Question about Samsung SyncMaster T200 LCD Monitor
After few minutes I have disturbance in picture on SM T200
Samsung SM T200 is connected with DVI to my PC. After I turn my PC on it's usualy working for few minutes normally but then I get a disturbance (buzz, noise) in the picture and with time there is even more noise until the monitor turns off by it self.
I'm not sure if this is a problem of a graphic card or a monitor
  • Thomas F. Schneider May 11, 2010
    Can you borrow another monitor to see which it is?
  • 3 Answers
I have almost the same problem and can't find a solution... hopefully the guy who made my computer know whats wrong with it...
my samsung syncmaster is also connected to the DVi port(digital)
and it's sometimes working for a day and other times for a minute of 5.
and now i get it always in games what i get is:
-screen go black and in the top left corner yuo see analog(VGA port)and then digital(DVI) again.
and this will continue for at least 5 min sometime it stops after that sometimes never and i need to reboot(1of 5 times that work sadly)
-i get a buzz sound while he is doing that.
-sometime i get a green flash in the shape of what i was doing and then he change again.
can anyone help me/us?
Posted on Aug 01, 2009
  • g0dverark_nl Nov 27, 2009
    it's youre graphics card and youre monitor just buy a new grqaphics card and sent the monitor to samsung, i had the same problem with my t200 on a ati radeon HD 4850 512 mb connected to dvi, and i sent it tobest buy to repair it but they dont even know what it is so just search for youre garraty and you will be fine just like me.
    ps: best buy did 11 weeks over it and it was still not working by then.
    srry for my bad english ^^
I have a HP LP20265 monitor, and it seems have problem, with signal detection.
well why not test it on another system
DT or LT
desk top or laptop.
why connect 2 data cables at once, this is SO wrong.
only 1 at a time.
Mar 09, 2017 | HP LP2065 Monitor
Samsung LN-T4671F HDMI PC hookup and Audio Problems
Pls bear with me, have you tried not using the HDMI/DVI cable but simple straight connection PC > Standard 15 pin VGA cable and audio cable that has "stereo mini-plug" on both ends to the PC IN of the Samsung?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 09, 2008 | Samsung LN-T4671F 46 in. LCD Television
wow ,, why not test the monitor on any other PC or laptop.
see if its good or bad.?
this is the only way to find this, unless guessing works.
i got lost in your post.
try 2 machines
the post photos of what screen does bad, words never work for telling graphics./
Mar 08, 2017 | HP LP2065 Monitor
Hi, I want to connect a new xbox 360 to my Samsung T200 lcd monitor. there is a VGI socket and a DVI socket in the back of the monitor. The VGA socket is already connected to my PC and I would like to...
You can only use one device at a time with the monitor.
Also the monitor doesn't have speakers, so you will not get any sound.
There is another device which you can use to connect both your computer and your xbox to the same monitor. It is called a KVM switch. You can buy it from a local store or online.
Sep 13, 2017 | Samsung SyncMaster T200 LCD Monitor
Acer Aspire 5536 only gives black screen when i connect power supply
  • Nothing is more annoying than a monitor that refuses to turn on. Make sure your Acer monitor is plugged in to a functioning outlet. If it's plugged into a power strip, try replacing it with a new one or moving the plug to a different outlet. Ensure that both ends of the power cable are plugged in firmly and securely, and that the connection to the monitor is not loose.
Cable Issues
  • Your Acer LCD monitor will usually accept DVI and VGA inputs. If you have an older computer, a VGA cable should work fine. If it doesn't have a VGA port, you'll need to obtain an inexpensive DVI to VGA adapter at your local computer store. A DVI cable, however, is compatible with most modern computers and offers superior picture quality over VGA. Make sure you're using the cable that's compatible with your system, and that you have the proper conversion adapter, if necessary.
Jun 19, 2012 | Computers & Internet
My sansung pn50a460s4dxza says it is 3d ready. how can i use this feature on my tv.
Your tv is a 2008 model, legacy 3d tv and requires a lot more than a current 3d HDTV does to view 3d. Today with a current 3d HDTV, Normally you only need a 3d source like a 3d Bluray movie and 3d glasses from Samsung and a HDMI cable connection from bluray player to HDTV. See below for your TV. You need a PC and IR emitter and Samsung 3d glasses plus user selected options on the tv.
Samsung 3-D Ready HDTV How do Samsung 3-D Ready HDTVs work?
Samsung 3-D Ready HDTVs are enabled by Digital Light Processing (DLP(R)) or Plasma Display Panel (PDP) engines that are capable of very fast refresh rates (120Hz). The inherent speed of these display technologies enables high quality stereoscopic 3-D by alternatively displaying left and right eye images. The display is synchronised with 3-D shutter glasses to provide the observer with a vivid perception of depth.
How do I connect my PC to a Samsung 3-D Ready HDTV?
The DVI output from the PC's graphics card must be connected to the TV's 3-D compatible HDMI port using a DVI-to-HDMI cable (or a HDMI cable plus a DVI to HDMI adaptor).
Alternatively, some newer graphics cards have a HDMI port instead of a DVI port. In this case, simply use a HDMI cable to connect the PC directly to the TV.
On all models, the 3-D compatible HDMI port is identified by the letters "DVI". (eg, "HDMI 3/DVI IN" or "HDMI 1/DVI IN")
What other equipment do I need to enjoy 3-D on my 3-D Ready HDTV?
  • Windows PC with DVI output
  • Compatible 3-D Shutter glasses and IR emitter with VESA compatible sync connector
How do I connect the IR emitter to the 3-D TV to support wireless 3-D shutter glasses?
The IR emitter should be connected to the "3D SYNC OUT" socket. The emitter should be placed on top of the TV with the LEDs facing towards the room. How do I turn the TV into 3-D mode?
Ensure that the TV source is set to "HDMI 3/DVI" (or "HDMI 1/DVI" for 720p models).
Plasma HDTVs Press the Tools button and select 3D Effect. Update from Off to Mode1.
May 04, 2011 | Samsung PN50C430 50Inch 720p Plasma HDTV...
How to i upload pictures from my samsung u600 with my usb cable?
Turn on your phone, connect to your pc, open windows explorer, locate your phone (usualy the last 'removable disk'), navigate to the location on your phone where the photo's are stored (usualy on the memory card), select, copy, navigate to your pc and the location where you want them to go, paste.
Jun 13, 2009 | Samsung SGH-U600 Cellular Phone
Connecting up a home cinema kit
Heya,
The good news is that the monitor and the Home cinema can be connected but you need to get a cable. Bad news is the cable did not come with it.
The monitor has D-SUB, DVI-D
so you need a HDMI to DVI-D connector then you need another cable to route the audio to the system which you should have.
like ebay item
Item number: 220341264176Hope it helps
Jan 10, 2009 | Wharfedale Televison & Video
Connect desktop PC w/ DVI and get a red screen
Fixed my own problem lol. Video card needs to be replaced.
Apr 25, 2008 | Protron PLTV-32 Television
Picture on my TV starts to flash after a few minutes of use
This problem is common in Samsung projection TVs. The DMD board is going bad.
Mar 21, 2008 | Samsung HL-R6167W 61" HDTV
Samsung SyncMaster T200 LCD Monitor Logo
341 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
