Question about Mitsubishi WD-62825 62" Rear Projection HDTV
Horizontial lines and picture deteroration
I have a wd 62825 and the picture is deterorating with horizontal lines. I have clean the mirrors and replaced the bulbs. Any other ideas?
  • Anonymous Feb 26, 2009
    I have the same issue with my set. i will check the caps and reply if fixed, thanks for the insight.
  • klbtech Apr 26, 2009
    the longer the t v is on the more and more horizontial lines there are. turn off the set and wait about 20 min. and turn it on the pucture is better, then it slowly gets worse. the compasiters have been replace already
    Problem Solver:
  • 17 Answers
This one is tough. Can be either the DM module, formatter board or optics block assy. Check for bad capacitors first in DM module, then signal board then formatter board. If your lucky, bad capacitors maybe what it is. If not, a new optics block is what you'll be needing.
Posted on Jan 09, 2009
Wd-62825 takes a few seconds to turn on
the lamp may be showing its age or number of hours of use---typical on this set from cold turn on is up to 15 seconds.
Oct 29, 2012 | Mitsubishi WD-62825 62" Rear Projection...
My mitsubishi diamond series wd-62825 picture is too dark
There is something I remember and it may be the model you have---Mitsubishi can tell you or you can look for yourself----a few models made at about the time this set was made had 2 mirrors----one a tiny one that faces up and reflects the picture into the large rear mirror.
Dumb idea--the little mirror gets coated with dust and brightness drops up to 70%---
The safe and correct way to know is to remove the entire front screen with its frame---both mirrors (if yours has 2) will be easy to see.
The large mirror hangs at a angle and down so it never gets dirty--don't even think of touching it or using glass cleaner on it--any mark on it will show in the picture.
let me know if you want to remove screen unit to see if one mirror or two---a call to mitsubishi would answer that.
May 15, 2012 | Mitsubishi WD-62825 62" Rear Projection...
My 91 sanoma is shifting late i have to put it in nuetrel then back in drive to get to 2nd and to get to third gear.are there band ajustments or what do i need to do?fluid is fine
No i think the box needs taking out and stripping and reconditioning ,these older vehicles are not computer controled but mechanical controlled ,so check the vacumn pipe from gearbox to the inlet manifold for deteroration
Mar 12, 2011 | 1991 GMC Sonoma
At what point do you replace the timing belt?
depends on its use ,any garage will give you the scare story and insist its done like yesterday but this vehicle is 4 yrs old and done a max of 40,000 miles i would say that with modern materials a belt is good for 100.000 or ten years old as they do deterorate in a dry hot climate sooner but if in a cool wet climate then maybe even longer say 120,000 but 60,000 is the recomended by the dealer but at their prices ??
Feb 21, 2011 | 2006 Mitsubishi Galant
My webcam shows up as upside down. Looking for a solution.
Please go to the webcam settings. There you will have an option to MIRROR the image either vertically or horizontially. Try them both. The vertical flip will solve your problem and horizontal flip will turn your picture from right to left and left to right.
Feb 08, 2011 | Computers & Internet
Horizontal Lines in Picture, Picture Possibly Dimmer
The dimming is usually caused by the mirror needing polishing. The lines floating across the screen is usually caused by failed caps on the FMT board you can get the V26 FMT repair kit from
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-fmt-pwb-repair-kit/cName/repair-kits
Jul 07, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have horizontal lines and flickering picture
I had the same problem a year ago. Turned out that the main chassis was bad. Had to have it rebuilt for $550. Was working perfectly until the recent problem with the set turning itself off just started.
Sep 17, 2009 | Mitsubishi WD-62825 62" Rear Projection...
Wd-62825 mitsubishi dlp tv
Had the same problem. Service replaced the lamp engine. It did help.
Dec 18, 2008 | Mitsubishi WD-62825 62" Rear Projection...
My Mits-Projection TV model WD-52825/WD-62825
Good Day, jmkay;
I see no reason why you can't do this yourself, but unlike the pioneer you have to approach the Mit's from the back and will have to remove the back from the screen (sort of)....charge you battery and Good Luck, big IRISH.
Aug 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Picture noise blue/pink
do self test diagnosis here in threads or goto ctechnicians.com
Nov 03, 2007 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi WD-62825 62" Rear Projection HDTV Logo
280 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
