Question about Kenmore 24 in. 15689 Built-in Dishwasher
Does not appear to wash
The dishwasher is a Kenmore Quiet Guard 3 Its not washing. It appears to go through a complete cycle but it does not wash. It fills with water, it heats up and drains but nothing is washed. Scott
  • 1 more comment
  • Anonymous Jan 04, 2008
    The machine fills up with water but does not wash, I was told it was the motor. I want to be sure because repair man was charging £147 for the motor alone with no VAT and no labour total cost £218. I found the part direct from the manufacturer £87.25 and I know I can fit it myself. The repair man charged me £25 for taking the dishwasher apart.
  • Anonymous Jan 09, 2008
    Ours does the same, but if it fills and drains its not the motor. Is it filling up to cover the seperator, if not its probably the inlet valve or water pressure.
  • Anonymous Feb 10, 2008
    Dishwasher is several years old but works fine, I love it, no problems. Washed off the front of the door yesterday and now the dang thing won't run. Bet I reset the buttons somehow. The dishes were dry and dirty, the soap door had popped open but NO water. Also, can't het the "water heat" light to go off. It just flashes at me when I push it. Buttons appear to work.
    I screwed up something when I cleaned the glass - reprogrammed the buttons or soemthing. How do I fix?
    President:
  • 1,462 Answers
Is there a low humming noise when it should be washing? if so may be the motor capacitor
Posted on Apr 04, 2007
Could you please help diagnose problem...dishwasher consistently stops washing in the middle of wash/sensing cycle. 2005 Kenmore Ultra Wash Quiet Guard 3
most likely the water is not hot enough,,it trying to heat the water,,when it starts to sense open the door and just test the water,,careful may be hot ,,but i doubt it...another easy way to tell is what is your hot water heater set on,,if you have a lot of soap residue is a good sign..
Sep 02, 2011 | Kenmore Dishwashers
Soap dispenser will not open during was cycle.
Probably a faulty solenoid on the dispenser. Not replacable new dispenser needed
Jan 20, 2010 | Dishwashers
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
Kenmore 665.17539. fills but does not wash. makes
Kenmore 665
My dishes on the top rack are no longer getting clean. I don't think any water is going to the top. The dishes on the bottom get clean but have a soap residue on them.
Jul 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore dishwasher does not wash completely
I had the same problem. I switched to a gel dishwashing liquid and added about 1/2 cup of white vinegar to each wash cycle. (Just pour the vinegar in a cup, put it in the dishwasher and let the water fill the cup and disperse the vinegar.) Gradually you can reduce the amount of vinegar that you use. Worked for me, hope it does the same for you.
Feb 07, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
The IRONY of my Quiet Guard!! SO LOUD!!!!
Yes the wash arm can be removed to get to the sump area. Take the model number for your dishwasher and enter it into a site like partselect.com. There you can get a blown up diagram of the components that need to be removed to get to the cause of the grind noise. Usually a seed or some other hard object has found its way down there.
Feb 06, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore Dishwasher displays the number "98"
I have a very similar problem. When I push a wash selection, every light on the panel shows up...and when I push Start, nothing happens. When I push cancel, it trys to drain, even tho no water is in there any more. Have you ever had an answer to your problem?
Feb 06, 2008 | Kenmore 16872 Built-in Dishwasher
Kenmore 24 in. 15689 Built-in Dishwasher Logo
632 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
