Question about Uniden DCT648-3 Cordless Phone
Lcd screen my LCD screen displays nothing but rectangles a caller id, no nothing...just rectangles
3 Suggested Answers
  • 201 Answers
SOURCE: caller id
This is a feature from your phone company you may have to pay extra for. Caller ID information is normally transmitted just after the first ring. When you are using call waiting there is no ring.
Posted on Jul 07, 2007
  • 201 Answers
SOURCE: I have call waiting and caller ID through my phone
You're right, at least one of them should. You should contact your telephone company and ensure you have Caller ID while on Call Waiting service (CIDCW) - it's not always the same as just Caller ID. Sometimes they'll want even more money. :)
Posted on Mar 14, 2009
  • 8619 Answers
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Posted on Aug 16, 2009
0 characters
1 Points
I have caller id service with my phone company; Why does my Radio Shack heavy duty wall phone with caller id display all rows of 8's in the caller id area?
It's radio shack... kidding, depending upon the age of it, the lcd black/grey display may have gone bad... from dropping or age or defect.
Feb 12, 2015 | Radio Shack Phones
I just received KX-T7730 phone with an LCD screen and it is not showing the caller ID # that is dialing in. It only displays CO 1. The previous phone similar to KX-T7730 shows the caller id #. So how can I...
The one who can show the caller ID when someone call is the caller only. He/she can set to hide his/her number ID in their phone so we can't see it. We can't force to see this caller ID, but if this calls disturbed you, you can install call blocker and only allow certain incoming call to be recieved.
Hope his help and rate please.
Jan 17, 2011 | Panasonic KX-T7730 Corded Phone
Caller id
try pressing the transfer button when the phone is ringing (without lifting the handset) - it should work through a cycle of displays until the phone number is displayed.
Nov 18, 2008 | Phones
Programing Caller ID display on my Toshiba DKT2010SD
is there any thing on the screen atm on the direct page of ur phone its saying press function and go though the settings or it says Caller ID is not available in all areas. Please check with your local phone company.
Jul 16, 2008 | Toshiba DKT2010SD Phone
Caller ID
Does this happen for all incoming calls? Some phones have their caller ID hidden by their network service.
May 15, 2008 | Panasonic KX-T7730 Corded Phone
Caller ID display
might be the IP funtion is on. this is not available in the USA. press SET/SAVE, press Up to select "SET 4 AUTO IP", press SET/SAVE to select, press UP to change setting, press SET/SAVE to confirm. if you'd like a copy of my manual for the phone, email me at and i will send a copy in 2 different formats so you'll be sure to be able to open at least one of them. hope i helped.
Apr 14, 2008 | Innovage Speaker/Caller ID* LCD Touch...
No lcd display-cannot set up phone
try replacing the batteries in the base
Jan 02, 2008 | Innovage 1502084 Corded Phone
Caller id
Unfortunately just adding caller ID to your phone line will not work with many business phone systems, especially older systems.
You can have this phone on one of several different Toshiba phone systems. The system must have caller ID equipment installed and programmed correctly for caller ID information to be shown on your phone's display.
Caller ID information is transmitted between the first and second ring. With business phone systems the system itself needs to collect this information and then pass it along to any phones that are programmed to ring at any given time.
Oct 26, 2007 | Toshiba DKT-2010 Corded Phone
LCD screen only displays information when phone is off the hook, goes blank when you hang phone up.
Aug 02, 2007 | Innovage Speaker/Caller ID* LCD Touch...
Uniden DCT648-3 Cordless Phone Logo
24 people viewed this question
Top Uniden Phones Experts
Dave Ellis
Are you an Uniden Phone Expert? Answer questions, earn points and help others
