phone line) or from the Sky website, or google search: "Sky remote codes".
However your sky remote wont necessarily control more recent televisions unless you have a REV8 remote control. You can check this by taking the battery cover off your remote and looking at the sticker inside. If it says RC1600/00 you're probably not going to be able to control your TV. REV4 and REV6 are more likely to work - but not guaranteed. If it says REV8, then you are probably not using the correct code or you're not programming the remote correctly.
If you have REV8, the correct code for your TV (according to Sky) is: 0678 or 1678 or 0254
Sky remote code finder page is here:
Sky guide to finding your remote code and programming remotes is here:
Please rate my solution if you find this helpful. Thanks.
Oct 13, 2010 | Panasonic Viera TH-42PX80U Plasma TV
No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Dec 10, 2008 | Panasonic SC-HT75 System
I have a Panasonic viera TX-32LMD70 TV and a Panasonic
remote control. I also have sky and I cant use the sky remote
control for the sound when I try to change it asking for the code
and I do not have any for the panasonic remote how came with the TV when I bouth it. Can you help me.
Thank you
Gill Plimmer
Aug 18, 2008 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
Panasonic Viera
vga board is bad ot the components on it are blown out.
May 08, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Home cinema/Viera link problem
Turn everything off and disconnect from mains.
Wait a few minutes.
Disconnect HDMI cable.
Turn on TV and DVD.
Connect cable.
If this does not work use a cable of different spec.
I had the same problem and now mine works .
Good luck.
Oct 06, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Connect3D Radeon X800 / 256MB GDDR3 / PCI Express / VGA / DVI / TV Out / Video Card Graphic Card Logo
76 people viewed this question
Top Connect3D Computers & Internet Experts
David Payne
David Payne
Are you a Connect3D Computer and Internet Expert? Answer questions, earn points and help others
