Question about Apple iPod nano
I forget my code so my ipod is locked - Apple iPod nano
I am the best man to help you. okay your solution is to.... GET A NEW ipod
Posted on Dec 20, 2008
DESBLOQUEAR PANTALLA
How to Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod. In order to use the device's functions again, you need to enter the correct code. However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Things You'll Need:
iPod Nano Mac or PC computer iPod USB cable
1 Plug the iPod USB cable into the bottom of your iPod Nano. Plug the other end of the USB cable into a free USB port on your Mac or PC computer. Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
2 Select your iPod Nano from the "Devices" list in the main iTunes window. Click on the "Sync" button to make a connection between your computer and your iPod Nano.
3 Click on the "Eject" symbol once the syncing process is complete. Remove your iPod Nano from the USB cable. The iPod's lock code will now be reset and you will be able to access all features again.
4 Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again. Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
Jan 05, 2012 | Apple iPod nano
Enter code i pod \
Hi
Things You'll Need
Dec 30, 2011 | Apple iPod nano
Got locked out i pod touch
How to Unlock a 16GB iPod Touch
Apple's iPod Touch comes with a screen lock feature that allows you to set a four-digit security code to prevent others from using your iPod. Every time the iPod locks, you must enter this code to unlock the screen and access the user interface. Entering the wrong code too many times, or simply forgetting your security code, can cause you to be completely locked out. When this happens, you can quickly
Instructions
1Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked.
2 If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding.
3 In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore."
4 When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore."
5 After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel.
6 Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration.
Tips & Warnings
Apple notes that the company will not be able to help you unlock your iPod if you forget the security combination. Your only choice is to restore the device to the original factory settings.
Dec 05, 2011 | Apple iPod nano
Forgot my code to unlick my ipod
Hi friend, Don't worry.. It is easy to solve your problem. Just follow these steps..
  1. Plug the iPod USB cable into the bottom of your iPod Nano. Plug the other end of the USB cable into a free USB port on your Mac or PC computer. Open the iTunes program by using the Dock on a Mac or the Start menu on a PC. if you don't have itunes software, get it from here.
  • Select your iPod Nano from the "Devices" list in the main iTunes window. Click on the "Sync" button to make a connection between your computer and your iPod Nano.
  • Click on the "Eject" symbol once the syncing process is complete. Remove your iPod Nano from the USB cable. The iPod's lock code will now be reset and you will be able to access all features again.
  • Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again. Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code
If you still unable to solve the issue, click here to know more information
Hope it works.. Don't forget to rate me please..
All the best.. :)
Jan 29, 2011 | Apple iPod nano
My ipod 8gb is locked how do i unlock it
According to Apple, if you have forgotten the code, you can unlock the
IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one
IPod synced with), and open iTunes. When you disconnect iPod from the
computer, it will no longer be locked.
If you can't unlock IPod using either [the code or connecting it to the
computer you use to manage its songs]. . . you can restore your iPod to
factory settings using iPod Updater. Please note that this will erase
all data on your iPod. Afterwards, you can add your music and data back
to your iPod.
If you want to change the primary computer that your IPod is associated
with, do this:
1. Restore your iPod. Warning: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the
IPod, which will erase all music and data."
Good Luck, I hope this helps
Please do not forget to rate me...Thank You
Aug 09, 2010 | Apple iPod touch
Forgot lock code for ipod 8gb grandson lockd it and doesnt remember the code to unlock it
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod.
Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the iPod, which will erase all music and data."
Mar 06, 2010 | Apple iPod nano
I haven't locked my ipod but i dont remember the code?
i have a 2nd gen ipod nano. how do you reset the lock code if you forget it?
Jul 09, 2009 | XO Vision EM200VID MP3 Player
Set a code
Go Menu> extras >screen lock > change combination  then turn screen lock on
Jul 21, 2008 | Apple iPod nano
Ipod lock code
My i pod ( 80gb) screen get locked & i forget the code, please advice
Mar 09, 2008 | XO Vision EM200VID MP3 Player
I for got my code and cant unlock
my friend sold me a ipod and the screen got locked and he forgot the password
Dec 14, 2007 | Apple iPod MP3 Player
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
