Question about SVA-USA VR 17S 17" Flat Panel LCD Monitor
Monitor shuts off...
My monitor will turn on fine and be usable for a couple of hours and then it gives me this message: no signal - analog signal out ...sleep... Nothing I do restores the monitor. I have shut the computer down and turned it back on and still get the same message. Ususally I can not get the monitor back up for several hours or until the next day. I have gone into settings > control panel > power manager and clicked everything to never go down but don't know what else to do. Why is it doing this? How can I fix it?
4 Suggested Answers
SOURCE: Mac Mini changed screen resolution monitor giving error message..
may be ur monitor is not capable to support such a kind of resolution or may be u need to update the graphics driver. if the problem still persists then visit the mentioned link for a free diagnosis.
http://tinyurl.com/m7ghqz
Posted on Jun 18, 2009
SOURCE: SVA Monitor stuck in Analog Mode or Sleep Mode
I had the same problem and called my brother who builds computers.  Here is what worked for me and makes perfect sense.  Also make sure that you set your computer to never go on sleep mode.
Plug in a different monitor so that you can set your computer display in this way:
The Screen disollution properties should be set to 1024X768 Make sure the setting is 16 Bit.  Now also set your refresh rate for 60hz(No higher)
Shut down your computer.  Plug in your flat screen monitor and restart your computer.
There is no reason to go find drivers because these monitors use the plug and play from windows.
It worked perfect after that.
Hope this helps everyone because it was simple and makes sense..
Posted on Jul 19, 2009
SOURCE: my SVA Monitor just started
Unfortunately this isn't a solution but a request for one, as my monitor does the same thing. D: Anyone?
Posted on Oct 13, 2011
LG 2542T goes dark after showing "analog power saving mode" message
Can you try the screen in another computer? I beleave the screen goes into power saveing mode when there is no input signal, thats what both my screens do.
Is your computer working?
May 16, 2008 | LG L1717S-BN 17" LCD Monitor
Check signal cable
There is no problem. The monitor is telling you that it's not receiving a signal. The reason there is no signal is because your computer is turned off, so it's telling the truth. :D
The monitor should go into idle mode on its own, so you won't see that message for very long. It's annoying, but doesn't cause any real problems. You can save even more energy by shutting off your monitor entirely after you shut down your computer. This will make the message go away and also save money on your electricity bill!
Apr 23, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
DVI won't work
WOW! I have that monitor too on one of my systems!
Strange thing is it HATES the SVGA connection ~ but works FINE with the DVI... wish I could tell you why?
I've tried a array of 'new drivers' but none help... STRANGE thing too is OTHER monitors work FINE (with the VGA port) so I'm fairly confident it's not that...
I CAREFULLY inspected the pins on the male connectors to assure none are pushed back into the connector body and tried new cables too... still NO GO?
PLEASE let US know if you found a solution!
Anthony
Dec 12, 2017 | Samsung SyncMaster 214T Monitor
Samsung GH19LS LCD Monitor wont display computer signals
You should have received two cables with the monitor. One is for VGA and plugs into you video card or computer board . The second one is for DVI digidal video and if you have that cable it plugs into the square connector. Then if you look into your monitor manual or quick setup sheet it will tell you how to connect and set the monitor to either VGA or Digital. I'm sure that is what has to be set. Don't hook up both cables to the monitor and computer. Only use the one. Digital gives you a better picture if your computer has that function. Hope this is helpful. Bud
Jan 04, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Monitor problem 900g analog signal and no picture
You power/inverter board more than likely needs an overhaul of at least the capacitors.
I do these on ebay.
There is a slim chance that one of your bulbs is failing ? This would normally show as a little pink in the screen, or flickering.
If you need instructions to disassemble it, let me know.
bammbammfran
Oct 20, 2008 | Computers & Internet
Analog output works fine, but no signal for digital output
is ther option on screen it self dvi mode and anlog mode .
Jan 24, 2008 | Sun - XVR-100 Graphic Card
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Monitor has no picture
Yes! :)
Your monitor is not the problem. Check all the connections from the back of the monitor, to the computer.
"No Signal Analog" means your monitor is working perfectly, however is not receiving signal from the computer.
Didnt find any loose cables?
Try unplugging everything. Leave it unplugged for at least 5 minutes. You need to give the system time to drain all the excess power.
Again your monitor is fine, blue light > No signal > orange light is totally normal for your montior.
Oct 12, 2007 | ViewSonic VX922 19" Monitor Flat Panel
No digital signal but analog works fine
Seems like this was already answered? But once you've checked against the owner's manual and ruled out the PC, I would suspect the signal / video board inside the monitor. May have gotten a surge or static, etc.
Jan 11, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
SVA-USA VR 17S 17" Flat Panel LCD Monitor Logo
27 people viewed this question
Top SVA-USA Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a SVA-USA Computer and Internet Expert? Answer questions, earn points and help others
