Question about HP PSC 1350 All-In-One Thermal Printer
Red light ink cartridge keeps on blinking
I replaced the ink cartridge witrh a new one but the red light keeps blinking
i turned the printer off and on again, with no result
the printer doesn't print or scan
  • van_casteren Dec 20, 2008
    it keeps on saying check ink cartridge, so I did. I thought the cartridge was empty so I replaced it. first for a refill, later for an original hp cartridge. But still it refuses to print becaus it keeps on giving this warning.
    Now what?
    Reina
    Sergeant:
    Champion:
  • 247 Answers
What does it say next to the blinking light for example check paper, check ink cartridge, etc.?
tom
Posted on Dec 20, 2008
  • Thomas Dec 20, 2008
    here is a website for you to check to solve you problem maybe, it is from HP:
    http://h10025.www1.hp.com/ewfrf/wc/docum...
    hopefully this helps you, cause it sounds like you have a bad ink cartridge and it won't hurt to check the website out and maybe it will cure your issue.
    let me know if you need anything else.
    thanks
    tom
  • Thomas Dec 22, 2008
    did me solution work for you? if so will you please change the rating to fixya please?
    thanks
    tom
I have replaced black ink on a hp deskjet 960c and the red light keeps flashing
I see you replaced the Black in on your HP printer but the light keeps on blinking still.
Make sure that you remove the silicon film from the ink cartridge before installing in the printer, if that file is not removed the contact to the printers ink will not detect the ink cartridge at all.
Also try to remove all the ink cartridges and install all of them at the same time , this is to reset the printer from detecting all the printer ink cartridges.
I hope this helps
Oct 26, 2011 | HP DeskJet 960c InkJet Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Ink indicator keeps on blinking even with new ink cartridge.
The blinking ink light means that the printer does not recognize one of the ink cartridges. Power the printer off, pull out the power cord, wait for awhile, replug and turn the printer on. If the light no longer blinks, ok. If not, try installing another cartridge pair if you have them available - even if they are old used ones. If the ink light continues to blink with different cartridges or if you don't have any different cartridges, old or new, you have a dilemma. Do you want a new printer or do you want to continue to chase this problem. To chase this problem, get new cartridges and install them (half the price of a new printer). If that works your set, but if not you need to have your printer serviced which is doubtful that it is worthwhile doing so.
Mar 03, 2011 | HP DeskJet 810c InkJet Printer
The orange ink cartridge light keeps blinking. We
the problem is that your cartridges are expired or bad, just replace the two cartridges with a new one
Mar 16, 2010 | HP DeskJet 940c InkJet Printer
Ink light of my tx101 keeps blinking
Hello, Amit.
From FixYa, give this a try:
Lift up the scanner bed (top part) of the printer to expose the cartridges.
Push the red triangle button once. Wait for the cartridge carrier to move to the middle. On the housing of the printer (the non-moving part), there is an arrow that will point to the empty cartridge.
Push the red triangle button again to see if the next cartridge is empty. Repeat this step, noting which cartridges are empty, until the cartridge carrier moves to the right. Now you can replace each cartridge that is empty.
After replacing the empty cartridges, push the red triangle button again, and the carrier will begin moving back and forth (cleaning itself). Once it stops, it should be positioned on the far right side.
Lower the scanner bed to "close" the printer. The ink light should go off and you should be able to print.
Hope this helps.
Oct 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Top light blinking, will not print
I believe that the top light is the low printer cartridge signal. Did you replace the cartridge or just take it out and reinstall it? Did you use a new HP cartridge or refilled cartridge?
Try a new ink cartridge from HP and double check that you have the correct cartridge for your printer. If that doesn't solve the problem, contact HP.
Sep 15, 2009 | HP DeskJet 5550 InkJet Printer
Says replace ink cartridge
I have replaced my ink cartridges numerous times and they are still full. It keeps telling me the ink cartridge needs replacing. It won't print and the red light keeps blinking. I have disconnected the usb and the power. I have only had this printer for about a year. It won't scan or print. Its a Kodak Easyshare 5300. The HomeCenter AiO is disconnected so how do I contact anyone from Kodak?
Feb 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Blinking Red Light
unplug your printer
try to move the ink case manually.
if you could remove the ink cartridge, then clean the contacts both on the cartridge and case. return the cartridges then move the case to its original location
plug
Nov 06, 2008 | HP PhotoSmart 7660 InkJet Printer
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
C43sx both lights on
ok...start by removing the drivers from control panel, go to website and get new drivers, install them, try it again.
http://tinyurl.com/6qcpgy
Jun 11, 2008 | Epson Stylus C43SX InkJet Printer
HP PSC 1350 All-In-One Thermal Printer Logo
474 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
