Question about Canon EOS Rebel GII with 35-80 lens 35mm Film Camera
Low battery indicator
I received the low battery indicator so i replaced the batteries. the camera still will not work. the low battery indicator still flashes & i cannot take a photo. i have had the camera for 2 years. this sounds just like "alisha"'s problem but it was not commented on. any ideas?
  • jakersavesth Jun 16, 2008
    i have the same thing and whenever i press any button it makes an odd sound
  • word up Aug 06, 2008
    same problem,i wonder if there is another battery inside somewhere?
  • 60 Answers
If that camera has a problem, the low battery symbol will flash as a warning to tell you that it is not working properly. Kind of like the "Check Engine" light in your car. It tells you something is not working, but doesn't give you any clue what it is!
Check to make sure the pop-up flash is not sticking down when it is supposed to be popping up. That is the most common cause for that problem. Also, check the shutter blades in the film compartment to make sure they haven't been pushed out of their tracks when you were loading film.
If neither one of those is causing the problem, take it to a local camera repair shop and have them check it out.
CameraRepairs
Posted on Aug 11, 2008
My remote is red light is flashing. I changed the batter and the battery in the unit is working. I can turn on the fireplace manually
  • The usual indication for a flashing light is a low battery. Suggest checking the remote again. Especially for corrosion at the battery terminals.
  • When you operate the remote will the receiver flash its LED indicator confirming that the command has been received.
  • The manual operation of the receiver located at the fireplace likely does not require batteries. For remote control operation good batteries are required.
  • If the red LED on the receiver is flashing the batteries need to be replaced.
  • If the LED at the receiver indicated that the command is received check the wires to the control valve from the receiver. The voltage is a very very low a millivolt signal.
Dec 01, 2015 | Heating & Cooling
Why did my flash stopped working
It should have said low batt in a day but just take them out and recharge or replace
Jul 11, 2014 | Wingscapes WSCA02 Digital Camera
Nikon N90 Flashing Battery Indicator
Take out the memory card and see if that makes a difference.
Sep 06, 2013 | Photography
My Nikon Coolpix S2550 says the battery is low when I need to use the flash - but I have fully charged the battery please help
try leaving the camera on to drain the battery down, then try charging it again.. or could be a bad battery
Dec 30, 2011 | Nikon Cameras
Take a picture and the camera freezes
hi..This problem is due to the low battery.orange
light indicates that battery is low.you need to
change your battery.
check it out..
thank u..
kindly rate my response..
May 09, 2009 | Olympus FE-270 Digital Camera
Auto flash not working right
This is actually a repair issue with the flash charging indicator switch. It needs to be replaced as it has failed. You can call Olympus Customer Service to discuss their repair policy and preocedures. Their telephone number is 800-622-6372 option 2 and then option 3.
Feb 17, 2009 | Olympus Camedia Stylus 300 Digital Camera
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Jun 17, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Flash won't fire
charging flash:-
POSSIBLE CAUSE:The camera is recharging the flash.
SOLUTION:It takes longer to charge the flash when the battery is low. If this message appears a lot, replace or recharge the battery.
Dec 28, 2007 | HP Photosmart R607 Digital Camera
Canon EOS Rebel GII with 35-80 lens 35mm Film Camera Logo
130 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
