Question about Channel Vision TFT-5.6" monitor w/mounting stand
I have a tft 5.6 color display monitor not working
Put power to it and the monitor will not come on
  • 15,935 Answers
Is there a video source? is the fuse blown? is it a faulty unit?
Posted on Dec 22, 2008
I was given an ilive dvd player boom box, model IBPD882B and the display screen doesn't work. Can I get another screen for player?
yes, but check connections
7inch TFT LCD Display HSD070I651 480×234 Resolution 7"Analog ...
https://www.ebay.com > ... > LEDs, LCDs & Display Modules > LCD Display Modules
7" HSD070I651 480X234 LCD Screen Signal Interface 26 pins TFT Specific Analog RGB, FPC. Resolution 480 ( RGB)×234. Viewing Angle 60/60/40/60 (Typ.). (CR?10) [Left / Right / Up / Down]. Display Mode TN, Normally White, Transmissive. ' eBay!
7 Inch TFT LCD Color 480 x 234 Resolution Stand/Mount Rear Button ...
https://www.amazon.co.uk/234-Resolution-Button-Monitor-420-TV.../B013FVEJP2 7 Inch TFT LCD Color 480 x 234 Resolution Stand/Mount Rear Button Leg Monitor with 420 TV Lines Night Vision Camera: Amazon.co.uk: Car & Motorbike.
7-inch TFT LCD Module with 480 x 234 (RGB) Resolution, Available in ...
www.globalsources.com > All Categories > Electronic Components Number of the colors: 65KModule dimensions: 164.9 x 100.0 x 5.5mmVA size: 7 inchesAA size: 154.08 x 86.58mmResolution: 480 x 234 (RGB)LCD type: TFT and transmissiveViewing direction: 12:00IC: HX8227-A01 and HX8655-ABacklight: CCFL backlightOperating temperature: -10 to 60 degrees CStorage temperature: ...
Feb 06, 2018 | iLive Televison & Video
Viewsonic VX910 display goes off and on.
if you mean that the screen cannot be viewed because it goes dark, then the backlighting is faulty, and i don't think a repair is economical. Or if you mean the the monitor turns on and off and displays no signal, just check the vga connections, if there are no bent pins then there is an internal fault, again with prices of LCD monitors coming down, it's not worth waiting weeks for it to get repaired when you can pick up monitors cheaply.
Jun 10, 2007 | ViewSonic VX910 19" LCD Monitor
Why going off after 5-10 min black screen
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers. Good luck.
Jul 04, 2014 | Gateway 24" Widescreen Flat Panel TFT LCD...
Neither picture is displaying on moniter nor sound is coming (DELL TFT moniter)
Which is a dell tft or compaq crt monitor ?
The Dell 1504FP is a flat panel LCD monitor that has a viewable area of 15 inches.
The monitor, which uses TFT technology, is designed to be used in a home or office and displays video at a resolution of 1024 x 768 pixels.
Over time, you may encounter problems using your Dell 1504FP monitor or it may cease functioning altogether.
Fortunately, there are variety of ways that you can repair the monitor to get it back up and running.
Shut down your computer and press and hold the power button on the side of your Dell 1504FP monitor if your monitor has a blank screen.
Unscrew the VGA video cable that connects the monitor to the computer.
Power the Dell 1504FP monitor back on and wait as it launches into the Self-test Feature Check.
During this period of time your monitor will make settings changes to ensure that it functions properly with your computer.
Firmly screw the VGA cable back into the rear of the monitor to ensure optimal video quality. Power both the monitor and computer back on and wait for your computer's desktop to appear.
Power off your Dell 1504FP monitor if the screen is dirty.
Wipe down the monitor using a dry microfiber cloth to remove any dust particles or smudges that have accumulated on the screen over time.
Power the monitor back on when you are complete and resume using it.
Press the "Auto Adjust" button on the right side of your Dell 1504FP monitor if the display is blurry and images appear out of focus.
Unplug the monitor's power cord for thirty seconds if the problem persists.
Plug the monitors power cord back into the rear of the device and power it back on.
This will reset the monitor and your display should now be focused properly.
http://support.dell.com/support/edocs/monitors/1504fpis/en/trouble.htm
Troubleshoot a TFT Monitor
TFT monitors can suffer from many potential problems, ranging from simple screen brightness issues to disconnected inverter or LCD cables.
These can cause video- and backlight-related failures on your TFT monitor.
Fortunately, you can attempt to repair these problems, even if you have no experience fixing a TFT monitor.
The only tool you will need is a Phillips screwdriver, although opening your TFT monitor will likely void its warranty.
Check the brightness settings on the TFT monitor.
There are dedicated adjustment keys on the bottom face of the TFT monitor.
If it is a screen incorporated into the design of a laptop, you'll find monitor adjustment keys on the top row of the laptop's keyboard.
A TFT monitor that has its brightness turned all the way down will appear to be almost completely dark.
Ensure the TFT monitor's power cable is still plugged in, if it is an external monitor. In the case of a laptop, make sure that the power cable is plugged in or that the battery is properly charged.
Disconnect the TFT monitor from the power source. If the TFT monitor is an external model connected to a computer tower, disconnect the video cable as well.
Remove the battery from your computer if you are using a laptop.
This is an important safety measure.
Turn the laptop over and slide the battery release mechanism over.
This mechanism is just below the horizontal outline of the battery on the underside of the laptop.
Remove the screws on the bezel of the TFT monitor.
