Question about Belkin Computers & Internet
I have just got a Belkin N1 vision wireless modem router. I have set it up and have it working ok on a Unsecure wireless network. But as soon as I try to secure the network. I get the following message when trying to connect. “The settings on this computer for the network do not match the requirements of the network” Any help please.
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    Are trying to set the security a PC wirelessly?
  • 827 Answers
Right-click on the network icon in the bottom right hand corner of your screen, Press Connect to a Network. You should see your wireless network in the list. Before you secured it, you could automatically connect to it because it was unsecured. Now you will have to double click on it and enter the username and password you secured your router with.
Once you have done that, there should be a box for you to tick that says 'Automatically connect to this network'. Tick that.
Done.
Hope this helps
Chris (ziraffa)
Posted on Dec 20, 2008
  • chris grams
    chris grams Dec 20, 2008
    Oh, just one more thing, in case you are still having problems, or if you had already done the above.. If you received a disk with the router, you may have to run that in your computer too..
    Chris (ziraffa)
How many pc's, laptop's & printer's can i link up to belkin n1 vision wireless router model f5d8232-4
You can uplink a fairly good number of PCs or laptops with Belkin N1 as it supports high bandwidth. Keep in mind that upon adding every new PC, the overall bandwidth for the other PCs is reduced. If the PCs/ laptops do not require much bandwidth, you can connect / add more PCs to the network.
Generally, I have uplinked upto 10-15 clients to one router and the network worked just fine. It all depends upon the network environment and the bandwidth usage by each client PC. If the PCs are using just email and simple internet browsing (and remain idle for most of the time), you can add more clients to your network as not all the systems consume network resources at the same time.
Hope it helps! Good Luck!
CreativeTECH
Apr 01, 2011 | Belkin N1 Vision Wireless Router
My internet is greatly reduced with Belkin N1 vision wireless (before the hook-up it was 15mbps now only 5mbps), I have tested by hooking directly from the modem to the computer and got 15mbps. Before N1,...
When you only get 5 mbps are you connecting to the new router wirelessly or via the ethernet cable? If it is wirelessly then try connecting with an ethernet cable and see if you still get 5 mbps. If so then try resetting the router (the procedures for this will be explained in the manual) and re-test. Wireless connections can slow down due to obstacles such as thick walls or other obstacles of that type. If all else fails return the unit and try another.
Mar 08, 2011 | Belkin N1 Vision Wireless Router
Hi i am using Belkin N1 vision version 102uk when ive plugged this in to the sky adsl router, it is showing no router detected?? can you help?? regards chris
1. check connection by 1st pinging the network card That is go to the dos window and type " ping 127.0.0.1 you should get 4 replies.
if not then you need to check the driver set for you network card.
2. check the ether net cord with a know good one
3. reset the router by unplugging it and reboot the pc
4.Call your ISP to check for outages
Aug 03, 2010 | Belkin N1 Vision Wireless Router
Signal problem
Step 1: Connect Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer (You can use any Web browser )
Step 3:On the left, under wireless click on channel and SSID (leave the password Blank and click submit )
Step 4: Change the Wireless Channel to 6 ( If its already 6 change it to 11)
Step 5: Click apply changes
Step 6: unplug the Router
Step 7: Restart the Computer
Step 8: Plug the power Cable back to the Belkin
Step 9: Connect to your wireless network
Jul 31, 2010 | Belkin N1 Vision Wireless Router
802.11n problem.
Please follow the mentioned step to check if the Wireless card is installed properly
Step 1 :
> click on start (assuming it to be a windows OS)
> right click on "my computer" and select "Properties"
> you will have the system Properties window pop-up
> under the Hardware tab, click on Device manager button
> under the device manager list look for network adapters
> you should now be able to see your wireless card under network adapter - check if the adapter is enabled ( if not kindly enable by right clicking on the adapter)
> once the adapter is active - it will have a green icon with not error on it.
> Now try to search for the network again - this should work..
Oct 17, 2009 | Belkin N1 Vision Wireless-N Wireless...
My Belkin n1 router disconnects from telstra every 2 hours - exac
This is a known problem with the Belkin N1 Vision Modem Router. The router keeps time by connecting to a Simple Network Time Protocol (SNTP) server every 2 hours. The solution is to go to www.belkin.com and download and install the pre-release firmware which is supposed to fix "A problem where the router could drop some connections on 2-hour intervals" among other things.
Sep 14, 2009 | Belkin N1 Vision Wireless Router
Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Mar 20, 2009 | Belkin N1 Vision Wireless Router
Belkin Wireless Modem Router problem
well, first of all the i also have the N1 belkin wireless modem router, in order for it to connect, there has to be a wireless connection in your area for you to connect to, if any of your neighbors so have wireless you can connect to their network, but if you are not getting a conection that means no one around you has wireless or lan, the belkin wireless is not a internet provider it just extends the distance of your internal wireless. some networks may be secured as well, sometimes you can only connect to unsecured networks unless you have the name and passcode for the secured network.
May 28, 2008 | Computers & Internet
Belkin n1 wireless usb adapter
Dear Friend,
1. Connect your ISP modem to your PC and configure as Bridge mode.
2. Remove your ISP modem and connect your wireless router to your PC and configure as PPPOE mode. (refer http://www.wi-fiplanet.com/reviews/article.php/3645166 if any doubt on configuration)
3. Now connect your ISP modem to wireless router, The modem should connect to your WAN cable.
4. And Give the wireless router's IP in your laptop as Gateway (In TCPIP settings of your Laptop wireless adapter / or configure DHCP)
5. Now you can access internet on both systems.
Feb 02, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Computers & Internet Logo
71 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
