Question about Garmin nuvi 255W GPS Receiver
255w in a loop - loading maps, then restarts...can't recharge
Bought a 255w one week ago and used it successfully for 4 days. Had it plugged into lighter for recharging. On 5th day, Garmin won't turn on. Assume battery dead, but when I plug it in, it goes into a loop - Garmin logo, 'loading maps', two beeps...repeat...repeat...etc...until you unplug. Assume the battery is dead, but it won't charge without going into the never-ending loop. Have removed SD card, same problem. Have tried whole process with wall charger, too. Same thing. Am not able to do a hard reset. Just continuing loop. Advice?
  • rose_russ Dec 26, 2008
    We have encountered the same problem!  Any solutions would be appreciated.
  • Anonymous Dec 31, 2008
    This happened to me on the first day I had mine (yesterday!) and I just pressed the rest button on the back and it came back on. It's been working fine since then... hope that helps.
    Problem Solver:
Use a USB connection to your computer and let it charge for three hours. Also download updates while your at it. Cigarette lighter charger is not efficient
Posted on Oct 01, 2009
I had something similar happen to my 785 on a 4000 mile trip. I was on hold on the phone with Garmin for 49 minutes before the call was dropped. On my own in rural Iowa somewhere between Grinnell and Decorah, I fixed mine by getting darn fast at drilling down to a reset to defaults button. It took a few times but by the 7th or 8th try I was able to get to Settings, Restore Defaults, and finish the restore process. After the Restore the unit has worked fine for another day of driving.
Posted on May 30, 2010
I just bought my garmin nuvi 255w about two weeks ago. This last weekend we used it to go down to New Glarus, WI. In our route a section South of where you turn onto US23 it does not reconnize and keeps on...
Unfortunately there is always a delay between roads getting built and maps getting updated, verified, and finally into products in the shops. On top of all that, the nuvi 255w is a model which has been available for a while now, so if the store had your example lying in stock for a number of months it may also have spent a few months before that in a warehouse before supply to the retailer. Your 18 month to 2 years may sound plenty of time to ensure that your unit has the latest mapping, but in reality it may effectively be the best part of a whole year less.
Garmin recognise that this is a problem so have the "nuMaps Guarantee program". If you buy a new nuvi and register the product within 60 days of it first being turned on and acquiring a satellite signal, you will be offered one free map update subject to simple conditions. To find out what they are, click here.
To find out more about which map updates are available and how to install them, click here.
I hope that my answer has been of use; please take a moment to rate my reply.
Sep 20, 2010 | Garmin nuvi 255W GPS Receiver
Garmin nuvi® 255W Car GPS Receiver. Problem: Reboots during Map
The simple way is to send the unit to Garmin they will load the maps for free.
If you keep trying - try this -
With your thumb in the lower right corner of the screen - pushing in - like there is an X there - [ push with your thumb before you turn it on] Turn it on -
when this screen comes up - push YES -
then try your maps.
If they do not load on your pc [ which must have the unit hooked up and a legit copy of the newest maps ] then send the unit to Garmin. They will load your maps for you FREE. 86278d7.jpg
May 11, 2010 | Garmin nuvi 255W GPS Receiver
Trying to start but its try to load maps and then
Please check the rear charging port to see if its loose. This is a common problem and if the connector is loose, the battery will never charge and the unit will die at loading the maps. Please see this link for more info:
http://www.sharc.net/gps_charger_repair.htm
- Jim
Mar 04, 2010 | Garmin nuvi 255W GPS Receiver
Will not turn on
I have a garmin 255W when turning on all itdoes is go to a white screen with black dot thatsay Press dot .It wont turn on how do you fix this
Jan 19, 2010 | Garmin nuvi 255W GPS Receiver
Garmin nuvi 255w trying to register and update maps. Got the Firefox addon-loaded successfully, restarted firefox; plugged in usb cable to pc and GPS; can not find my device. Tried XP sp3 desktop and vista...
The problem was following the Garmin instructions too closely. What I found via a GPS forum was that some USB cables can be finicky and trying different USB cables may solve the problem. In my case I found I had to turn the nuvi 255W on normally during registration; then connect the USB cable to device and PC. Then the registration and download worked.
The documentation is not clear on this.
Found I had the latest map; but did upgrade my firmware from 5.90 to 6.10.
Dec 29, 2009 | Garmin nuvi 255W GPS Receiver
I'm on my second nuvi 255w. As before this ine has
I am in the same boat as you.. I am on my 2nd 255w unit as well. The first one lasted 2 weeks. This one about 45 days. The thing I noticed, which may be coincidence, is I updated the software and map a couple days prior on each unit before problem occured. Last night the 2nd one lost satelite for about 5 hrs, an area I deliver pizza's in everday with no other problems. No mountains, no tall buidlings, yet I decided then to power off unit completely, stand outside and turn unit on. I waited about 10 minutes then put 255w back in vehicle in which at that time still was not working. But 30 minutes later when I got back into vehicle it was working again for the rest of the night. Not sure if standing outside corrected or not, but it is working again. I would be curious to know if the software update and map update plays a part in the problem.
Sep 25, 2009 | Garmin nuvi 255W GPS Receiver
My new nuvi 255w will not start displaying info
When using a usb from your computer it is only a trickle
charge to the garmin. Will take a day or two to fully charge. If you use a the cigarette lighter plug that came WITH the garmin, it will fully charge in 4 hours. Stick with garmin approved plugs and all will go smooth. I know, I made the same error.
May 15, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
New 255w does not work.
Sorry but you'll have to call Garmin. Never purchase anything from a store going out of business unless you check it out in the store and your happy it works.
Feb 09, 2009 | Garmin nuvi 255W GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
2,004 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