The bezel is the plastic piece surrounding the TFT screen.
The screws will likely be covered with plastic seals for aesthetic purposes, so pop these seals off with your fingers and remove the screws using a Phillips screwdriver.
Pry up on the bezel gently and remove it.
Start at one corner and work along the bezel's perimeter with your fingers.
There will be small plastic latches between the bezel and the rest of the computer you'll need to disengage.
Check the TFT monitor's inverter cable.
This black cable lies at the bottom center of the monitor and should connect to a socket on the inverter board, which is the green color horizontal strip that lies just below the inverter cable.
If the cable is loose from the board, the TFT monitor's backlight will fail. Pull up on one side of the socket and slide the cable back in, then press firmly down on the socket to lock it down.
Remove the metal brackets on either side of the exposed TFT monitor if the inverter cable fix does not solve your issue.
There will be two to three screws in each bracket that must be removed using your Phillips screwdriver.
Pull the TFT monitor carefully away from the rear casing of the display to reveal the LCD cable. This cable runs from the back of the TFT screen and should be connected to a socket in a similar fashion to the inverter cable. If it is disconnected, lift up on the socket, slide the LCD cable back in, then press down on the LCD socket to lock it back down.
NOW FOR SOUND
if you can get a screen
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
If your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers.
Rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a free driver solutions
which will automatically search for and find the correct driver
You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
It might take some time being free
Aug 09, 2013 | HP COMPAQ 7540 CRT Monitor
Power supply sony monitor SDM-S204
TRY WITH A OTHER MONITOR ARE THAT OKEY YOUR MONITOR ARE PROBERLY BROOKEN.
ARE THE OTHER MONITOR ALSO BLACK YOUR VIDEOCARD ARE PROBERLY BROOKEN.
ALL CABELS SHOULD ALLWAYS BE SEATED TIGHT.
Jun 07, 2013 | Sony Sdm-s204 20.1" Tft Lcd Color Desktop...
I have model LCM-19v1 SL monitor and I need to know what type of power cord I need for it. and possible a picture
hi,
these are the specs for you monitor
Upgrade your desktop display in size and style with this Westinghouse LCM-19v1 19-inch LCD monitor! Its advanced HD-Grade flat panel technology lets you enjoy crisp, vibrant images while working on spreadsheets, writing email, watching movies, playing games and surfing the web.
Some key features include 1280 x 1024 native resolution, 600:1 contrast ratio, and a fast 21 ms response time. Its thin, sleek and sophisticated design will complement any office. Get yours today!
By law, California shipments of this product are subject to an $8.00
Electronic Waste Recycling Fee
Features/Specifications:
  • Westinghouse LCM-19v1 19-Inch TFT LCD Flat Panel Monitor
  • General Features:
  • Silver Cabinet color
  • 19" diagonal screen size
  • Native/Optimum Resolution: 1280 x 1024 16.7 million colors
  • Compatible Modes: VGA, SVGA, XGA, SXGA
  • Contrast Ratio: 600:1
  • Brightness (Nits): 300 cd/m2
  • Response Time: 21 ms
  • Viewing Angle: 170 degree Horizontal, 170 degree Vertical
  • Built-in stereo speakers
  • Connectors: 3.5 mm stereo mini-jack. VGA-in, DC-in
  • DC Input: 19V - 3.1A
  • EnergyStar compliant
  • Regulatory Approvals:
  • FCC
  • UL
Package Includes:
  • Westinghouse LCM-19v1 19-inch TFT LCD Flat Panel Monitor
  • Power Supply (100-24V 50~60Hz)
  • Power Cord
  • Stand
  • VGA cable
  • Audio cable
  • User's Manual
Additional Information:
  • Requirements:
  • Available power outlet
  • VGA adapter
  • Notes:
  • LCD displays may have cosmetic imperfections that appear as small bright or dark spots. This is common to all LCD displays used in products by all vendor and is not specific to any vendor or brand. Below are the acceptable amounts of "dot defects" for LCD displays that we sell:
  • 17-Inch to 18-Inch:
  • Total Defects: 8
  • Bright or Dark Dots (random): 4
  • Bright or Dark Dots (2 adjacent): 2
  • Bright or Dark Dots (3 adjacent): 0
  • Minimum distance between defects: 15 mm (bright to bright dots); 5 mm (dark to dark dots
for the adapter, already inserted the picture of it
Hope this will help... Your response is very much appreciated....
Jan 20, 2011 | Computers & Internet
My monitor does not display any color other than blue.
Check monitor button to select proper colours or reset it to factory settings
Sep 08, 2009 | Gateway FPD1775W Monitor
Samsung SyncMaster 510N LCD TFT Monitor
Does the monitor remain on does it switch off?
Problem seems to be hardware related ie monitor itself is defective.Try connecting to another known working system.If monitor is defective it could be a power/inverter related issue or panel could be defective.
Please provide feedback and rate the solution.
Samir
Jun 13, 2008 | Samsung SyncMaster 510N (Silver) 15 inch...
Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Monitor stops display
most likley the monitor has an internal power supply failure, generally the cost of repair could be higher than buying a new one.If your monitor is still in its warranty period contact the manufacturer,if not do you know of a local tv repair shop that provides free estimates to confirm cost of repair vs. replacement?
Dec 14, 2007 | ViewSonic VA1703wb Monitor
Car Audio & Video Logo
76 people viewed this question
Top Channel Vision Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Channel Vision Car Audio and Video Expert? Answer questions, earn points and help others
