Question about Hoover 9.9 cu. ft. / 280 liter Upright Freezer HVA280K
Hi i have a Hoover Hnu241Aff 80 and need a new instruction manual
I have a new freezer but dont know how to set it up and how to use the super freeze button. I bought it cheap as it was only going in my garage as my second freezer had died and when it was delivered it didnt have a manual.
On second thought its probably not such a great idea to get one without a manual as i'm not sure how to use it! any help would be appreciated
thank you
    Top Expert:
  • Hoover Master
  • 57,204 Answers
Try a search thru google Google
Posted on Aug 10, 2017
Hi we have a norfrost chest freezer it is freezing everything but bread on superfreeze when we take it off of superfreeze it defrosted the bread
sounds like the thermostat is at fault or more than likely the refridgerant gas has partially escaped due to a leak, check te seals on the doors first. hope this helps.
Oct 09, 2016 | Freezers
Re lights lit on freezer
Red light lit on freezer means that is not reaches operating temperature.
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees
- orange light : pressing the so-called SUPER-switch which means that the compressor is running continuously. The SUPER-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
Dado
Sep 02, 2014 | Electrolux Freezers
I need the owners manual for the estate chest freezer model no. tcf1510ew00, or if someone could just tell me the temp settings for each number? it shows on the side that 4 is i guess the freezing point...
The numbers are generic and don't mean a thing. They are there to make you feel like you have control. Anything under 1 should be very much frozen. If it is not then you have T-stat problem and should address that. Chest freezers run at -25f on average if the freezer has enough product in it. The more food in the freezer the better and more efficiently it will run.
Apr 10, 2014 | Whirlpool 10 cu. ft. Chest Freezer...
I just bought a used (but never installed) wf 1061 (freezer with a wine fridge). the unit and dsidplay lights up as normal...but i don't hear the compressor starting...can it be in demo mode?...
Try this also:
Super freeze 5 seconds set desired temp press super frees briefly again then adjust the wine cooler temp press super freeze again briefly, Next press menu and select normal. Then press menu again. To exit press super freeze again until it no longer blinks.
Kelly
Aug 28, 2011 | Freezers
Alarm has stopped working on hotpoint freezer fzs175g I have reset as per instructions but there is no light and no sound
We had a problem with ours, try setting the temp dial to off and then hold the super freez button for 5 secs, you should hear a bleep and hopefully all should be well.
Nov 27, 2010 | Hotpoint Freezers
My chest freezer does not freeze over 80% of the case.it only freezes a small seccion of the upper part of the case.
This one sounds just like a refrigeration problem.
If the freon leaked out then it will definitely do this...
I would recommend to get a new freezer here's why.
if you call someone to put the freon back in it will cost you anywhere from $80 to $150. it will freeze and work good but eventually it will go back to the same problem because the tech did not fix it only put it back in... its just a matter of time then you have the same problem... save your money and move it to a new one...
hope this was helpful
Mar 06, 2010 | Whirlpool 14.8 cu. ft. Chest Freezer...
Bottom 2 shelves not freezing
if it does not freeze it is because the refrigeration system is low on freon. this will cause the bottom shelfs to not freeze...
you have to decide if it is worth putting the freon back in (they wont fix it because very hard to find)
so you could spend anywhere from $80 to $150 to get the freon back in... then after a while it will leaks out and you will have the same problem
why dont you instead move that money to a new freezer
Mar 04, 2010 | Freezers
My freezer is freezing at the bottom but is not at
Short on refrigerant would be a good starting point, pressure temp relationship should be tested by an opperative.
Jun 27, 2009 | Hoover 9.9 cu. ft. / 280 liter Upright...
Weve lost the instruction manual for our Hotpoint Fridge-Freezer
Sorry, no secret. The fan wasnt working so we called an engineer who bypassed a sensor. Now it works perfectly again.
Mar 22, 2009 | Bosch Freezers
Hoover 9.9 cu. ft. / 280 liter Upright Freezer HVA280K Logo
219 people viewed this question
Top Hoover Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Hoover Freezer Expert? Answer questions, earn points and help others
