Question about Toshiba Satellite A215-S4697 Notebook PC
Cannot record sound
I cannot use my mike. I can hear sound from my Toshiba laptop but cannot record sound. Please help
    Problem Solver:
  • 8 Answers
Normally every Lap is coming wit internal mic; so
1- Simply check your mic is mute or not
2 - Check your mic volume
3 - Use sound recorder that comings with windows (just record & play)
4 - Use an external MIC (known as working) with sound recorder
5 - Check in control panel->sound and audio device --> default recording device and Voice recoding device as your system’s built-in audio device (some times it’s changing when we installing b-tooth deice)
6 - Check device manager --> under sound audio controller for any issues
7 – Uninstall & install completely your Audio Device driver with default settings.
** If you didn’t solve your prob; my advice is take your lap to a good technician with component level Repair skills.
Thank you & Best Regards
Dinu..
Posted on Dec 20, 2008
High beep when i increase the volume
This is more than likely feedback from your mike. You'll need to turn the mike off the stop the feedback. Right click on the speaker in the lower right of the display and recording devices to shut the mike off.
If this information was helpful, please rate it high.
Jun 05, 2011 | Toshiba Satellite Pro P300 Notebook
The mike of my headphones is not working.Even the inbuilt sound recorder of windows XP can't record any sound from the mike..The mike is working fine in other Laptops.I have installed all the...
make sure that your mic input is not muted. look under control panel/sound and audio devices, then under your microphone, select "volume" and make sure the input is selected (with a chack mark in the box under the mic volume control) and not muted.
Oct 12, 2010 | Compaq Presario 700 470024-192 Notebook
I have a Toshiba Satellite P205d-S7438 laptop. I am trying to determine if I have an internal microphone. On the front of the computer, there are connections for a microphone and headset.
sorry, accourding to the laptop specs found here
you do have built in speakers but no mic!
you need to get mic and headphones or a headset to say chat with sound through your mic using msn messenger or skype.
I know is not the answer expected, my apologies!
Apr 19, 2010 | Toshiba Satellite P205D-S7438 Notebook
Toshiba laptop Microphone Not working or Non-existant?
Click Start/All Programs/Accessories/Sound Recorder. Click Start Recording and talk to your computer in a normal voice. When you finish click Stop Recording. Type in a file name and click save. Open the file and play it. If it works you have a built in mike, otherwise buy yourself an external, which I recommend anyway, because the built in mikes are generally not good enough for voice recognition or VOIP.
Sep 22, 2009 | Toshiba (P000257700) Microphone
WindowsMediaPlayer silent on Toshiba laptop; sound faint on Skype
GOTO CONTROL PANEL-- check the audio devices, see if its set to the default device under playback and recording device, default is realtek,,,
Feb 03, 2009 | Toshiba (P000377700) Computer Speakers
Sony dcr-dvd105 no sound
Try this:
Play back a recently recorded scene through the viewing screen. Make sure any "mute" setting is turned off and turn the volume up. If you can hear the sound, the problem is not in the camera. Also, run through your menu's audio settings to make sure that they are set correctly.
If you can't hear any sound, repeat the process with an external mike attached. If this gives you sound, the camera's built in mike is defective. Time to hand it in for repair.
If you still can't hear any sound, something else is wrong with the camera. Again, send it in for repair.
Jan 09, 2009 | Sony Handycam DCR-DVD105 DVD Camcorder
Acer aspire 4720z Built-in microphone only records loud static
You did great troubleshooting for your laptop. If the sound is fine and good for the headset, your sound card is probably not the problem. The driver aspect, should not be the problem either if it works with your headset. So herein lies the dilemma...the problem is most likely due to some physical componenent between the built-in mike and the computer case itself. You should take it to a laptop repair shop and see what they can do. It has nothing to do with the software or the sound card. It is the physical component of the built-in mike and speakers. Get that checked out and you should be good to go!
Nov 15, 2008 | Acer Aspire 4720 Notebook
Toshiba tecra m3
The window sound recorder is not very good this purpose. You would need a sound recoder progam :
check this link:
http://www.sound-recorder.com/
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 19, 2008 | Toshiba Tecra M3 Notebook
The microphone muted on my toshiba satellite laptop
sure...open control panel..go to sounds..open the sound manager..check to see if the mike is muted..uncheck that box..you can also adjust the settings from there, usually
Oct 11, 2008 | Toshiba Satellite A135-S4527 Notebook
Microphone is not working
You need to check that all of your sound devices are enabled. Most laptops will shut down certain devices when on battery to conserve power.
There are setting available to alter the microphone gain in the sound settings part of the control panel. Under Sounds and Audio Devices Properties. Check the sound recording section under audio, make sure the microphone is enabled and that the volume slider is not at minimum. Under XP there is a test hardware button that should help.
Dec 13, 2007 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A215-S4697 Notebook PC Logo
259 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
