Question about Hitachi Televison & Video
I have a hitachi 37ld8700, it was working fine when it suddenly went on stand by on its own and will not come back on, I've tried the remote, using the button on the side of the tv, turning the power off at the socket for a minute but nothing seems to work.
techman
  • 3130 Answers
SOURCE: TV auto shut off-power indicator light blinking-won't turn back on
You could have gotten an electrical surge that put your set into a shutdown condition and unplugging the set and letting the Microprocessor reset will fix this problem if it dosent blow out the main power regulator as you still or might I say have a regulator IC problem. IF THIS PROBLEM HAPPENS AGAIN MORE THEN A FEW TIMES WITHIN A SMALL TIME FRAME I WOULD HAVE THE SET LOOKED AT BEFORE THE REGULAOR BLOWS SOMETHING OUT!!!!
Posted on May 14, 2006
SOURCE: tv wont turn on
That same thing just happened to my t.v. The repair person will be here on 10/10/06. I will let you know what they say.
Posted on Sep 27, 2006
SOURCE: Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Posted on Jul 18, 2007
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
  • 55 Answers
the flashing light often shows malfunction ,check the wire connection of your devices something must be wrong .the surge protector you have is for overpower or low voltage too?Ask your neigbours if they have shame problems
Posted on Nov 18, 2007
The red power light comes on but nothing else works on my hitachi 53FDX01B PROJECTION TV
silly question but have you tried turning it on with the remote. if a tv has been turned off by remote and then power goes, turning it on by the tv switch will put the tv back in stand-by mode and you need to use remote.
just a suggestion.
Dec 13, 2013 | Hitachi 53FDX01B 53" Rear Projection...
Buttons stopped working
If there is a tv button on the remote, try pressing that..
Chances are its damaged and you might need to order a new one from Hitachi or possibly use a universal.. With remotes there really isnt much you can do when they stop functioning.
Jul 17, 2008 | Hitachi VT-RM391A Remote Control
All of the sudden my printer is telling me that my cartridges are "Invalid"
is you machine hooked up and have internet then it might have gotten new firmware and if you are using generic cartridges this can happen. try oem lexmark cart.
Jul 04, 2017 | Lexmark X2500 All-In-One Printer
Hitachi Ultravision, 1998 model, 50" screen. It turned itself off and will not turn on.
I had the same one. And my color went out and had a rainbow on its left side. I think what I was told its because it was being used for gaming. The tv cannot stand on a blank screen for long. Maybe this will help.
Jan 13, 2012 | Hitachi Televison & Video
My Element 40" Tv is stuck in stand by how do I
hi have you changed the batteries in the remote, if the remote is ok there's a fault with the tv, could be a swollen capacitors shorted diode or poor solder joint,or a bad mainboard , thanks
shaun
Mar 08, 2017 | Element ELCHW402 40 in. LCD HDTV
I have a Hitachi it is stuck on stand by. Cant
Hi I have same problem as you but with different brand of tv, now is all good, if you open your back tv see there board connect to your on /off button on tv or find where is on/off button on your tv, try follow where is the wire going to the board,there is 3 cappacitor in mt tv said 470 uf 25 V your tv could be different size. the capacitor doesnt look bulge or bad but i just change it cost me aus $ 2.10.and work straigh away. hopely this help.
regards.
Apr 30, 2010 | Hitachi 42HDS69 42 in. Plasma Television
I have a 2006 Hitachi Ultravision 42 inch plasma
plasma tv units use a lot of power ,well into the hundreds of watts 9 some big screens use up to 800 watts to work)
I suggest that you consider a new led unit which uses barely any power and you will get a remote with it
Jun 24, 2017 | Hitachi UltraVision 42HDS52 42 in....
Techwood HDMI 32'' TV - Went to black screen while watching
Am Martyn...ma Tv same model did the same thing this mornign while i played FIFA 2010 world cup on PS3 Fat...what could be the problem???
Jun 14, 2009 | Televison & Video
I need a remote code for a hitachi tv
Here is the setup copde page http://universal.dev.efocus.nl/?pag=54. I didn't see that model remote listed but many times the remote manufacturer will use the same codes.... So look at other remote codes for Hitachi and see which one works.
MM85
Jul 24, 2008 | One For All URC-3021 Remote Control
Televison & Video Logo
75 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
