Question about Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Ps3 won't display video on my 40 inch Sony xbr hdtv
I tried the suggestion to reset of the ps by turning off the power and waiting for it to beep 3 times - it didn't work. The component video won't work either. I have a sony xbr 40 inch hdtv crt with a dvi connection. I have direct Tv hooked  up via hdmi and it works fine. I hooked up  my PS3 via Dvi/HDMI and it worked perfectly for 6 months until now. There is no picture from the PS, so I changed cables to no avail. I connected the DirectTV HDMI cable to the PS and that didn't work either. I even exchanged my ps3 for a new one and that didn't work. I changed the output settings in the ps menu (hdmi, conponent video and back again) and this didn't work. I downloaded updates of ps3 software. Nothing is working. Lastly, I watch my blurays on my ps hooked to my projector and this works with no problem. Is there something wrong with my TV? Why would my directTV hd work on the sony but not the ps?  Thanks for the help. Max
3 Suggested Answers
  • 12 Answers
SOURCE: ps3 won't display on hdtv via dvi
Re-Set the PS-3, by pressing and holding down the power button (front panel) this hard re-sets the unit and yo can then reconfigure via the composite video cable it came with, back to HDMI / DVI
Posted on Dec 17, 2008
  • 82 Answers
SOURCE: Use sony xbr 32" 1080p 120hz. Connected to bluray
YOU NEED TO RESOLDER SOME RESISTORS THAT BECOME LOOSE WITH THE TVS TEMPERATURE... YOU CAN GET A MANUAL TO DO IT YOUR SELF.. AT TVPARTSANDMANUALS ONLINE
Posted on Dec 21, 2010
How do i get the ps3 to display on my tv ps lights up disc inserted etc but no activity on the tv screen
ok you have to reset the ps3 by turning of backswitch wait 10 seconds turn on the backswitch then press and hold down the front power button for 10 seconds you should hear 2-3 beeps that does it just wait and the video settings have automatically detected your tv settings and are going to ask you to save hit x to save display settings on ps3 remote problem solved.
Dec 15, 2010 | Sony Playstation 3 (PS3) Console
Why will my ps3 not wotk on my samsung tv
Please try these steps to reset your display :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep when you first press it then beep again 5 seconds later. Release the power button when you hear this second beep.
Step 3. Wait for your PS3 display to reset.
Hopefully this should sort out your problem.
Hope this helps and thank you for using FixYa.
Oct 27, 2010 | Sony Playstation 3 (PS3) Console
Ive turned on my ps3 but i cant see the screen on my tv
Hi there, please try the following steps :
Step 1 Turn the PS3 off into standby (red light on)
Step 2 Press and hold the power button. It will beep when you first press it and then beep again 5 seconds later. Release the power button when you hear this second beep
Step 3 Wait for the PS3 to boot up
This basically resets the video display back to standard definition.
Oct 16, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 doesn't display video,only audio works
Try the following steps to solve your PS3 problem :
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Aug 28, 2010 | Sony Playstation 3 (PS3) Console
Switch my playstation to hdmi.. Played switched it back cant get any picture
Please try the following to reset the display settings back to standard.
Turn the PS3 off into standby mode (red light on)
Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later. Let go of the power button when you hear this second beep.
Wait for the PS3 display to be reset
Hope this helps
May 23, 2010 | Sony Playstation 3 (PS3) Console
Turns on, but not sending picture or sound to tv, and receiver, or even just tvi have an older 80gig ps3 irreplaceable, all info on HD and plays ps-1,2,and 3 games, need help
  • Have your ps3 in standby mode (red light).
  • Now, press and hold the power button in the front down. Your ps32_bing.gif will beep twice. Let it go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
try this
May 08, 2010 | Sony Playstation 3 (PS3) Console
My so moved his ps 3 from the HDTV (HDMI) cable
Nothing wrong, you just need to reset the video back to default.
While the PS3 is off (red led), hold down the power button until you hear the SECOND beep, quickly release.
Video should be up now :)
Nov 21, 2009 | Sony Playstation 3 (PS3) Console
Initial set up of PS3. initial set up screen not displayed
When tv and ps3 backswitch turned on hold down the front power button when off until the ps3 has done a double beep after the intitial beep and wait for a max of 1 min and initial set up screen should appear
Apr 17, 2009 | Sony Playstation 3 (PS3) Console
Ps3 won't display on hdtv via dvi
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
No Display
Hmm ok I suggest connecting the av coords again then turn the ps3 off then on wait for the red light. Then push the power button down until you hear it beep then reset itself... common issue may take 5-10 times to work but it will!
Jun 28, 2008 | Sony Playstation 3 (PS3) Console
Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV Logo
169 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
