Question about Sharper Image PH130 Shelf System
I have lost my instruction manual and am having difficulty setting the memory function. The unit has 20 preset channel options and I think I've pushed every button and combinaiton of buttons and can't figure it out. Can you help?
Tune in desired channel
Press clk adj/mem button...00 appears on screen
Press mem up/repeat button untill the channel number appears that you want to program 01 - 20.
DONE!!!
very intuitive huh...took me an hour to stumble on it....
Posted on Aug 28, 2008
Sharper Image SA255 cd door would,not work, got frozen, not able to close it even manually
This could be due to a mechanical failure in the door mechanism, BUT I had a 3-disc unit on the bench recently and the control logic was messed up. Try the reset and check to see whether it specifies the drive you are having trouble with as the one to be loaded
Nov 25, 2012 | Sharper Image SA255 CD Shelf System
Nakamichi Soundscape 5 3 Disc System
Hi David, Saving Presets: 1. Navigate to your favorite station with the UP/DOWN buttons. 2. Press MEMORY once. The preset choice will go to the next available one. 3. Within 5 seconds, press MEMORY again to save the current frequency as a preset, or else use the UP/DOWN buttons to fi nd another preset number, then press MEMORY to save it. 4. The UP/DOWN buttons usually tune the frequency, but when loading the presets, they navigate the presets. Try this and let us know if it works for you. Best regards, Bill
Jul 04, 2007 | Nakamichi SoundSpace 5 Shelf System
How do i preset radio stations on my bush cmc22dab music system
Try to downlaod the user manual to your set from internet. If you feel any difficulty in downloading, send your email address to me by fieya. I'll send a copy of the manual to you by return mail. It will have all the details.
Apr 09, 2012 | Audio Players & Recorders
I can't figure out how to set the radio station pre sets
hi,
there is no auto presetting available. u have to set all channels in preset manually. if u power off the subwoofer all setting will be erased.for manual preset do the following.
1. Press the FUNCTION button to select "TUNER".
2. Press the FM/AM button to select a band.
3. Select the station you want to listen to (Hold down the TUNING Up or Down button until the
frequency display begins to change. When a station is tuned in, the tuning process will stop automatically.)
when it tune the first station available do the following to preset it,
4 .Press the MEMORY button.( on remote)
5. Within 5 seconds, select a preset channel to store the
station using the PRESET buttons of the remote control
unit.
6. Within 5 seconds, press the MEMORY button.(The station is stored and the MEMORY indicator goes off. To store more stations, repeat steps 3 to 6) .
for listening preset ed station ,Press the PRESET button repeatedly until the desired
preset station is found.
ok
Dec 24, 2010 | Teac CD-X9 Shelf System
Instruction book for a micro cd shelf system
not solved - but not going to pay for an instruction book when it should be a 'downloadable' item by sharper image
Dec 03, 2009 | Sharper Image SO330 CD Shelf System
Lost sound
try to tap on the front and top may has dry soldring
Nov 17, 2009 | Sharper Image PH130 Shelf System
Sharper image power tower 200
There is a small 1 1/2 inch O ring style belt that connects the motor to a set of gears. This belt is most likely broken and needs to be replaced.
May 17, 2009 | Sharper Image Power Tower Motorized DVD...
Instructions on programming Nakamichi SS5 radio presets
The solution is really very simple.
This unit is capable of a total of 30 presets.
10 AM presets in 2 groups (AM1 & AM2).
20 FM presets in 4 groups (FM1 - FM4).
Each of the individual groups can have a total of 5 presets.
In other words, there are 6 groups of 5 presets (AM1 AM2 FM1 FM2 FM3 FM4) for a total of 30 presets. Hope that makes sense.
You have preset buttons 1-3 on the top of the unit. Preset button #3 is the MEMORY or "set" button.
Try these steps and you should be up and running.
1. Choose which band you want to use. ie. AM1 AM2 FM1 FM2 FM3 FM4.
2. Tune in a station
3. Click the #1 preset button and watch the screen, let's say that you have tuned into the station FM 100.0, the station frequency is displayed along with the "group" you're in (ie. AM1...FM4) and you will also notice a number in between your "group" id and your station. This is the # you're going to set and the way to change this from 1-5 is simply by pressing the #1 preset button until the # comes up that you want to save it to.
4. Press #3 Preset button (labeled "MEMORY")
5. That's it, now do all the stations you want but be mindful that once you have programmed 5 presets to any given group, you have to move on to the next group until you've maxed out the total # of presets.
Hope this helps.
Jan 25, 2009 | Nakamichi SoundSpace 5 Shelf System
Sharper image clock radio for shower
To set tuner presets:
1. Manually tune desired frequency.
2. Press MEMO button, Display will flash.
3. Manually enter memory position, 1-5.
4. Press MEMO button again.
The manual is available as a PDF file from the Grundig web site. Or, if you will e-mail me at deepblack <at>ugaalum<dot>uga<dot>edu and put "Yachtboy" in the subject, I will e-mail it to you
Mar 23, 2008 | Grundig Yacht Boy P2000 AM/FM/SW Radio
Sharper Image SA260 Stereo Shelf System
open the stereo doors and switch the line button on the bottom right from out to in
Apr 09, 2007 | Sharper Image SA260 CD Shelf System
Sharper Image PH130 Shelf System Logo
351 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
woodzowl307
Tom Chichester
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
