Question about Adobe PageMaker Plus 6.5 for PC
I need to make a booklet. so when i print the document it be read like in abook
  • Dot Ball
    Dot Ball May 11, 2010
    Pacita, let us know how you went. If you still need help Arceye is on the right track.
    PageMaker has no imposition plugin/features and it has to be done manually.
    Let us know if you still need help and we can talk you through it - it sounds way more complex than it is.
Hi, I dont actually use PageMaker, so you might need to check your help file for more info.
Basically you need to look for an option that lets you 'impose' your document (there may be a tool box or print option for imposition).
If you cant find it just do the imposition yourself.
For a simple 8 page A5 booklet you would want two A5 pages side-by-side on an A4 sheet of paper.
Back cover would be on the left (pg8) - Front on the right (pg1).
Inside front cover on the left (pg2) - inside back on the right (pg7).
Then the centre pages - right (pg3) - left (pg6)
Inner double pages - left (pg4) - right (pg5)
Hope that helps!
arceye10
Posted on Dec 31, 2008
When printing a duplex booklet, the printout is reduced in size with larger margins than in original document. How can I get it to print regular size?
It happens when the documents is on A4 size and the printer is set to print on letter size (which is smaller in size). Hence the printer automatically resizes the prints which result in larger margins and print as compared to the actual document.
Therefore, when you print the documents (Press Ctrl+P) you have to select the paper (A4) from the print properties.
Hope it helps! Good Luck!
CreativeTECH
Mar 02, 2011 | Brother MFC-9840CDW Laser Printer
Booklet layout
Is page on printing on the left hand side or right hand side?
<a href="http://stashbox.org/77137/printing.png">http://stashbox.org/77137/printing.png</a>
<img src="http://stashbox.org/77137/printing.png">
Jan 31, 2008 | Dell 922 All-In-One InkJet Printer
Booklet printing pages in wrong order.
I believe this is going to be a software issue. Do a print preview of the booklet first to see if they are showing up in the right order. If they are, then it is a printer issues and I really can't help you there, but it they aren't then you know it might be a software issue. Check you formatting on the document before you trying printing it again.
Jun 30, 2009 | Epson Stylus Photo R300 InkJet Printer
Canon 3200 - trying to do booklet printing, saddle stitch. The booklet should be 2 pages total (stitched together) but only one page comes out (with no stitch since it is one page) and a page of my...
Are you sure that the original documents fed through properly? If the document feeder double feeds then the machine will think that there is only one document, the first one. If the machine does not through up an error then this may well be the problem. Check with normal copying first. Also remember, you would need at least 5 or more documents to make a booklet as each page has 4 A4 pages reduced to A5.
Jun 24, 2009 | Canon imageRUNNER C3200 Copier
Error Message says "Cannot Print Booklet or Magazine due to Mixed Color Modes"
Might be a bug in the software.
Suggest try re-download again.
Dec 02, 2017 | Office Equipment & Supplies
My HP LaserJet 1020 don't print pdf
go in contact with HP help and customer support....or read ur instruction booklet under trouble.shooting aand help......
Mar 12, 2009 | HP LaserJet 1020 Printer
Designing a document in book form and printing in Word 2007
When you select Book fold for your page setup, Microsoft Word prints two pages on one side of the paper. When you fold the paper, it opens like a book. This option is intended for documents that have more than two pages.
1. Set up your document as a booklet.
When you create a booklet, it's best to start with a new, blank document so that you have better control over the placement of text, graphics, and other elements. You can add a book fold to an existing document, but you may have to reposition some elements once the book fold is in place.
A. Start a new, blank document.
B. On the File menu, click Page Setup, and then click the Margins tab.
C. In the Multiple pages list, select Book fold.
If your document is not set to landscape orientation, Microsoft Word sets it to landscape.
D. In the Inside and Outside boxes, type or select the amount of space you want for the inside and outside margins (margin: The blank space outside the printing area on a page.).
If you need even more space along the fold to accommodate binding, type or select the amount of space you want in the Gutter box.
E. In the Sheets per booklet list, select the number of pages you want to include in a single booklet.
If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets.
F. Select any other options you want in the Page Setup dialog box.
G. Add text, graphics, headers or footers (header and footer: A header, which can consist of text or graphics, appears at the top of every page in a section. A footer appears at the bottom of every page. Headers and footers often contain page numbers, chapter titles, dates, and author names.), and other elements to your document as usual.
2. On the File menu, click Print.
3. Set options for printing on both sides of the paper.
If you're using a duplex printer (one that automatically prints on both sides of the paper)
Click Properties, and then set the options you want. If you have a choice of setting the page orientation and duplex options, select landscape orientation, and flip the document on the short edge or short side.
If you aren't using a duplex printer
In the Print dialog box, select the Manual duplex check box. Word will print all of the pages that appear on one side of the paper, and then prompt you to turn the stack over and feed the pages again.
4. Select the page range you want to print.
If you click Current page or Pages, Word prints the page you indicate, plus the three other pages that belong on the same sheet of paper.
If you click Selection, Word prints your selection using the default page layout instead of booklet layout.
Dec 25, 2008 | Computers & Internet
Printing booklets in Word 2007!!
Under file > print set up select two sided it will print bot the sided
Sep 09, 2008 | Microsoft Office Professional 2007 Full...
Word 2007 Booklet Graphics print on wrong page.
did you try to preview your work and see if its coming out on the page like you want before you print try that and see if it looks right before you do your work, I don't know if that will help you out but I hope so.
Dec 31, 2007 | HP Media Center m7060n PC Desktop
How do I print on both sides of my paper
On printers without a duplexer (a device that flips the paper to allow printing on both sides) you will have to print the first side, manually flip and print the second side. If you're using MS Word or MS Publisher you can easily configure the program to organize the pages for you: Start a new, blank document. -Click File, Page Setup then click the Margins tab. -In the Multiple pages section select Book fold. -Set your document to landscape orientation if it is not already. -In the Inside and Outside boxes, type or select the amount of space you want for your margins. -In the Sheets per booklet list select the number of pages you want to include in a single booklet. If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets. -When you get ready to print make sure you check the manual duplex box (should be in the first dialog box that appears when you click on File, Print). Word will print the first page, and then prompt you to take the pages that just printed and load them into the input tray of your printer. The trick is to learn how to orient the pages correctly for your printer. Good luck.
Jun 17, 2007 | HP DeskJet 1600C InkJet Printer
Adobe PageMaker Plus 6.5 for PC Logo
103 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
