Question about Emerson EWF2004 20" TV
The TV seems to be stuck in some kind of diagnostic mode....
My grandmother picked up the remote and somehow mysteriously punched in a sequence of numbers or buttons that seems to have put the TV into some kind of diagnostic mode.
There are 4 numbers 2's one in each corner, there is no sound and the channels will not change. when I push the menu button on the TV the menu changes to various gibberish codes such as "DL/CH =" or BRT [349] + [129] or CNTRST {235} + {150-}
please tell me how to pull this out of diagnostic mode.
  • 1 more comment
  • Anonymous Dec 29, 2008
    same thing happend to my tv i cant see any channels and i cant change channels and i keep getting a message that my tv has no signal...i have the cable connected to it, idk what to do
  • superjunkbox Feb 02, 2009
    The tv is an Emerson made in 2004
    model number EFW2004
    it's a 20"
    I've had this thing unplugged since I posted the problem, I will plug it in tonight to see if it's cleared up on it's own.
    This is "superjunkbox" the poster of the original thread.
  • Bruce May 11, 2010
    tv make and model
    sometimes turning tv off and unplugging it for a while works
    if not need tv make and model
ebrus
  • 30 Answers
SOURCE: Emerson Spongbob tv broken remote...cant change input?
Then the only way to reach your tv is through coaxial antenna port. So you can buy an rf modulator ( very cheap) and connect your red yellow and white cables (rca cables from a dvd, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me.
Posted on Oct 15, 2008
nickstorm
  • 93 Answers
SOURCE: how to change the input
First, the bad news: Unfortunately, you are correct - the only button to change inputs is on the remote, which you no longer have.
Now, the good news: You can buy a universal remote, set it for your TV model, and have control of your inputs again. The first link below is for the URC R6, which is available at any Walmart for about 20 bucks. You can set it up for an Emerson TV, no problem. Here's the link for it:
http://www.universalremote.com/consumer/products.php
Also, here is a link for the owners manual to your Emerson EWF2703, in case yours has gone missing with the remote:
http://www.emersonaudiovideo.com/pdf/om/EWF2703.pdf
Not a perfect solution, but it will work, and it will work just as fast as you can get to your local Walmart or equivalent.
Cheers
Posted on Nov 05, 2008
  • 104 Answers
SOURCE: Can't find the input/video channel for my Emerson TV
universal remotes are tricky, if you have the pamphlet, often times there are several codes for each brand. you have to try all the emerson codes for your universal even tho the power, volume and channel functions may work with several emerson codes, some of these specialized buttons (like input) may only work on your TV with one specific code.
also, if there are any unlabeled buttons on the universal try them with each new emerson code.
Posted on Feb 12, 2009
  • 8457 Answers
SOURCE: cant change channels or input using front panel/no remote
Buy a new remote,tries this website for an exact remote or very closse to the original.1-800-Factory Original.
Posted on Sep 30, 2009
vljenterp81
  • 86 Answers
SOURCE: remote turns on/ off tv but will not change tv channels
that particuar remote might not work for this television completely. that is not unusual at all. it will understand some commands but not all of them. i would advise using a little black remote with white buttons that sells for $5 at the dollar general store. i have yet to see a tv that it does not work with. please rate me it would be greatly appreciated.
Posted on Nov 11, 2009
May someone please send the service mode specifications for a Samsung LED 40 inch TV UA40EH5000R?
I don't have service mode specifications but I do have a Samsung and looked around for how to get it in service mode some time ago because the HDMI cables somehow disconnected themselves a lot. Thought it was an electronic problem but it turned out to be a parenting problem instead SO I have never used this information and can not vouch for it. I cut and paste it from a note I copied from a forum entry to use at your discretion:
First post:
To enter "Service Mode" Press the remote - control keys in this sequence :
From Standby Info-Menu-Mute-Power On
- The buttons are active in the service mode.
Remote - Control Key : Power, Arrow Up, Arrow Down, Arrow Left, Arrow Right, Menu, Enter, Number Key(0~9)
Careful though there are things you shouldn't touch in this menu.
avforums.com/forums/lcd-led-lc­d-tvs/601553-samsung-service-m­enu-research.html
Another post:
Method 1
Put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV in standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Samsung LCD Monitor Service Menu Instructions
End quote.
