Question about Adobe Computers & Internet
Mouse hang so often
Sometimes while working mouse hang on and to work again with it either have to restart the computer or sometimes even after restart it does not work. I found that by unpluging the mouse cable and plugging again we can continue work without restarting the computer but last days it hang over about 20 times during a time span of 2-3 hours and i really got panic by this. Is there any solution to get rid of continuous hanging of mouse?
  • Sean Cole
    Sean Cole May 11, 2010
    What machine are you running it on, how much memory does it have and what other software is running at the same time (including background tasks such as antivirus, email, etc)?
    All the best
    Sean
    PiDigital.co.uk
ImWireless
  • 113 Answers
SOURCE: Mouse stops responding randomly
The issue may not necessarily be with the mouse. Are you able to use the keyboard once the mouse freezes? If you not even able to use the keyboard, there is some application installed on your computer or a virus due to which the mouse freezes. If, in case, the keyboard works even though the mouse is stuck, try changing the USB port or try a different mouse. Please revert back with any other observations. Good Luck
Posted on Mar 30, 2007
  • 51 Answers
SOURCE: Mouse stops working time to time
I would get a new mouse. Sounds like there is an issue with the usb connector.
Posted on Aug 18, 2007
SOURCE: Sometimes my computer restarts suddenly.
this problem is due overheating, and you say yo have a C2D with this mobo.... at intel site it said that this mobo works fine with intel P4, Pentium Duo an Celeron but not C2D. Its true that you have 800Mhz FSB and it will detect the micropro.... and work fine but the C2D will overheat the mobo for its need of energy and overheat it so it start restarting. I dont know how much that mobo is going to last but start installing all cooler you can....the mission is to cool down that mobo and micro...
Posted on Jan 02, 2009
SOURCE: Pocket mouse "hangs up" when I stop moving. Starts again if I cli
Had nothing to do with the reinstall of XP. Just put in new batteries. Guess it was just a coincidence that the batteries went dead (low) at the time I redid XP.
Posted on Jan 11, 2009
tunmun
  • 413 Answers
SOURCE: computer never continue to start up, it just
run it in safemode with networking and install safemsi.exe and then run malawarebytes which is free to download ,update it and run this will fix the problem
Posted on May 08, 2009
All of a sudden my system will hang with nothing function... not even ctrl+alt+del... mouse is also not working... since having no idea, I have to restart it again and again... This will happen...
This sounds more like a hard drive problem than motherboard. Try this FREE program called Mydefrag click the link. This program works different than the std. windows version. It can move files from a dead spot on the HD to a healthy spot and prolong the loss of your stuff. I would suggest you start moving files to another HD keep things you want or need. Hope this helps FixYA up.
Aug 13, 2011 | Intel D845GVSR Motherboard
My mouse keeps shutting down right in the middle of my work on the computer. I have to unplug it and plug it back in time and again...I'm frustrated. can you help me????
Replace your mouse... it's symptomatic of it being faulty. If it is USB, though, sometimes plugging things in & out can cause the USB bus to Hang.
Feb 05, 2010 | Logitech 9311570403 Mouse
Mouse will not click buttons / Task manager allows mouse to work
remove the mouse and plug it again. go in setting of mouse control the speed and all if the same the test the mouse in different pc. if that time also same then your mouse not good. buy a new 1 or put it in a service center.
Jan 29, 2010 | Computers & Internet
I have the same problem
check to see if the CPU is connected to ur motherboard securly and check RAM aswell.
Jun 06, 2009 | Intel D845GVSR Motherboard
Frozen mouse with a touch pad laptop computer
Check your drivers. Go into the device manager (start>control panel>system>hardware>device manager>human interface device) . If it shows a big yellow question mark, than it is a driver problem.
I would suggest that you either install or download the latest drivers for the mouse, and you can do this even without checking for a hardware conflict as stated above.
You can also access the control panel and trouble shoot your mouse through the mouse icon.
Even sometimes this may not work.....
I had an IBM brand optical mouse that continually plague me with problems until I gave it away with a computer that I built. The person who has it is still have occasionally issues with the mouse even with the proper drivers installed. I believe that it is a connection issue because sometimes the mouse will start working when you jiggle the male USB connection.
Oct 14, 2008 | HP Pavilion Media Center a1330n - AMD...
Mouse hangs
The wire of your mouse have a problem, sometimes it work when you are to restart your computer and sometimes it doest work properly. So, if you like to used your mouse, you can changed the wire of your mouse or replaced new one.
Jun 26, 2008 | Computers & Internet
Hp a305w Pavilion No Mouse or Keyboard at first bootup
i would reset your keyboard and mouse settings to default then shut down pc.. unplug components and wait for 3o secs and then try again.. if the problem persists, you may just have some loose connections especially if your pc is older..make sure there is enough slack for your mouse and keyboard wire to move around.. i know sometimes we can ruin them if we have then stretched to far out.. hope this helps.. d
Feb 22, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Compaq presario S5300NX Mouse not working
Bill check the cables in back make sure its tightly plugged in. also restart your computer.
Feb 15, 2008 | Compaq Presario 5000 PC Desktop
Mar 30, 2007 | Logitech Optical Wheel Mouse M-BT58...
Computers & Internet Logo
57 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
