Question about Lexmark Z611 InkJet Photo Printer
Phote prints out faded and in black and pink only
I tried printing a copy of my head stone photo. it turned out light pink all over except for all the inscriptions done on the stone. that part was black. my color cartridge is old but the black one is new. can I do some kind of color test? if so, how? should I go ahead and change my color cartradge also?
  • 859 Answers
There are a number of single issues that can cause your problem in this case. The most common are listed below:
1.) Color cartridge expended.
2.) Print Paper selection incorrect.
From your statement above. I would suggest it is both item 1 and 2. Since, we are doing this assistance via chat mail, I can't come to your aid and witness myself what the results are and what your settings are for the paper type.
When you end up with a red hue over all over the print area the cause it usually a bad print head and selecting the wrong paper type.
To answer you question then, Yes, replace your color cartridge. But, first, try this method below to clean your color cartridge bubble jets.
When you go to print a job, always go into print setup or printer properties and choose the paper type as closely as you can to match the paper you are using.
The print head manual cleaning is listed below, it is from Lexmark. Below that is a process to clean blurry and bad print results. Although this is not specifically the case in your problem. The process to achieve resolution will also correct any problem your machine may be having. Remember, I do believe you need a new color cartridge. You will know with certainty however when you clean the cartridge head. If you do not see, cyan, magenta and yellow lines upon cleaning, at all, ever, then those inks are depleted. Replace your ink cartridge and then do these steps below the head cleaning.
Also, when ever you change a black or color cartridge you will want to run a print head alignment test and adjustment. There is enough of a difference in cartridges that this is quite necessary.
Please do not hesitate to give me as much feedback as possible on any issues and results you discover. You can use the comment text area below to respond to these instructions and give me the results of your tests and procedures.
Regards, Worldvet
Cleaning procedure
  1. Remove the print cartridges.
  2. Moisten a clean, lint-free cloth with water.
  3. Gently hold the cloth against the nozzles for about three seconds, and then wipe in the direction shown below.
    phote prints out faded and in black and pink only - pattlnk_6142005_1418-all_carts_clean_manually.jpg
  4. Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and then wipe in the direction shown.
  5. With another clean section of the cloth, repeat steps 2 through 4 above.
  6. Allow the nozzles and contacts to dry completely.
  7. Reinsert the print cartridges.
  8. Print the document again.
  9. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times.
To Resolve Print Quality Issues (below is for blurry lines, it will resolve many other issues too, so proceed after replacing your color ink cartridge if upon cleaning you see no ink coming out and the cartridge feels very light and makes little to no sound when you shake the cartridge.)
Overview This article outlines various techniques for resolving a blurry print issue. Cleaning the print cartridge nozzles is necessary when:
  • Characters are not printing completely.
  • White dashes appear in graphics or printed text.
  • Print is smudged or too dark.
  • Vertical, straight lines are not smooth.
  • Colors on print jobs are faded, or they differ from the colors on the screen.
Clean the Print Cartridge Nozzles using the Computer
    1. Load plain paper.
    2. Open the Lexmark Solution Center (go to Start, Programs, Lexmark XXXX Series, Lexmark Solution Center).
    3. From the Maintenance tab, click Clean to fix horizontal streaks.
    4. Click Print. A nozzle page prints, forcing ink through to clean the clogged nozzles.
    5. Print the document again to verify that print quality has improved.
    6. If print quality has not improved, try cleaning the print cartridge nozzles up to two more times.
Clean and Wick the Cartridge
  1. Try cleaning and wicking the cartridge to help improve the print quality. See this article for directions.
  2. When this step is complete, try to run the clean print nozzles (CPN) operation again.
Auto Alignment · Align the print cartridges
Align the print cartridges after installing them to improve print quality. To do this:
    2. Open the Lexmark Solution Center.
    3. From the Maintenance tab, click Align to fix blurry edges.
    4. Click Print. NOTE: Discard the page after it prints.
User the Quality Settings in Print Properties
Print Properties is the software that controls the printing function when the All-In-One is connected to a computer. You can change the settings in Print Properties based on the type of project you want to create. Do the following:
  1. With a document open, click File, Print.
  2. In the Print dialog, click the Properties (or Preferences, or Options, or Setup) button. The Print Properties screen appears.
    Click here for an enlarged view.
  3. Try changing the following settings to see if your print quality improves:
    Multiple Copies·Specify how the All-In-One should print several copies of a single print job: collated or uncollated.
    Print Color images in Black and White·Select this to print color images in black and white.
    Paper Setup
    Paper Type·Select the type of paper you are using, or allow the printer sensor to select the paper type for you.
    Paper Size·Select the size of the paper you are using, and specify whether or not you want to print borderless.
    Orientation·Specify how you want the document oriented on the printed page - portrait or landscape.
    Print Layout
    Layout·Select the print layout you require.
    Duplexing·Select this option when you want to print on both sides of the paper.
Save Settings
From the Save Settings menu, you can name and save the current Print Properties settings for future use. You can save up to five custom settings
I Want To
The I Want To menu appears when you open Print Properties. It contains a variety of task wizards·printing a banner, printing a poster, printing a photograph, printing an envelope, printing on both sides of the paper·to help you select the correct print settings for a project.
Check the Media
If the print is still blurry, try printing the same image on a different media brand/type: plain paper designed for use with inkjet printerscard stockgreeting cards, index cards, postcards, or photo cardscoated paperphoto or glossy papertransparenciesiron-on transfersbanner paper
Use the Lexmark Photo Editor
Try printing a higher quality image, or print an image from a different source.
Posted on Dec 20, 2008
  • Glenn Rogers
    Glenn Rogers Dec 21, 2008
    What results did you manage to achieve? Thanks. Your reply will help in assisting in our repair database.
I've got a Canon Pixma MP 500. Printing from my computer = faded print. Copying = blank page. Auto head align fails. Alarm light goes on. Have tried stop/reset button. How can I fix this?
It sounds like the print head on your printer is either clogged or not working.
You get faint print from your computer because the computer will use your color inks to get gray. When you copy, it only tries to use black and the black isn't printing at all.
Check your user's manual and it should show you how to clean the print head. Otherwise replace the print heads and you should be fine.
Aug 16, 2010 | Canon Pixma MP500 All-In-One InkJet...
All colours and black print faded. Black is a
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Faded text every few lines- Canon printer
When you print photos you print in Max dpi, for this no faded lines anywhere. Probably you have a problem only in black color in print head.
Мay be it's partially clogged or partially defective.
Sep 28, 2009 | Canon i850 InkJet Photo Printer
Constantly cleaning the print head
I feel you should take it back. Under warrantee?
May 01, 2009 | Kodak ESP 5 Printer
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
My black is really faded, when I print a test page by pushing photo and copy, however when I do a print head allignment the black for the allignment paper is sharp and deap, whats going on? Ive tried to...
The PHOTO mode is for printing grayscale photographs. Printed letters using PHOTO mode may appear faint because PHOTO mode is optimized for halftones. See if there is a TEXT or LETTER print mode, and try printing on that setting. If printed letters are still faint, you may have to go into ADVANCED PRINTER PREFERENCES, and see if the TONER SAVE mode is on. If it is, turn TONER SAVE off. Also, try changing the DPI image density, or try other adjustments in the ADVANCED PRINTER PREFERENCES MODE.
Aug 21, 2008 | Kodak Office Equipment & Supplies
Faded print job
ok...have you tried a clean and re calibrate lately on those print heads?
Mar 20, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Open Questions:
See all Lexmark Z611 InkJet Photo Printer Questions
Lexmark Z611 InkJet Photo Printer Logo
501 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
