Question about Toshiba E-STUDIO 650 Copier
What is error code f105 for an toshiba e-studio 520 copier?
Can someone tell me what this error code is and how to clear it?
  • 3 more comments
  • re_services Dec 20, 2008
    Morning! When I boot up the copier... it states to call the local servicing company/their phone number and on the right side of the screen it shows F105????? I don't have the money to pay that company to come out and fix this... I don't think there is anything wrong with the copier as it has only 45k copies. I did think that the sorter lagged a few times upon boot up so there might be an issue with that?
  • re_services Dec 21, 2008
    Thank you very much! Is replacing the hard drives on these Toshiba copiers easy? I was hoping that it was an easy “plug and play” type of replacement. I’m handy and have basic computer knowledge…. Would your suggestion be to hire a professional or is this something that a laymen could handle. Happy Holidays back to you!
    OK..... I'll go work on that when I get a chance and let you know if I need help or what happens!
  • Everett Lin May 11, 2010
    Dear sir; The error code you submit that is invalid we can not find in service manual, please verify and submit again, thank you.
    President:
  • Toshiba Master
  • 990 Answers
Dear sir; There have your solution, try to turn power off and on, if can not reset , you have to replace HARD DRIVE, f105 is hard drive problem. good luck! if you need more help please let me know, HAVE A HAPPY HOLIDAY !!!
Posted on Dec 20, 2008
  • Everett Lin Dec 21, 2008
    SIR; If you have a basic computer knowledge, I'm pretty sure you can make it, just go for it, I am here back you up,OK! DON'T FORGET GIVE ME A GOOD RATE ! Thank you.
  • Omar Gourti
    Omar Gourti Aug 10, 2014
    keep the machine off , keep 0 and 8 pressed then click start , then enter 690 and click enter , you will see 2 2 , then wait till they ask you to rboot , so restart the machine and the problem is solved
How to clear error code
Fuser error...
Clear the message... 08-400 "0"
If occur again, u need to check the fuser probable, such as themistor, IH board, connectors and etc...
Apr 05, 2012 | Toshiba COPIERS E-STUDIO 520 Copier
F105 On e-studio 520 Toshiba I know its the hard drive. Can it be saved???
Perform the bad sector check (08-694) takes about 20 minutes. If ok, recover the data if the results fail..you know replace HDD. Hope its not system board but that would be next if the HDD is good. Hope this helps.
Jun 25, 2011 | Toshiba COPIERS E-STUDIO 520 Copier
Error F105
[F105] HDD other error
(1) Check if the connectors of the HDD are disconnected.
(2) Check if the connector pins are disconnected or the wires of harnesses are open circuited.
(3) Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If
the check result is failed, replace the HDD.
(4) Replace the SYS board.
Oct 22, 2010 | Toshiba E-Studio 3511 Color Copier
Error c477
There is no C477 call for service on an e-Studio 520. If it is in that range however, it will likely be a fuser error. You can try going into (08) mode by holding 0 and 8 while turning on the copier. Once the copier starts up key in 400 and press start, input "0" and press interrupt. Try rebooting the copier, if this doesn't clear that call for service then you are going to need to get work done on your fuser.
Aug 24, 2010 | Toshiba COPIERS E-STUDIO 520 Copier
E-STUDIO 720 Copier Gives me a error F105. What should i do? thanks
Hi:
You are having a Hard Drive issue. You should call in a qualified Toshiba tech at this point.
Andrew
Jun 14, 2010 | Toshiba E-STUDIO 720 Copier
Error - Service Recomended SPC
The message can be reset. 08-800 set to "0"
Feb 17, 2010 | Toshiba COPIERS E-STUDIO 520 Copier
Error code F105 studio 450
F105 indicates HDD other error
Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If the check result is failed, replace the HDD.
Sep 17, 2009 | Toshiba e-Studio 350 Copier
Hard Drive error No. F105
F105 is "other HDD error" . Start the copier holding 0 and 8, it goes in a test mode, then punch 690 and presss start key. Restart the copier. If does not work you might have to replace the HDD and reinstall the firmware. Let me know.
Dec 30, 2007 | Toshiba e-Studio 350 Copier
E-studio 520 copier Jamming
Where is it jamming at and what code is it giving.  Press the clear and -8- buttons at the same time to see code on screen.
Oct 19, 2007 | Toshiba COPIERS E-STUDIO 520 Copier
1,702 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Timothy Van Der...
Adorjani Laszlo
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
