Question about SanDisk Sansa Fuze MP3 Player
To use a fm transmitter for an mp3 player R there any settings on
The mp3 player that needs to be set.
I bought an inexpensive transmitter and on the back of the package it tells you what 8 stations can be set. Out of 8 there is only 1 sation that barely works. When I do plug in everything and find the songs or proceed to tunr up the volume all you hear is a skipping rotating/thumping noise that eventually stops but by this time you are so frustrated you don't wnat ot bother with the mp3 player.
SOURCE: synchronize to continue your music subscription
hmm... well someone probably placed a subscription time on the songs you purchased. the only thing i could think to do would be to try and reload them to your mp3 player
Posted on Oct 17, 2007
mixmaster
  • 626 Answers
SOURCE: can't delete songs off my MP3 (sansa c250 2G)
You should format the device thru My Computer>Device Name (c250)>Right Click and select FORMAT.
Best of Luck.
Posted on Nov 07, 2007
SOURCE: Mp3 Songs are not visible.
Go to the menu in you mp3 player. In the menu, under settings, make sure that "advanced" is set to off. Then it should show that the USB is MSC, not MTP, and you should be able to view your songs when you hook back up to the computer.
Posted on Nov 27, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: Sansa Clip 2Gig skips... sometimes
download the Sansa Connect Recovery Tool from:
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
Posted on Feb 19, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: will not let me syncrhonize music to my e280r player
Your songs are in the wrong format - expired DRM license or expired music svc - convert them all to Mp3 format and you will be fine
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
Connecting mp3 car radio
If you radio has an Aux input then you can connect a audio cable from your MP3 player to the Aux input on your radio.
If your radio does not have an Aux input the you can use a FM transmitter device. Connect the MP3 player to the FM transmitter and tune your FM radio to the radio frequency on this FM adapter to listen to your audio book on your MP3 player.
Check out these WEB sites fro FM transmitters.
http://dx.com/c/car-accessories-799/car-audio-systems-707/fm-transmitters-players-710
http://www.amazon.com/Coby-CA-745-Wireless-Transmitter-Cigarette/dp/B000OTF6G0
http://www.popularmechanics.com/technology/how-to/gadgets/4307160
Feb 05, 2013 | Audio Players & Recorders
IS THERE A WAY I CAN PLAY IT IN MY CAR IN THE RADIO
Yes, You will need to purchase a device called an FM transmitter, it plugs into the headphone jack and transmits the sound to your FM radio. The transmitter will have station settings, you just find a radio frequency that does not have a station in your area, set the transmitter to that and tune your radio to the same frequency. You can get the transmitters from Walmart electronics dept, Target, Sears, Amazon.com, Radio Shack and most other electronics retailers. The transmitters run about $12-20 and can be battery powered or plug into your car power outlet. Go to google.com and do a search for "MP3 FM transmitter" and you will see what they look like.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 26, 2010 | iRiver E100 Digital Media Player
Accessories for SMPK8854B mp3 touch
Buy yourself an FM transmitter. This plugs into the cigarette lighter and the MP3 player. You set an FM station on the transmitter. Place your radio on that station, if you have your player on you will hear music. You may need to adjust the volume. The easiest way is to turn the volume all the way up on the player. (Just remember to turn it down before you listen again with headphones.) This should solve your problem.
Jun 18, 2009 | Sylvania SMPK8854 Digital Media Player
I need to know how to turn it on...i don't know if its broken or what...cuz i put in new batteries and it won't trun on
1. Open the battery cover on your TuneCast II Mobile FM Transmitter. Install the included AAA batteries and
replace the battery cover.
2. Plug the 3.5mm connector into your iPod player or other portable music device.
3. The AUTO ON feature will power on the FM Transmitter when the unit detects an input signal. Your FM
Transmitter’s “AUTO ON/OFF” feature uses your audio player’s volume level to automatically power on and
off.
For best results, keep your player set at a medium volume level. NOTE: Setting your device volume very
low may cause the FM Transmitter to turn off, even if the audio player is on.
You can also press and hold
both and buttons simultaneously for two seconds to turn on the unit. To turn off the unit, press
and hold both buttons simultaneously again for two seconds.
Mar 03, 2009 | Belkin TuneCast II FM Transmitter
Technika fm in car transmitter
Tune in the transmitter to one of your car wireless stations - switch on - play MP3 player and it should work
Hope it works
Tony
Jul 11, 2008 | Pyle iPod Car Stereo FM Transmitter w/LCD...
Just bought a new Philips MP3 Player Model SA3025/37 and was wondering if I can use it in my car?
You can use any MP3 player in your car by connecting to an FM transmitter.
Look for FM transmitters on E-Bay.
They are powered by either battery, or cigarette lighter adaptor.
They plug into the headphone socket of the MP3 and convert the output into an FM signal, which you can tune your car radio into.
Jun 07, 2008 | Philips Audio Players & Recorders
Belkin TuneCast FM transmitter for samsung t9
I just bought this transmitter and i plugged it into the car and my samsung mp3 player and it will charge the player but you cant hear any music even when i tune it to a vacant radio station.
May 20, 2008 | Belkin TuneCast Auto FM Transmitter for...
Bekin tunecast 3 set up advice
Check to see that the actual radio frequency and the belkin frequency are the same...
Apr 14, 2008 | Belkin TuneBase
SanDisk Sansa Fuze MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
