Question about Samsung DLP HL-P5663W 56" TV
No picture We are currently in the middle of doing some home improvement, so our house has been a little dusty. One day last week, we turned on the TV and there was no picture. However, we happened to turn it on again that night and noticed that we could see the picture in the dark. We still cannot see the picture during the day, only in the darkeness. We looked through the owner's manual, and it did say to keep the TV away from dusty areas, but it didn't say how to fix the problem. Do you think the dust caused this problem? Is there anyway to fix it?
  • 68 Answers
Well, give it a try and open that tv and then use air blower to clean it up. good luck
Posted on Apr 02, 2007
Is not opening
Yellow Hibiscus, Mothers Day gift. My son brought it home last night.
2 blooms lots of buds. Blooms closed last night, today still not open. Transfered to larger pot. Added water and a little extra soil.
Nov 26, 2013 | Spooky House Studios UG Bubble Explode
No picture, No sound
It sounds that the IIC Bus circuit shorts bey some faulty components connected to it. The troubleshooting work to this section circuit is very skilled one. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Feb 11, 2013 | Digital Lifestyle FA1B32Z 32 in. LCD...
How much for a weekly cleaning service?
The rate of cleaning services are different from company to company and from the condition of your house. Generally cleaning services in a week is not costly if you get regular cleaning services because in this situation your home will not too more dirty therefore the cleaning service provider charge small amount. You have heard that health is wealth and most of us has done this experiment. When we become ill we do not be able to continue our work as well as it affects us mentally too.There are many health issues increasing day by day , hence it is necessary to concentrate on the home cleaning.
NEW YORK CLEANING SERVICE
Nov 29, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
Why is line feeding out too fast on 503a
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Untail Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, !!
Jan 29, 2012 | Garden
Picture how to string a ballon shade
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Until Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, !!
Jan 20, 2012 | Garden
My mitsubichi projection tv model vs-50605 is getting dark, Do i need to change the bulb
This model does not use a "bulb", it has three picture tubes.
What does happen is the lens for each can get dusty; picture will gradually get dimmer and dull looking.
With set unplugged, remove rear cover (it can be done from front but back is safer for a do it yourself person..
With the rear cover removed look for the 3 large black lens pointing up in the middle of the set--simply clean them with a lens cloth or a paper towel with glass cleaner sprayed on it---this should usually be done once a year.
If they have not been cleaned recently or you are in a dusty environment, cleaning them should improve the picture a lot.
Let me know if you have questions.
SD TECH
Jun 01, 2011 | Mitsubishi VS-50605 50" Rear Projection...
Dryer heater stops working
BAD AIR FLOW CAUSED BY VENTING IN THE HOUSE BEING PLUGGED
Aug 11, 2009 | Amana Dryers
Philips HDTV does not turn on
I would check the line coil and horizontal and low voltage regulator transistors.
Jan 21, 2008 | Philips 60PP9202 60" Rear Projection...
look for imperfect contacts on the inside main board.
Jan 21, 2008 | JVC AV-27230 27" TV
Samsung DLP HL-P5663W 56" TV Logo
63 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
