Bosch Maxx Classic water drain problem
Hi there, I had our washing machine delivered on Saturday, put it on a test run (15 min express) with no soap or clothing. Got down to 12 mins and then stopped and it refused to drain.... Called Bosch, they mentioned something about the petrol cap looking thing at the bottom right of the washer. So i openened it, water came spilling out all over the laundry floor... So after this i tried another 15 min wash, it worked, the whole wash and it drained. But afterwards, I opened the cap again and more water came out... Do I have to be doing this after every wash?? Should I even have to be doing this at all? I dont really want to be flooding the floor every time i need a clean set of clothes.... Cheers I have a Bosch Maxx WFO 2050 Front Loader and have been unable to get the cap of to the filter recently.
It has worked in past but wouldnt budge this time.
Any way I have broken the plastic cap / plug and was wondering if someone knew were to get a replacement
Thanks
3 Suggested Answers
  • 1462 Answers
SOURCE: Bosch Maxx Classic water drain problem
you only need to check the filter once a month or so depending on what you wash - blankets for example give off a lot of fluff. to help prevent water spilling out when you check, put machine on drain and check filter while draining.
Posted on Jul 15, 2008
barkencoa
  • 3463 Answers
SOURCE: My Bosch Maxx 2000 WFO 2060 is leaking from the
The filter is usually located at the bottom right front of washer, sometimes behind a removeable cover, or a drop down flap.If you can locate it, then unscrew it anti-clockwise to remove and clean it.
There is also a possibility that there could be a hole or tear in the door seal so check the seal as well.
Hope this is of some help to you .
Posted on Dec 08, 2009
How do I drain the pump on a bosch classic maxx model 18061 au
You will always have some water (up to a litre) left in the pump of any washing machine once the cycle has finished. On some of the Bosch models there is a short black hose next to the filter which will allow you to drain off this excess water in to a shallow baking tray before opening the filter. I there is no hose then usually you can drain straight into a shallow tray
Sep 20, 2014 | Washing Machines
I have an error code E6 on my Bosch Front Loader Maxx Washing Machine, can you please advise what this error is and how to fix??
Hello there
Normally this is a drainage problem code
Unplug the machine and wait for 30 min
During this time Remove the cover on the front bottom right corner or the front cover at the bottom , use the small hose that is attached to the pump to drain the water, from the pump then unscrew the large drain cover and remove the blockage from the drain pump. and any additional hoses then reattach the hoses and then plug in after the 30 minutes is up then press the cancel button and test ...Test by pouring 1L water into section II in the top and setting the machine to 'drain'. it should beging to drain
Mar 07, 2011 | Washing Machines
Washing machine i not draining out. bosch maxx
two possible reasons that you dont drain pump is blocked or to much soap,
Mar 28, 2010 | Bosch Washing Machines
My Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Dec 09, 2009 | Bosch Washing Machines
What does error code E2 mean? I have a Bosch Maxx Classic.
The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
to fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing.
Nov 03, 2009 | Bosch Washing Machines
Bosch Maxx WFL 2061 motor starts running and then stops
Hi ! I have problem with my Bosch Washer wfl 2061 .. It was running till stoped to
realease drain water out... But no drain water come out.. I have checked drain water host... Nothing thaere.. Water was still in the drum Tank... Whoever knows this problem , please kindly suggest or help me to do something.. Thanks.. Peace pkurdnirund@hotmail.com , peacepattaya@gmail.com
Nov 28, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Jul 15, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Bosch max wfl2000 washing machine
Just been through this with our Bosch Maxx, problem was the pump discharge pipe was blocked with soap deposits. I also removed the large black rubber pipe from the drum/pump and cleaned this out as well.
All working fine now.
SteveN
Sep 08, 2007 | Washing Machines
Washing Machines Logo
390 people viewed this question
Top Washing Machines Experts
