Question about SVA-USA VR 17S 17" Flat Panel LCD Monitor
Monitor shuts down
My monitor will turn on fine and be usable for a couple of hours and then it gives me this message: no signal - analog signal out ...sleep... Nothing I do restores the monitor. I have shut the computer down and turned it back on and still get the same message. Ususally I can not get the monitor back up for several hours or until the next day. I have gone into settings > control panel > power manager and clicked everything to never go down but don't know what else to do. Why is it doing this? How can I fix it?
4 Suggested Answers
SOURCE: SVA Monitor stuck in Analog Mode or Sleep Mode
Actually it was quite easy. I rebooted my computer in "safe mode" by restarting it and pressing the F8 key. At the start up windows gives you an option to toggle down to "enable VGA mode" and select it. After that, my computer recognized my monitor and it has worked fine ever since!
Posted on Mar 13, 2008
SOURCE: Mac Mini changed screen resolution monitor giving error message..
may be ur monitor is not capable to support such a kind of resolution or may be u need to update the graphics driver. if the problem still persists then visit the mentioned link for a free diagnosis.
http://tinyurl.com/m7ghqz
Posted on Jun 18, 2009
SOURCE: my SVA Monitor just started
Unfortunately this isn't a solution but a request for one, as my monitor does the same thing. D: Anyone?
Posted on Oct 13, 2011
Hello, In the last couple of days my Sony TV (KDL32S3000) has been working fine for about 10 minutes then a message appears saying 'POWER WILL BE TURNED OFF BY AUTO SHUT OFF SOON' this message...
If this happening when TV is viewed then it is possible that the auto shut off is active as no signal is detected by the processor and so is instructing to shut down.
However this fault is related to a problem in the signal detection circuit, if this happens with the auxially circuit- play station- then some logic gate is faulty which needs to process and detect the signal.
Remove power for few hours and see if the fault resets, if not the circuit needs a technical review.
Jul 08, 2011 | Sony KDL-32S3000 32 in. LCD Television
Check signal cable
There is no problem. The monitor is telling you that it's not receiving a signal. The reason there is no signal is because your computer is turned off, so it's telling the truth. :D
The monitor should go into idle mode on its own, so you won't see that message for very long. It's annoying, but doesn't cause any real problems. You can save even more energy by shutting off your monitor entirely after you shut down your computer. This will make the message go away and also save money on your electricity bill!
Apr 23, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
I have s samsung monitor T220 and will not come to show that my computer is connected, I have a message on the screen that says check signal cable with the word digital at the bottom of the message box....
oh i had the same issue with T220, remove all ur memories , disconnect the monitor , remove the graphic card, clean it and instert it back , insert the memories and then connect the monitor to analog cabl;e first,,, put it on and then shut it down and then move back to digital sorce with the cable changed
Jan 11, 2010 | Computers & Internet
Mitsubishi HC900 Projector shuts down after 5 minutes.
You have 1 of 2 possible problems.
(1) You need a new lamp.
(2) You have an overheating problem.
Just a quick couple of notes about your projector. It is a DLP projector (not LCD) and as such the machine as no air filters to clean. It does have air intake and air exhaust grilles, but no air filters to clean. This next part comes directly from the owner' manual for your projector:
When the lamp operation time exceeds 2000 hours*1 *2, the projector automatically shuts off and can’t be used until the lamp is replaced and the lamp operation time is reset.
Your machine is designed to give visual warning messages at 1500 hours used, and 1900 hours used. Did you see any visual warning about lamp life over the past few months?
If you were experiencing an overheating problem, a "TEMPERATURE!!" message would flash up on the screen just before the unit shuts down. If there is no warning, you don't have a heat problem.
If you have a replacement lamp available, install it and reset the lmap hours according to your user manual. If you don't have the manual, google it on the web (it available).
Apr 01, 2009 | Mitsubishi HC900 Multimedia Projector
Monitor shuts off and on
I had the same problem, so I switched the Auto Source feature to "Manual" and so far it's working fine for the past 2 days, if I run into the problem again I'll update this message.
On the side panel of your monitor, press the top button to access the menu, scroll down to the setup menu (by pressing the 3rd button down on the panel), press the 4th button down to enter the setup menu, scroll down to "Auto Source", use the 4th button to select, "Auto" & "Manual" are your choices.. press the 2nd button down to select "Manual" then the top button to exit the menu(s).
This monitor is set up to be able to do multi display with the software included. Utilizing both Digital and Analog signals. I'm not using this feature so I'm not sure how switching the Auto Source off will affect the performance of this feature.
Dec 13, 2008 | E-Machines T6520 PC Desktop
LG 2542T goes dark after showing "analog power saving mode" message
Can you try the screen in another computer? I beleave the screen goes into power saveing mode when there is no input signal, thats what both my screens do.
Is your computer working?
May 16, 2008 | LG L1717S-BN 17" LCD Monitor
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Monitor has no picture
Yes! :)
Your monitor is not the problem. Check all the connections from the back of the monitor, to the computer.
"No Signal Analog" means your monitor is working perfectly, however is not receiving signal from the computer.
Didnt find any loose cables?
Try unplugging everything. Leave it unplugged for at least 5 minutes. You need to give the system time to drain all the excess power.
Again your monitor is fine, blue light > No signal > orange light is totally normal for your montior.
Oct 12, 2007 | ViewSonic VX922 19" Monitor Flat Panel
No digital signal but analog works fine
Seems like this was already answered? But once you've checked against the owner's manual and ruled out the PC, I would suspect the signal / video board inside the monitor. May have gotten a surge or static, etc.
Jan 11, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
SVA-USA VR 17S 17" Flat Panel LCD Monitor Logo
42 people viewed this question
Top SVA-USA Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a SVA-USA Computer and Internet Expert? Answer questions, earn points and help others
