Question about Toshiba Satellite A105 Notebook
A105-S1014 LCD Screen issue
I have a A105-S1014 that I've had almost 3 years. About two months ago, I noticed that I was getting lines and a blurry screen. I would tap on the top of the screen and it would clear up. About two weeks ago, the screen would start to freeze. I would have to tap it harder, and then it would come back for a little while and then do it again. I wasn't sure what was going on with it, so I assumed the screen was going bad. I got one on Ebay and replaced it, only to find the new screen didn't fix it. If I put my fingers about 3 finger-tips on each side of center, and push in, and pull on the screen with the other fingers, it clears right up. When I talked to someone, they said it might be the LCD inverter, however the screen is bright no matter whether it works or not. Could I have a short in the ribbon LCD cable that goes to the LCD screen? Any other ideas?
  • evanejp1980 Dec 20, 2008
    The screen was new. I am fairly certain it is not the screen(s), because I've tried them both and found them both to do the exact same thing. But yes, if I tilt the cover/screen a bit it appears to reload easily. If it was a screen problem, why would the screen just fade from whatever it was doing and stick on it for a bit. When I would "squeeze" the screen like I mentioned above, it would come back to life. Kinda weird situation with this computer.
  • JDTec
    JDTec May 11, 2010
    Strange that the new LCD did not fix your problem. The symptoms that you describe are those of a bad LCD screen. A loose cable may be
    causing the problem, but not likely. A loose cable would show when you lift the cover and the video only appears when you have the cover open at a certain angle.
    Check if the cable going into the back of the LCD screen is pushed all the way tinto the connector.
    You are correct when you say that it is not the inverter. Inverters would make the video dim. It would not cause these symptoms. Was the LCD screen that you bought new ?
    Problem Solver:
  • 6 Answers
The LCD inverter maybe going bad and i would check for a lose wire or the lcd cable may have a brake and when you pull or tap it moves
Posted on Dec 20, 2008
  • Aaron Wagers
    Aaron Wagers Dec 21, 2008
    i had a dell with a bad ribbon to the LCD screen i hooked up a desktop monitor to it and used it for a while to see if the inverter was bad and it worked fine so i opened it and found that the LCD ribbon had a brake in it from opening the screen to far back i got the laptop that way from a friend that did not take care of it after i fixed the ribbon it worked fine
I bought an LCD Samsung 3 years ago and about a year ago a thick black line appeared in the middle of the screen. Can this be fixed at home?
check if the lines appear on different inputs or source like hdmi,av,pc, if it happens on a different source then theres a problem with the lcd screen it needs to be fix.
Dec 26, 2014 | Samsung Televison & Video
LG LCD picture blurry/polarized
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 18, 2017 | LG 42LC2D 42 in. LCD HDTV
Black Screen on Toshiba Satellite A105 S1014
Blown or damaged graphics chip on motherboard, would take to specialist repair shop
Feb 09, 2010 | Computers & Internet
Toshiba Satellite a105 s4004
Here, I found this:
Toshiba Satellite A105. How to remove and replace laptop FL inverter and LCD screen.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
Jun 23, 2009 | Toshiba Satellite A105 Notebook
Vertical lines on the laptop screen
hi, the fault could be cause by a number of things, the Lcd harness cable maybe loose or faulty or even a mainboard issue, but it sounds like the matrix (circuitry)of the LCD is on it's way out.
Feb 28, 2009 | Compaq Presario M2000 Notebook
Toshiba satellite a105-s1014
try the computer with an external monitor, if it works correctly then it's the monitor that has broke and you need it replaced.
otherwise, if it does the same things on the external monitor...
I would check in order:
1)RAM memory
2)Motherboard
if the problem is only after windows boot, try changing the video driver, the problem might be caused by overheating video Chip, but that should freeze the system too...try also to remove the dust from all the heatsinks with canned air...
Jan 18, 2009 | Toshiba Satellite A105 Notebook
Vertical lines on my 40 inch lcd mitsubishi hdtv 1080
Similar problem with an eleven and a half month old LT-40148. Approx. 1 inch vertical banding line on left side of screen on all inputs. After about two weeks, same problem on the right side of the screen.
Fortunately this occurred two weeks prior to the one year warranty expiring.
Called Mits customer service and they referred me to an authorized service center who I happened to have dealt with before.
They picked up the set. The front panel (LCD screen ) had to be replaced. Set was gone for two weeks as parts were not in stock. There was no charge. I hope this screen last more than a year.
Jan 16, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
Toshiba satellite a105 screen problem
You need a new lcd, The connectors are bad...
Dec 13, 2008 | Toshiba Satellite A105 Notebook
Display problem with Samsung 40'' LCD.
This is usually an issue with the TCP (Tape Carrier Package) on the LCD panel prying loose. You need to wedge something on top of the TCP in the problem area that will apply pressure (rubber or foam. That will do away with the lines.
Nov 14, 2008 | Samsung LN-R408D 40 in. LCD HDTV
Toshiba Satellite A105 Notebook Logo
164 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
