I getting Low virtual memory now an then Operating system : NT4.0 Model : IBM Netfinity 5500 RAM : 130,472 KB
    President:
  • 2,110 Answers
You can change virtual memory by following steps
Rightclick on My computer->Advance tab->Goto Performance Tab->Advavnce..
Posted on Dec 20, 2008
Error message Low on virtual memory
Virtual Memory is used by the operating system as an extension to the Random Access Memory (RAM). When the RAM does not have enough space to accommodate the entire running program, the inactive parts of that program are temporarily shifted to the Virtual Memory. These parts are then swapped back into the RAM as and when needed. If the Virtual Memory set on your system is not enough for the computer operations to run smoothly, then you will get the "Virtual Memory Is Too Low" error message.If operating system is xp then this problem can be easily overcome by increasing the Virtual Memory size.This is how you can do it by following instrutions:
  1. Click on "Start" and then click on "Control Panel.
  2. Double-click on the "System" icon in the Control Panel.
  3. Click on the "Advanced" tab in the System Properties dialog box.
  4. Click on the "Settings" button below Performance.
  5. Click on the "Advanced" tab in the Performance Options dialog box.
  6. Click on the "Change" button below Virtual memory.
  7. Click on a drive_letter below "Drive [Volume Label]" in the Virtual Memory dialog box.
  8. Click on the "Custom size" option.
  9. Click in the "Initial size (MB)" text box and type a larger value (for example, 600).
  10. Click in the "Maximum size (MB)" text box, and type a larger value (for example, 1500).
  11. Click on the "Set" button. Similarly change the Virtual Memory on other drives.
  12. Click on "OK" and then restart your computer.
Apr 07, 2010 | Microsoft Windows XP Professional SP2
At bootup, I receive a message about a problem
Turn the computer off.
Remove the RAM from that J1/Slot6 slot.
Reconnect the power and start it.
Do you still get the "problem" message?
Mar 26, 2010 | IBM Netfinity 5500 M20 4RY (86624RY)...
My operating system is windows 98, i recently upgraded my memory card from i gigabyte to 2 gigs, but every time i boot my computer there is an error message low in memory, the question is; how can i boot...
CAUSE:
The Windows 32-bit protected-mode cache driver (Vcache) determines the maximum cache size based on the amount of RAM that is present when Windows starts. Vcache then reserves enough memory addresses to permit it to access a cache of the maximum size so that it can increase the cache to that size if needed. These addresses are allocated in a range of virtual addresses from 0xC0000000 through 0xFFFFFFFF (3 to 4 gigabytes) known as the system arena.
On computers with large amounts of RAM, the maximum cache size can be large enough that Vcache consumes all of the addresses in the system arena, leaving no virtual memory addresses available for other functions such as opening an MS-DOS prompt (creating a new virtual machine).
WHAT CAN U DO?
To work around this problem, use one of the following methods:
  • Use the MaxFileCache setting in the System.ini file to reduce the maximum amount of memory that Vcache uses to 512 megabytes (524,288 KB) or less. For additional information about how to use the MaxFileCache setting, click the article number below to view the article in the Microsoft Knowledge Base: 108079 (http://support.microsoft.com/kb/108079/EN-US/ ) 32-Bit File Access Maximum Cache Size
  • Use the System Configuration utility to limit the amount of memory that Windows uses to 512 megabytes (MB) or less.For additional information about how to use the System Configuration utility, click the article number below to view the article in the Microsoft Knowledge Base: 181966 (http://support.microsoft.com/kb/181966/EN-US/ ) System Configuration Utility Advanced Troubleshooting Settings
  • Reduce the amount of memory that is installed in your computer to 512 MB or less.
Feb 07, 2010 | Computers & Internet
System says low on virtual memory even after I zero & format the hard drive with new operating installed?
this is virus instaled on computer bios or defective memory boards.
1st replace memory, and check-it.
2nd find a original bios on IBM website, and flash-it.
Nov 22, 2009 | IBM NetVista PC Desktop
Missing support/installation cd
I had the same problem.
There is a cd that came with the server called "IBM RAID Support" that is a must have to reconfigure the hard drives.
It took me a week to find the ISO image.
I will upload the cd via FTP and send you the link.
Apr 07, 2009 | IBM Netfinity 5500 M20 4RY (86624RY)...
I have an IBM thinkpad T20 running windows 2000. The computer is on and booted up but the monitor is not lighting up. It is running on 256mb ram and I was getting a lot of virtual memory is low warnings...
To determine if the laptop has a problem with the inverter of low virtual memory issues, plug an external monitor in to the laptop and you can change the virtual memory by following these instructions, right click on my computer, select properties, then select advanced, click on virtual memory and change the settings to system detemined, save settings and reboot the laptop without the external monitor to see if it is virtual memory or inverter.
Please keep me informed
kind regards and please don't forget to rate us
Dec 03, 2008 | Computers & Internet
Netfinity 550 "drive not found"
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Dec 02, 2008 | IBM Netfinity 5500 M20 4RY (86624RY)...
Nintendo DS lite game card
there several steps like these....
may be the virtual memory is low.... you trying increasing virtual memory..
this can be done by following
1. go 2 control panel,system,advanced tab
2. in performance option click settings
3.go to advanced
4. go to virtual memory option there click change select your operating system drive and increase the virtual memory minimum for 700 and max to 900... give ok
and then have check...
if same problem persists may be ram u r using is low upgrade your ram to atleast 512mb ram
or
may be you are using the old version of directx... install latest version of directx ( atleast you install directx9.0c)
or may be operating system problem(may be due virus attack system files have became unstable) try reinstalling it...
Jan 16, 2008 | Computers & Internet
Running Non-ECC Ram in a IBM Netfinity 3500 M20
Dear NickB,
In my experience working with many servers, Non-ECC memory will not work on a machine that requires ECC memory. It is possible in some servers to disable the ECC mode in the system BIOS to allow non-ECC memory to work, but you will often end up with performence problems later on.
Hope this information helps, let me know if I can be of any further assistance.
Oct 31, 2007 | IBM Netfinity 3500 M20 8657 Server
Bios upgrade error
re-install the old bios. evidently the new flash bios is not compatible with your machine.
Sep 11, 2007 | IBM Netfinity 5500 M20 4RY (86624RY)...
Computers & Internet Logo
47 people viewed this question
Alun Cox
David Payne
David Payne
