Question about Transcend StoreJet Computers & Internet
The 2 GB Store n Go will not copy all the photos, it's almost like it is full. I am trying to put 316 photos on and it will only copy 170, then an error message "Error Copying File or Folder, Cannot copy 100_3999_p002_229 The directory or file cannot be created" If I go into Properties, the Used space is 44,859,392 bytes 42.7 MB and the Free Space is 1,976,500,224 1.83 GB What am I doing wrong? I am not very good on a computer so you will need to give me easy directions. Await your reply . .. Thanks Lyn Jagger
  • 1 more comment
  • ljagger Dec 22, 2008
    Hi Mark, yes 100_3999_p0002_229 is the name of a photo. It is not just this photo that it won't copy . . .its the remainder of the 316 . . .it would only copy 170. If I deleted a photo that it had copied (making some space, it would then accept one more photo that it previously wouldn't copy. I fiddled around with it for a few more hours and tried to copy one folder with 370 photos and it then accepted all of them. I'm thinking I must have all the photos in one folder and then it will accept them . . is this correct? If so, can I put a bunch more photos in another folder and copy the entire fold onto the same memory stick?
    Thanks
    Lyn J
  • Mark Robinson May 11, 2010
    no when you use windows copy and paste...it treats the copied data as one file if you like...then it hits a corrupt file or part of it and stops the whole process....so what you get is say you want to copy 500 photos and number 30 is corrupt...windows will only copy the first 29 and fail the rest.....but it might be that numbers 31 to 500 are fine.....so the trick here would be to try copying the next one in line until you know which ones are causing the problem.....I had to do this for a customer who had 30gigs of data....took about 2 days and a lot of hair pulling
    100_3999_p002_229 is this a name of a photo ? when windows comes across a file that is corrupt or it is denied access to then the copying procedure stops at that point....this doesn't mean that the rest can't be copied...try copying a directory at a time to see if you can pinpoint the corrupt file
  • Transcend Master
  • 17,448 Answers
First thing to do is run check disk on the computer to be sure that file is not corrupt. The file name may be too long or not recognized.
Posted on May 05, 2017
  • 40 Answers
SOURCE: error copying file or folder
You can always reformat it. If you plug the mp3 player into your computer and right click on the icon in the MY COMPUTER window, and click on FORMAT. It should come to a new window and click on start format. Your fixer, Wild2DMaxx
Posted on Jan 25, 2007
Beni S-P
  • 1006 Answers
SOURCE: Can't detect my HD properly
Possibilities:
1) One of your USB devices have faulted, or is causing a resource conflict (or similar)
-- Remove all USB devices, and reboot.
2) Your USB chip/ports have been damaged.
-- Find a spare HardDisk or bacjup your data and re-install Windows and see how that goes.
3) Your Power Supply Unit (PSU) isnt supplying enough power to your PC (usually caused by a Video card upgrade). Try a more powerful PSU ... 400watts should do the trick
4) Bad memory (RAM) can cause wierd problems. run memtest for an hour to make sure your memory is ok
It seems that many people are still getting the 'USB Device not Recognized' problem from time to time. Unfortunately there is no easy fix.
Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying .
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Hopefully some of this may be of help, let us know how you get on.
Posted on Oct 26, 2007
micromaster
  • 3614 Answers
One of the most important yet overlooked elements of PC maintenance is data backup. If you do not perform regular backups, chances are your productivity will eventually suffer from data losses or a failed Windows installation.
All versions of Windows after 3.1 ship with a free backup utility called Microsoft Backup. It is not the best backup program available, but it may be sufficient for your needs. (Backup is better in later versions of Windows. Microsoft recommends Win98/Me users purchase a third-party utility.) If you want more control over your backups, consider purchasing a third-party program.
Backup is part of the System Tools utility. However, Setup does not install it by default in Win98/Me/XP Home. If you cannot locate Backup, visit the Microsoft support site and query for article No. 152561 (Win98), No. 264541 (WinMe), or No. 302894 (WinXP Home).
In Win98/Me, click Start, select Programs, Accessories, System Tools, and click Backup. To create and run a backup, click the Create A New Backup Job radio button and click OK. Follow the prompts to create a full or partial backup. If you want to create a backup set and run it later or run an existing backup set, open Backup and click the Open An Existing Backup Job radio button and click OK. You can now access the main Backup dialog box.
In Win2000/XP, navigate to the System Tools utility and select Backup. Click the Backup Wizard button. If you do not see a Backup Wizard button, click the Welcome tab. In WinXP, the wizard will start automatically if you are in wizard mode. Follow the prompts to create your backup set.
