Question about Panasonic CQ-RX400U Car CD/ MP3 Player
Technics J201 Wiring
Just got a Technics J201 car cassette at a used stuff shop and need to know the wiring configuration of the harness connector at the back so I can soder wires to it rather then buy a harness. I could be being really cheap and may just go buy the connector, but want to do this as inexpensivly as possibly. The head unit cost $4 and may not even work.
brandonboyce
  • 84 Answers
SOURCE: how to install a panasoinc cq-df903u in 91 integra
The wires for the two harnesses should be color coordinated or at least closely colored. The harness should have come with either a guide that says what is what or the wires themselves have little flags saying what they are. You can use this to match it up with CD Players wires by using the manual from the CD player to know which wire is what.
Posted on Jun 27, 2007
  • 146 Answers
SOURCE: Whining noise @ acceleration?
You have a bad ground somewhere. You also may nneed to replace your spark plug wires. The deck is getting interference from the engine due to a grounding problem.
Best of luck
Posted on Jan 30, 2009
  • 55 Answers
SOURCE: Which colors go where in the power cord?
You Really only Have
* RED....POWER + 12 VOLTS USE VOLT METER OR 12 VOLT TEST SHOULD ONLY HAVE POWER WHEN THE KEY IS TURNED ON.
* YELLOW......ALWAYS HAS +12 VOLTS
*BLACK........GROUNDS
* THE SPEAKER WIRES WILL WILL HAVE 2 WIRES OF THE SAME COLOR (EXAMPLE) GREEN AND THE OTHER WILL BE GREEN WITH BLACK LINE ON IT .YOU WILL HAVE 4 SETS OF THESE .IF THIS IS TO MUCH FOR YOU.. PICK UP THE REPAIR BOOK FOR THAT CAR IT WILL HAVE THE CONN.PIN OUTS. GOOD LUCK.
Posted on Feb 20, 2009
  • 124 Answers
SOURCE: Not for sure which is the hot and which is the ground wire.
Solid black is always ground on aftermarket head units. Red is usually the ignition wire, ie when you turn your car on, your stereo turns on. Hot or positive is usually yellow and usually the biggest wire
Posted on Mar 21, 2009
saailer
  • 1871 Answers
SOURCE: Have a wiring harness for a CQ-C8100U panasonic CD
Hello! Since I do not know if your vehicle is equipped with the Standard or Premium System I'll give both sets of wiring...You can identify which system you have by looking at the color of the ground wire...
Red=Standard and Black/Green =Premium
Standard...Constant +12=Green/Yellow...
Switched=Yellow/Black...Ground=Red...
Illumination=Blue/Red...
Standard Speaker
FR + White
FR - Green/Orange
FL + Orange/Green
FL - Light Blue/White
RR + Orange/Red
RR - Black/White
RL + Pink/Green
RL - Pink/Blue
Premium...Only power difference is Ground=Black/Green
Premium Speaker
FR+ White/Red
FR- Brown
FL+ Green
FL- White/Orange
RR+ Purple/White
RR- Blue
RL+ Blue/Black
RL- Yellow
Guru.....saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Posted on Feb 18, 2010
Wiring diagram for a toe bar
that will take some major rewiring, no?
front toebar. wiring. to tower hitch.
first off we dont know what is towing car, nor its hitch wiring
but in most cases, you may need and adaptor, to convert simple
USA wiring to Euro type wiring.
there are 2 systems. that cant just be wired in willy nilly.
is this permanent? one tow , only
or for ever. we cant guess that.
if 1 tow ,why not use clamp on aux light bar and get it done
rent them at u-haul?
if perm, is need , get a pro shop to do this.
how to do this and not damage the cars , electronics that controls
lights can be very tricky.
the safest way is to have new connector installed to rear lights.
to the main harness, then you unplug the cars harness side
and then connect the tow bar new custom harness connector to the rear.
none of this is easy or simple.
tell more get more.
Sep 12, 2014 | Suzuki SX4 Cars & Trucks
Can someone plz help me and tell me what all the loose wires are in the trunk and wat are all just the speaker stuff in the trunk? theres a few wires and connectors tht are not plugged into anything? y is...
the spare wiring is because the manufacture will use a wiring harness for the same model for differant specifications and leave the unused connectors thats not needed to install the upgrade system you have got the wiring there but you may need a power amplifier more speakers and not knowing what model stype you have you may have to have the audio head unit reprogrammed
Nov 22, 2017 | 2000 Jaguar S-Type
Car-stereo wiring diagram TOYOTA Tarago 1986
any local car stereo shop can sell you an adapter harness for $10-$15. This is a much cleaner and better way to go than cutting your factory harness.
Mar 14, 2010 | Car Audio & Video
I have a 2004 Hyundai Elantra and am trying to install a stereo but dont know what the wiring diagram is..any help?
Personally owning this car and installing several Hyundai stereo's, I would purchase a wiring harness kit from car audio shop or electronics retailer. The wire harness has a plug that connects to the cars wiring harness. This wiring harness kit will also list the wires to connect your new aftermarket radio to the harness. I would also recommend using crimped **** connectors to attach the two harnesses together.
Feb 24, 2010 | 2004 Hyundai Elantra
I want to install am/fm cd cassette player into my honda odyssey lx model,by removing the casste player ,harness connectors are same
No the wiring harness are not the same, if your factory radio is standar audio system this is the part # Metra 70-1721
Jan 07, 2010 | Buck Honda Odyssey 2004 Car Stereo/radio...
The connector does not match the wiring harness connector for car
you can buy wiring harness adaptor from any car audio shop or try Ebay.
Dec 04, 2009 | XO Vision XO1915BT Car DVD Player
Need how to connect cd changer
I think the factory used one wiring harness for all the radio's, on a low cost radio you just plugged in the connectors needed for the radio setup in the vehicle and the rest of the connectors are just laid aside. You can't just buy a radio harness, you buy the entire wiring harness for the cab, in any event check this out on the harness and see if the connectors are their.
Dec 02, 2017 | Car Audio & Video
Need to know what connectors to buy to install my pioneer audio?
You can usually purchase a wiring harness for your vehicle to ease the connection to factory wiring. Two examples would be here:
Toyota Into Car Harness
Toyota Into Radio Harness
Feb 01, 2009 | Pioneer DEH-P3000IB Connect an iPod nano...
Panasonic CQ-RX400U Car CD/ MP3 Player Logo
91 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
