HP S3120N Pavilion Slimline Desktop Computer PC - REFURBISHED Logo
Anonymous Posted on Aug 21, 2012
Computer debugging viruses
Viruses and wont let me get on the web or anything or open any files
Christopher Fletcher
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Aug 21, 2012
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
2904
Points
41
Well more data is needed on this, if you have a subscription to mcafee they are currently experiencing an update outage for all computers with windows XP/Vista/and 7. if this is you then unistall your mcafee and reboot the computer once your back online you can then redownload the mcafee.
if not then more info is needed,OS and year and make of computer and what kind of virus you are refering to. ie what is your computer currently doing or how is it reacting
2answers
I have virus problem need to solve it and protect my laptop from virus
If it is a bad virus that won't let you do anything on the computer, follow the instructions on this link. If you can install programs on your computer, follow only steps 7 and 8 from the above link.
My files on my desktop wont open up and most of my documents have all turned to short cuts - because of a virus called Fucox.exe - please if anyone has any idea as to how to remove this devil and restore...
This seems to be a pretty bad virus that won't let you do anything on the computer, so follow the instructions on this link. If you can install programs on your computer, follow only steps 7 and 8 from the above link.
Running script error
Method 1: Disable script debugging loadTOCNode(3, 'whattotry'); If the only sign of a problem is the error message, and Web sites are working, you can probably ignore the error. Also, if the problem only happens on one or two Web pages, it might be a problem with those pages. If you decide to ignore the errors, you can disable script debugging.
Note If this problem occurs on more than one or two sites, do not disable script debugging. Go to method 2 now.
To turn off the Scripting Debugger in Internet Explorer 6, follow these steps:
  1. On the Tools menu, click Internet Options.
  2. On the Advanced tab, click to select the Disable script debugging check box. and then click OK .
To turn off notification about every script error in Internet Explorer 7, follow these steps:
  2. On the Advanced tab, click to clear the Display a notification about every script error check box, and then click OK.
Method 2: Test a Web page from another user account, another browser, and another computer loadTOCNode(3, 'whattotry'); Use another user account, another browser, or another computer to view the Web pages that triggered a script error to determine whether the problem persists. If the script error persists, there may be a problem with the way the Web page is written. You can probably ignore the error and disable script debugging as described in method 1.
If the script error does not occur when you view the Web page from another user account, browser, or computer, the problem may be caused by files or by settings on your computer. Go to method 3 to continue to troubleshoot. Method 3: Verify that Active Scripting, ActiveX, and Java are not being blocked by Internet Explorer loadTOCNode(3, 'whattotry'); Active scripting, ActiveX, and Java are all involved in shaping the way information displays on a Web page. If these are blocked on your computer, it may disrupt the display of the Web page. Reset the Internet Explorer security settings to make sure these are not blocked. To do this, follow these steps:
  1. Start Internet Explorer.
  2. On the Tools menu, click Internet Options.
  3. In the Internet Options dialog box, click the Security tab.
  4. Click Default Level.
  5. Click OK.
Note ActiveX controls and Java programs are turned off at the High security level in Internet Explorer.
Try to open a Web page where you previously received a scripting error. If you do not receive the error, the issue is resolved. If the issue persists, go to Method 4. Method 4: Remove all the temporary Internet-related files loadTOCNode(3, 'whattotry'); Every time that you open a browser to view a Web page, your computer stores a local copy of that Web page in a temporary file. If the size of the temporary Internet files folder becomes too large, some display problems may occur when you open Web pages. Periodically clearing the folder might help resolve the issue.
To remove all the temporary Internet-related files from your computer when you use Internet Explorer 6, follow these steps:
  3. Click the General tab.
  4. Under Temporary Internet files, click Settings.
  5. Click Delete Files, and then click OK.
  6. Click Delete Cookies, and then click OK.
  7. Under History, click Clear History, and then click Yes.
  8. Click OK.
To remove all the temporary Internet-related files from your computer when you use Internet Explorer 7, follow these steps:
  4. Under Browsing History, click Delete, and when you are prompted, click Yes to confirm.
  5. In the Delete Browsing History dialog box, under Temporary Internet Files, click Delete Files, and when you are prompted, click Yes to confirm.
  6. Under Cookies, click Delete Cookies, and when you are prompted, click Yes to confirm.
  7. Under History, click Delete History, and when you are prompted, click Yes to confirm.
  8. Click Close, and then click OK to close the Internet Options dialog box.
Try to open a Web page where you previously received a scripting error. If you do not receive the error, the issue is resolved. If the issue persists, go to method 5. Method 5: Install the latest service pack and software updates for Internet Explorer 6 or Internet Explorer 7 loadTOCNode(3, 'whattotry'); If you do not have the latest service pack or software upgrades for Internet Explorer 6 or 7, download and install them. They may contain updates that can help resolve the issue.
2answers
My laptop toshiba satellite 1405 S151 has a virus
Since you are almost struck even with an antivirus. I would recommend you to try an OS restore to a good know previous restore point. This could help because the virus might have affected the registry keys and its manual repair is very tedious job.
Please come abck and rate my solution if it turns to be helpful for you, or also if you need more clarification. Thnx
15helpful
My facebook games wont load or they go half way. I tried cleaning catche, refreshing and it still wont work comes up with errors on page
please update your java files, go to my computer > control panel open java control panel, and select update. also games run better in ir due to the virtual machine environment. jre the java files call several hundred files to load your web games. this has major issues on speed, also note a virus scanner may be running in background,.this will kill bad files or slow loading files possibly.
Rebooting pc
just because you have an anti virus doesn't mean you cannot get a virus.... the best thing to do at this point is to perform a repair on windows...Here is a walk through or simply bring it in to your local computer shop....
Hpqthb08.exe and HPQDocViewer.exe error messages
Make your system virus and spy ware free. Then unistall all the softwware you needed from HP CD or Web site. Hope this will solve your problem.
2answers
Internet connection is corrupt
Which website? Sounds like you may either have a virus or your LSP is corrupt (which could also be caused by a virus). Try running Spybot-S&D (http://fileforum.betanews.com/detail/Spybot_Search_and_Destroy/1043809773/1), updating it after installing, running a scan, and deleting anything it finds. Hopefully that helps.
3answers
Two errors. The first is RUN TIME ERROR
Hi, have you run a virus scan lately? If you sure your system is clean then I would reccomend you run the XP repair console. You do this by reloading XP from your CD and at the SECOND PROMPT select repair, this will allow you to reload XP and save your current settings, this will repair any corrupt files and install any missing ones. You will have to re-activate with Microsoft. Regards mistyman
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