When you reach the last dialog box, Completing The Backup Wizard, you can click the Advanced button to create a backup schedule (this option is not available in Win98/Me). When you reach the When To Back Up dialog box, select the Later radio button and click the Set Schedule button. Perform data backups on a schedule that is appropriate to the importance of your files (once a week is a common timeframe). You should also perform a system backup at least once a month.
If you do not want to use the wizard, or you are working with an existing backup, open Backup and click the Backup tab to access the main Backup dialog box.
Posted on Feb 11, 2008
Pattods
  • 116 Answers
SOURCE: how to format raw sandisk
Alright, plug the player in with your USB cable.
Open "My Computer" and find in on the list of drives and CD-Roms. It will be called something like "Audio Device" or "Removable Storage Device". Make sure you find the correctly icon for the player.
Right click the player then select the format option. You'll probably want to use a FAT32 format as it is the usual format for MP3 players and flash drives of the like. This will totally erase any files on the player, so be forewarned before you complete this.
Raw file system is basically the media in it's standard state. All the information is recorded as zero's and this is how your computer is seeing it. It is either reporting incorrectly due to bad file system error, or simple was formatted incorrectly.
Give that a try, let me know what happens. :) Hope it helps.
Posted on Sep 21, 2008
saqeb
  • 47 Answers
SOURCE: Transcend 16GB Pendrive - error while copying
If your drive is partitioned with FAT32 then it cannot copy larger files. You have to format it using NTFS.
Posted on Jan 28, 2009
What happen if 12 gb file is put on 8 gb flash drive?
From my (limited) experience, the flash drive will write the items within the file until it runs out of space, & then a warning message will be displayed. (E.g. a file/folder of photo's, will copy individual photo's till space is used up)
Jun 30, 2014 | Acer Aspire One PC Notebook
Verbatim 2 GB store n go says it has 918 MB of free space, but says 'disk is full' when I try to add files. I do not believe the store n go is partitioned. What gives?
If you can read the drive, Copy the information from it, into your computer, and format the drive, copy the files back, and it should work... also, if you have a security switch on the drive (write protection) you have to disable it.
Apr 14, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
What to do when it says internal memory full
Delete some pictures off you camera. It means that there is no more room on your memory.
Make sure to transfer them to a computer, before you delete them, as you wouldn't want to lose precious memories.
If you found this answer helpful, please rate it.
Mar 14, 2011 | Kodak EASYSHARE Z1485 IS Digital Camera
How can i send pictures from windows photo gallery to verbatim?
When you connect the SmartDisk into the USB port of your computer, the computer will detect this as an external storage device. When you open this SmartDisk you can create folders to store your photos. Just select your photos from your computer where the photos are stored then copy and paste these photos into the folders on the SmastDisk.
Sep 25, 2010 | Verbatim SmartDisk Firelite Portable USB...
I put my Scandisk SDHC 4 GB memory card in my Dell computer and put all my photos in folders straight in the card (I did not import them to computer first ) just after I put photos in folders I put them...
It is likely that the camera reads the FAT (File Allocation Table) of the card in a different way than the computer. Try re-formatting the card in the camera.
Aug 10, 2010 | Computers & Internet
8mb vs 8gb of space on an 8gb flash drive
sounds like you upgraded it to a dynamic volume and are using the leftover space, flash drives should be left as basic disks and formatted fat 32.
Mar 15, 2010 | Verbatim STORE-N-GO (95312) 8 GB Hard...
I can't store movies,photos or videos in my external hard drive
I returned the product to the store and got my money back.
I will never buy a WD product again.
Apr 11, 2009 | Western Digital My Book Essential Edition...
I am receiving the following message when I attempt to access my Western Digital My Book 500 GB: "Ox8007045D I/O Device error" I can see that my photos are still there but cannot open them or copy into the...
Happened to me too in both file backup and computer backup. I supposed MS will address in the future. For now, go to the system settings and unchecked the drives so they no longer create shadow copies . Apply the new settings to erase all existing shadow copies. Then reset by checking the boxes you unchecked. Now try to backup the whole computer again. It appears a shadow copy error is conflicting with the backup process. Once you delete all shadow copies (restore points) it will work.
Jan 05, 2009 | Western Digital My Book Essential Edition...
PNY 2GB SD Card will only hold approx. 350 photos
Depends on the size of each file ( picture). If your shooting a large formate then it could ( that's all you can get on it.
Jun 02, 2017 | PNY 2GB microSD Memory Card
Computers & Internet Logo
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
pankaj rautela
pankaj rautela
Alun Cox
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