Good luck. Just a basic suggestion you probably don't need: keep track of any changes made by writing them down so you can put it all back if you have to.
Dec 20, 2014 | Samsung Televison & Video
Tip
Curing the "black box" on some TV channels
Here's the symptom: A mysterious black box covers some or most of the picture on your TV, but not all the time. It may not show up on all channels, or sometimes it disappears only to come back later.
No, it's not the picture tube, it's your closed-captioning. Somehow your TV has been set to "text mode", and the screen is being cleared for text that isn't there. On channels or shows where captions aren't being broadcast, there's no box. But the box returns when captioning is being sent.
Many TV set remote controls have a single button to set closed-caption modes, so it's easy to set a TV to "text" without knowing it. (Especially when you have kids who love to press buttons!) Then when the box pops up, it's a mystery.
Simply press the captioning button on the remote, or use the set's menu, to cycle through the settings until you turn captions off. No more box!
on Jan 31, 2010 | Televison & Video
Tv master reset
GO TO TV MODE
PRESS MENU
THEN PUNCH 4725 ON REMOTE
WILL PUT YOU IN ENGINEERS MODE
WARNING YOU CAN MAKE YOUR TV UN USABLE
GO TO DIAGNOSTIC PAGE & SELECT RESET
TV SHOULD SHUT DOWN & RESTART
THEN YOU SHOULD GET FACTORY START UP FOR TUNNING
Jan 23, 2014 | Alba LDVD1538WDCH LCD TV
Sony KV-36FV26- no remote control. trying to reset to factory settings. Any ideas?
There is no other way to select factory setting, without its remote control.
Apr 04, 2013 | Sony KV-20S20 20" TV
Akira tv universal remote accidentally went into service mode cant reset
Press menu-display-power in sequence on the remote control.
Jan 08, 2013 | Televison & Video
My remoute control joust change the volume and anyother keys doesn't work.
The remote's volume keys are "punch-thru" keys, meaning they'll work for the TV for which the
remote is programmed no matter what mode the remote is in. It seems your remote is not
in "TV mode," but the punch-thru keys (volume UP/DOWN) are working.
The Solution: change the remote from "AUX mode" or "DVD Mode" back to "TV mode", by
pressing the "TV" button at the top of the remote.
Either that, or your remote keypad has failed with the exception of the Volume UP/DOWN keys....
Also, your batteries may be failing, since it takes a tiny amount of energy to light
the IR (infra-red) LEDs at the front of the remote to change the volume.
Is your remote a "multi-function" remote?
Could help more if you could post your Samsung remote model number, since
www.samsungparts.com lists 37 pages of TV remotes (at 10 models per page).
Jul 02, 2011 | Samsung TV Remote Control
Lost manual to work remote.Need template to work remote. My mom somehow zoomed the picture. She enjoys basketball, but is now unable to view the score on the margins.
Look in ur tv remote control for a button that said like VIEWMODE,P.sizes or Zoom buttons,pick one of these button fine a picture mode that fit ur tv screen.
Nov 22, 2010 | Dynex DX-L32-10A 32" LCD HDTV
Sony kde 50 xbr 950 blinking code
turn tv off, the use the code afore mentioned and it will turn on in service mode. You best know what you are doing. You can really mess tv up in there
Nov 13, 2017 | Sony Televison & Video
Direct TV remote code for yamaha rx-v463?
It is 30376. The trick to discovering, is to turn the receiver off, first. Then it will power on when you input mute/select 30376. Then you can program the DirecTV remote to adjust volume (in AV2 mode only or in all modes). However, it will only power up the receiver. It has to be turned off with the original remote or at the receiver itself.
Feb 09, 2009 | Yamaha RX-V463 Receiver
Turning OFF picture in picture!
I have an old Sony Trinitron; had the same problem... somehow turned on the pip while moving the television off its stand. I have neither the remote nor the manual.
Does your tv have a 'demo' button on the front? Mine does; when I pressed it, the pip disappeared!
Jan 06, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Emerson EWF2004 20" TV Logo
160 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
