Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
T.V won't turn on
Well i turned it on and hooked up my ps3 after a minute it just shuts of. Now it won't turn back on
  • John Smith Apr 02, 2007
    Also no lights come up nothing happens when i click the power button
    Scholar:
  • 77 Answers
If nothing happens at all no lights no click make sure you unplug it for a while and try again the micro may just be locked up. If not also look at the line fuse, beyond that it will get pretty technical. May need a pro. Good Luck
Posted on Apr 25, 2007
Playstation 3 works fine useing the av hook up but won;t work with hdmi cable hook up.
First, make sure your TV is on the appropriate input for the plugged in HDMI cable. Once this is completed, turn your ps3 on. If the screen comes on and is black, turn the ps3 to standby (red light is on) and hold the front power button until the console beeps a second time. This will usually force the ps3 to recognize the hdmi input and will bring up the menu to configure the AV settings.
Aug 13, 2014 | Sony Playstation 3 (PS3) Console
Ps3 just shut off by itself
The Fan could be faulty, I have had that problem with numerous devices, if the fan IS faulty, make sure you can get enough air for it to cool down
Nov 19, 2012 | Sony Playstation 3 (PS3) Console
Error code 8002f149
Give this a shot:
Hard boot the PS3, turn off the PS3 to stand-by, flip off the back switch and remove the power cord. Then shut off your modem/router, for about 5 minutes, then turn the modem back up first and let it sync, then turn the router back on(if using one) and let it sync. Reconnect your power cable and flip the back switch up again. Then make a new network connection.
Jun 09, 2011 | Sony Playstation 3 (PS3) Console
Error code 8002f149 keeps coming up after the system trys to update
Jun 06, 2011 | Sony Playstation 3 (PS3) Console
I hooked the ps3 to the philips tv. turned on the ps3, AV1 displays in the corner. Nothing else happens, I am expecting the ps3 logo
give this a try...
Leave the TV running, go over to your PS3 and turn it off.
Once its off, hold the power button down till you hear a beep, KEEP HOLDING THE POWER BUTTON till you hear a double beep. The PS3 will shut itself off.
Give the device a couple of seconds, then hit the power button one last time (just turn it on, you don't have to hold it).
If all went right, your baby is back up and running...
Oct 11, 2010 | Philips 27RF50S 27" TV
PS3 turned off on its on, now won't turn back on
"When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked."
"If this happens:
• Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
• If the PS3 system is in an enclosed area like a bookshelf or entertainment center, move it to a more open area.
• Leave the PS3 system off for 30 minutes to let it cool down.
• If you continue to have issues, you will have to send the system in for service."
Hope this will help...
May 31, 2010 | Sony Playstation 3 (PS3) Console
Turns on then it turns right back off
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} "When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked."
"If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like a bookshelf or entertainment center, move it to a more open area.
· Leave the PS3 system off for 30 minutes to let it cool down.
· If you continue to have issues, you will have to send the system in for service."
May 26, 2010 | Sony Playstation 3 (PS3) Console
My ps3 shuts down after two minutes. It won't turn on when I press the ps button on my controller. I don't get a blue light at all, and when I do turn it on I get a message that says it was turned off...
when that message appears press the PS button on your controller and your controller will turn on, follow the steps on the screen after shutting it down it should be back to normal, all you have to do is hold the O/I button for 2 seconds, it will turn off after that press the PS buton on your controller and it will turn back on
Apr 14, 2010 | Sony Playstation 3 (PS3) Console
I turn on my PS3 and after about 2 minutes it
This is normally because the laser on the drive is slightly off. The good thing is that you can fix this yourself it is quite simple.
Or of course you can send it in to be fixed it is up to you.
If you send it in you will have to pay out about $130 to get it fixed.
Jan 24, 2010 | Sony Playstation 3 (PS3) Console
PS3 will not display on TV
WHEN YOU START YOUR PS 3, KEEP YOUR FINGER ON THE START BUTTON UNTIL YOU EAR A SECOND BEEP ( BETWEEN 5 & 10 SECONDS); THIS WILL RESET AND SELECT THE RIGHT CONNECTION . I HAD TO FIND THIS PROBLEM WHEN WE WERE SWITCHING FROM THE LIVING ROOM TO MY KID'S ROOM.
LET ME KNOW, HAPPY NEW YEAR.
PIERRE ( MONTREAL)
Jan 01, 2009 | Sony Playstation 3 (PS3) Console
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
