Question about Sony Cyber-Shot DSC-P41 Digital Camera
What do I do?
My camera will turn on in the picture review mode, but it will not stay on when switched to the picture taking mode. The message I receive is: Turn the power off and on again. I turned the power off and on again several times with no luck.
  • 4 more comments
  • Christina51 Dec 01, 2007
    I just had my sony cyber shot do the same thing. I was in the middle of using it when I used the zoom. Now all I get is the message turn power off and turn it on again.....
    Christina Routt
    419-233-5698
    croutt@woh.rr.com
    My camera is about 3 yrs old...
  • Anonymous Dec 29, 2007
    I have tried every thing but no good have simular problem please can you help,great camera easy friendly until now??? help live brisbane aussie anyone here you can recommmend?????
  • CWineland82 Jan 01, 2008
    I do not get the power on and then off message. my just does not power on. If I am in the picture view mode, all systems are go...but as soon as I switch to the picture/video 'maker', the camera just shuts off. It is not the batteries either. I've tried with 3 new sets. Help. Please
  • krystinazzz Jan 03, 2008
    I have the same problem. I can review the pictures on my memory stick, but no longer can take pictures. It just shows a black screen when i put in it the "take picture" mode. I dont know what to do. I have had this camera for about 3 years and have never had any problems. I'm bummed.
  • TVEE777 Aug 14, 2008
    When I turn on my camera I get the message NO FILE IN THIS FOLDER and if I awitch lever to take pictures the camera shuts off
  • Anonymous Jan 05, 2009
    My Sony Cyber-Shot DSC-P41 has the same problem... It only turn on and stay on in review mode.. If i do get it to come on in picture taking mode it says my batteries are dead and shuts down again.. even though while it is in review mode it says my batteries are fully charged
    Sergeant:
    Champion:
  • 326 Answers
The problem with your camera can be in optical (lens) unit. Part number is: 884875701 If you need more info please advice.
Posted on Apr 03, 2007
SOURCE:
Mode Switch - Stuck in view mode and won't take pictures
Did you try taking out the batteries for a few hours to power cycle the camera?
Mar 25, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Canon s2IS when I turn the camera on in review mode the LCD screen displays pictures one after another. Cannot stop the picture review except to turn off the camera. In camera mode the menu button and...
Please do the followings.
1. Turn off the camera.
2. Remove the memory card.
3. Remove the batteries.
4. Wait at least 3-5 minutes.
5. Place the memory card and batteries.
6. Turn on the camera in any mode except review mode.
7. Take any ordinary picture.
8. Change the camera mode to review.
9. What happened now. Is everything normal. if not please write a comment to explain the situation.
Jun 03, 2010 | Canon PowerShot S2 IS Digital Camera
I TURN ON MY A70 AND I GET A VIEW OF THE LAST PICTURE I TO TOOK.
The camera is stuck in picture review mode. Try sliding the mode switch back and forth a couple times, and leave it in camera mode to see if this corrects the problem.
Apr 02, 2009 | Canon PowerShot A70 Digital Camera
Can't turn off/disable optimize image screen- nikon d80
Ok, all you need to do is:
1.Hold the camera normally like you would take a picture.
2.Turn it on and review a picture.
3. While looking at a picture, take your index (pointer) finger and rotate the front "wheel" right under the shutter release button. This switches the viewing mode, and should solve your problem.
Jan 12, 2009 | Nikon D80 Digital Camera with 18-135mm...
HP Digital Camera - M425 - Stuck in review mode, won't switch to capture mode
I just fixed my daughters camera with this problem. First go to the capture mode and see if the reason you are in review mode is because the camera thinks it is docked. If so, look at the dock port on the bottom of the camera. ( May need to magnify it to see in there ) Look for any green corrosion between the contacts. Her's has this corossion between two pairs of the contacts. I took a jewelers screw driver and scraped out the corrosion and then blew canned air in there to remove it. Turned it on and now it works fine. I have a feeling that the battery compartment is venting through this port and the small amount of acid vapor produced as the batteries discharge is causing the contacts to get this corrosion.
Jan 13, 2008 | HP Photosmart M425 Digital Camera
Power Wont stay on when in Camera mode
I have the same problem. Can anyone help please?
Dec 23, 2007 | Sony Cyber-Shot DSC-P71 Digital Camera
Sony cybershot dsc-s600
Hi, here is a temporary solution that might work for you as it did for me:
1: turn on the camera in picture/movie review mode
2: turn the screen off (not the camera)
3: change from review picture/movie mode to take picture/movie mode
4: turn the screen back on.
You should now be able to take pictures and record.
Hope this is of some help.
Apr 09, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Broken
If there is no error displayed, you've got weak batteries. If they're chargeable, charge them AT LEAST 14 hours then try. If the batteries are a couple years old, try new rechargeables.
Dec 05, 2006 | Sony Cyber-Shot DSC-P100 Digital Camera
Viewing is fine, taking pictures is not
This sounds like what started happening with my camera a few weeks ago. I found that turning the LCD screen off during picture-taking allows me to take pictures. I then have to go into review mode to look at the pictures I took using the LCD screen. Definitely not a great fix. I'm trying to locate a firmware upgrade that may solve it.
Sep 01, 2006 | Sony Cyber-Shot DSC-W1 Digital Camera
Sony Cyber-Shot DSC-P41 Digital Camera Logo
81 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
