Question about Hotpoint WMA32 Front Load Washer
Hotpoint WMA 32 broken wires on Motor?
My Hotpoint washing machine WMA 32 kept tripping the circuit breaker on the fuse box. The motor would start but every time the heater element switched on the circuit breaker tripped the house. I found that both wires to the heater element had worn down to the bare copper, probably caused by rubbing against the lower concrete block (bad design Hotpoint). I repaired these with insulation tape. While doing this I also cleaned up the brushes on the motor - they were very 'sooty' but had plenty of wear left in them. I also found that one of the wires on the connector to the main motor had broken off completely, (before I touched anything - honestly!), either the 1st or 7th wire I think. This was reconnected but does anyone know what the wires are for i.e. would it reduce the motor speed by not selecting one othe windings. I had noticed that clothes were not as dry as they used to be, but had ignored this. So maybe this wire enabled the fast speed to be done.
The mashine now washes fine, but I'm curious about the wires on the connector to the motor.
Thanks for any help.
  • 135 Answers
This has to be the pick up for the fast spin as any other would disable the motor.
Posted on Dec 20, 2008
Testimonial: "Thank you for the suggestion. Since fixing it, the machine has worked fine."
  • patsy70 Jun 04, 2011
    hi my washing machine was tripping the curcuit, i removed the top to find the 3 wires all completely snapped off, what would cause this and do i just reconnet all 3 wires andwill this be safe,
    many thanks
    patricia
I turn on power button. Short time later 20 amp breaker trips. I can reset breaker and do a load of wash. Must repeat for each load. I replaced receptacle and 20 amp breaker. Same results
Please do not do another load of wash until this problem is fixed, or you may find yourself with a house/apartment fire!
I am thinking your motor (most likely) or the controls (least) have a short, and are causing your problem.
Oh, yes.
Take a really good look at the circuit breaker box inside, because a broken or loose ground wire ( there are two) can also cause this problem.
One ground wire should be white, one should be bare.
Each should be securely screwed into the lugs of the grounded section of the circuit breaker box.
God bless your efforts.
Jan 12, 2016 | LG WM Washing Machines
Hotpoint ultima trips fuse
Motor is probably defective. The only other thing that could cause the breaker to trip is a short circuit. Look for any wires that have come loose and fell off from any terminal connection points.
Dec 05, 2015 | Hotpoint Washing Machines
Hotpoint ultima wt940 washing machine
Either you dont have a high enough amperage breaker or the motor is going bad
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 10, 2013 | Hotpoint Ultima WF860 Front Load Washer
Washing machine has blown a fuse and tripped the curcuit breaker
I hate to say this but a blown fuse in that machine wouldnt trip the breaker, so if you turn the breaker on and it stays on until you start the machine the motor is probably shorted and need to be replaced
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 10, 2012 | Hotpoint First Edition WMA22 Front Load...
Hotpoint TDL 52P trips RCD at fuse box when switched on at socket
hi martin it sound like bad earth this could be anythink check the plug for loose wire check the socket for loose wires if check motor wire in the washer also check circuit board connections if all wires are ok you could have a faulty motor hope it helps
regards
shaun
Nov 14, 2011 | Washing Machines
No heat in dryer
Hi
Thanks for using FixYa. If your dryer isn't working or isn't getting heated up, you'll need to check the following to be sure what exactly the issue is--
Blows fuses or trips circuit breaker —ELECTRIC Models:
• The amperage readings are at 240 volts. One line will be 24 amps and the other line will be 21 amps. The neutral line will be at 3 amps. If the above amperages are not present, then the house wiring, fuse box or circuit breaker should be suspect.
• Shorted heating element to housing.
• Incorrect wiring or a wire shorting to ground.
• Drive motor winding shorting to ground.
Blows fuses or trips circuit breaker —GAS Models:
• If igniter is not glowing, check for 120 V at igniter.
• Igniter harness may be loose and shorted to base.
• Incorrect wiring or a wire shorted to ground.
If it runs for a few minutes and then stops, then check for the following:--
• Empty dryer.
• Check motor spins freely.
• Lint buildup around drive motor.
• Low voltage present.
• Blower impeller blocked in blower housing.
• Drive motor - start switch contacts stuck closed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 12, 2009 | KitchenAid Dryers
Hotpoint ultima cd80 condenser dryer has stopped heating can it be repaired/reset or is it a new unit and how much? Cheers
Hi
• Empty dryer.
Thanks
Rylee
Nov 10, 2009 | Hotpoint Dryers
Why does my washing machine trip the electric
run the machine, after it trips, unplug and carefully touch the motor,it may have a bad capacitor, or dry bearings causing it to draw excessive current,if these 2 things are not it, then look for a bare wire that may be touching case during this part of the cycle,and if you can get an "Amprobe" it reads current and check machines current draw during the start to trip current
Oct 27, 2009 | Hotpoint WMA58 Front Load Washer
Hotpoint washing machine keeps tripping electric
First unplug your washer. Check the ground on the washer and make sure it isn't loose; this would be a good time to inspect the wiring harness for any problems. Next check the outlet (turn off the electric to that breaker first) make sure all the wires are tight and are making good contact; pay special attention to the neutral (white) wire. If that seems fine, and you are comfortable with going into you breaker panel, turn off that breaker and check the hot (the wire on the breaker) to make sure it isn't loose and then check the neutral wire. If either of these wires seem loose tighten them down....a loose wire will move when a load is put on it and cause the breaker to trip. If all seems normal and washer is still tripping the breaker you might want to replace the breaker.....they can go bad. Good luck!
Aug 26, 2009 | Hotpoint Washing Machines
Hot point washing machine WMA 32
It's unusual for a household RCD to go out on excess current from an appliance - the fuse in the plug top and circuit fuse/MCB in the consumer unit should provide closer protection. This leaves you with an earth fault. Earth faults aren't usually related to motor load. Watch carefully what phase of the cycle the trip happens. Does it correlate with the start of water heating? A very frequent cause of low current earth faults is water ingress into the heating element. If you can trip the RCD reliably on every cycle, running the same cycle with the element disconnected would confirm whether or not this is the cause. A.
Feb 28, 2007 | Hotpoint WMA32 Front Load Washer
Hotpoint WMA32 Front Load Washer Logo
248 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
