Question about Sony PlayStation Portable (PSP) Console
The green light wont show and it wont turn on
I pressed the home button and went out in the middle of the game and then i was listen to mucis so i made the screen black and then made it hold. after when i was tryin to change the mucis the sreen wont show and i had the hold thin off and so i toke off the battery and put it back on and tryed it again but this time the green light and the screen wont turn on
idkia_33
  • 70 Answers
SOURCE: Keeps going to quit screen
it could be that someone pushed the button in too hard and it wont pop back up because even if you lightly touch it, it could go to that screen
Posted on Jan 21, 2008
gamerfixer07
  • 344 Answers
SOURCE: ps3's green light turns on usually screen stay's black
Call Sony so they can fix it. This sounds like multiple problems. Good luck.
Posted on Jul 03, 2008
SOURCE: game stuck/blinking red light
i was playing mw2 yesterday and bam (red light of death) ill prob have to send it to sony but i got the game out follow these steps. 1. turn off at the back. 2. hold your finger on the eject button. 3. turn on again at the back while holding the eject button for a few seconds 4.your playstation should start up and your game should be ejected
Posted on Nov 14, 2009
SOURCE: My PSP screen turns black when i press
this happened to mine it got a bit of moisture in it and pressing home made the screen go black.
i opened it up and pulled the strip out that connects the buttons to the circuit board , cleaned the connections and it worked
Posted on Mar 08, 2010
  • 1139 Answers
SOURCE: My PlayStation 3 turned off
Unfortunately what you are describing is known as the Yellow Light of Death (YLOD). This indicates a general hardware failure normally due to overheating. When these PS3's were produced Sony decided to use lead free solder. The problem with lead free solder is that it is not as flexible as leaded solder but it is cheaper and more environmentally friendly. When the console gets hot and cools down hairline cracks appear within these solder joints and a good electrical contact cannot be made. This then causes the console to fail. It could be on a number of different components including the CPU, GPU or memory. There is a temporary cure that may or may not work but ultimately the console will need to be repaired professionally or replaced. If it is out of warranty Sony will not replace it but will offer a refurbished unit for around £130. If you look on Youtube for Yellow light of death fix there is a way that you can re-heat the solder joints using a heat gun but if you are not confident taking apart electrical items then this really may not be something you want to try.
I am sorry I cant give you any better news but unfortunately it is a very common problem with the PS3
Hope this helps and thank you for using FixYa
Posted on Oct 30, 2010
Testimonial: "Unfortunatley, that's not what I wanted to hear, but your advice seems to be very educated and helpful. So thanks a lot!"
Why wont my ps3 turn on
The problem might have to do with a power thing maybe the power switch i mean maybe the power at your home went down and that causes the PS3 to basically be unusable, what i would recomend is to go and make a diagnostic to your playstation, im not sure where but im sure that if you google it you might find cheap places to see whats wrong with your ps3Good luck!! :D
Nov 29, 2011 | Sony Playstation 3 (PS3) Console
Board wont calibrate
ifif your talking about the Wii and the balance board wont calabrate, you need to sync the balance board to the Wii by removing the battery lid and pressing the sync button. The board power button lights should blink for about 20 seconds. At this time, you open up the SD card lid on the council and press the sync button on there. The board will stop blinking when it is synced. After this, insert a video game that requires a balance board. You go to "controls" on the main menu and set it to Wii balance board mode. after this you press "ok" and it should tell you which way to set the board. After this, you go to Wii home by pressing the button that looks like a house in the middle of the remote. Then, you hold down the power button on the board and wait until player 4 shows life. (player 4 is the board.) The board should work now.
Jan 09, 2011 | Video Game Consoles & Games
I can't Connect it to my Playstation3 with Bluetooth .. If i start scanning, The headset woudn't show on the Screen. Please help
To enter pairing mode the turn the headset off. Then start holding the middle button again till the headset turns one (green light + tone), but keep on pressing it till it starts to flash alternating red and green. The PS3 should be able to pick it up withing seconds. My **** manual specifically said that the headset should be off. Which is not true.
Apr 05, 2010 | Logitech Cordless Vantage Headset for...
My playstation2 wont turn on the red button is on. anyone have some feedback on this issure
You need to press the red button to get the system to turn on. It should show a green light. There will be a blue light next to the green light if you also have a game inside.
Feb 10, 2010 | Sony PlayStation 2 (PS2) Console
My xbox 360 and wireless controller will sync but then it wont show that they are connected and even though i turned on my console by using the button on the console it just shows the green light turn on...
To connect the controller to your Xbox 360 console, follow these steps:
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that your Xbox 360 console2_bing.gif is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console2_bing.gif.
  3. On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. After the Ring2_bing.gif of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Aug 15, 2009 | Microsoft Xbox 360 Console
My psp wont turn on ,but the green light stays on for a couple of
firmware could have crashed. welcome to a 150$ paper weight. sorry.
computers can run into the same issue if a bios update fails or corrupts.
sony might be willing to fix it.. maby.. or game stop might buy it off of you.
Aug 06, 2009 | Video Game Consoles & Games
Ps3 controller won't turn on
cut the game on press the middle button then give me yur number my yahoo.com is andreparker72@yahoo.com
Jul 14, 2009 | Sony Playstation 3 (PS3) Console
Wont boot fully boot up.
Try reseting your PS3. Turn your PS3 completely off by the switch in the back. Then flip the switch back on. Press on the power button and hold it until the green light comes on, beeps twice then the green light should go out, replaced by a red light. Then turn it on normally.
Nov 21, 2008 | Sony Playstation 3 (PS3) Console
Sony PlayStation Portable (PSP) Console Logo
134 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
