Cars & Trucks Logo
Roc Frazier Posted on Aug 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replace crankshaft position sensor in 2003 dodge caravan 3.3 V6
What is the location of the crankshaft position sensor in a 2003 dodge caravan SE V6 engine please HELP!!!
Robert Gleba
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 29, 2019
Robert Gleba
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
3768
Points
I found the crankshaft and my 2003 Dodge Caravan but I cannot separate it from the plug I got the little red clip out how the hell do I get it The sensor separate it from the plug because they don't give you lotta room and pulling on it Like 30 minutesand I can't get the two separate it so I can take out the sensor also how do you take that out once I get them separated
Stephen
Level 3:
Top Expert:
  • Dodge Master 21,873 Answers
  • Posted on Aug 21, 2012
 Stephen
Dodge Master
Level 3:
Top Expert:
Answers
21873
Questions
0
Helped
6209531
Points
67230
According to Haynes, the V6 engine has the sensor mounted in the bellhousing on the back of the engine.
5 Related Answers
Anonymous
  • 1392 Answers
  • Posted on Jun 23, 2009
SOURCE: 2004 DODGE STRATUS 2.7L, Location of Crankshaft Position Sensor?
it is located on the right side of the motor, in the trans area. Actually in the bell housing.
Anonymous
  • 4 Answers
  • Posted on Jul 03, 2009
SOURCE: Crank shaft sensor location.
Underneath on the transmission housing.
co7196
Ned C Cook
  • 3433 Answers
  • Posted on Sep 28, 2009
SOURCE: need location of crankshaft position sensor on a
The crank sensor should be found at the front by the crank pully. it is bolted to the engine wuth a wire connection plug on it.
Anonymous
  • 90 Answers
  • Posted on Jan 31, 2009
SOURCE: replace spark plug 2003 dodge caravan v6
hi the front ones are not bad but the back ones you will have to get from under the van.( do them one at a time)
Anonymous
  • 10 Answers
  • Posted on Jun 13, 2009
SOURCE: location of crankshaft position sensor Jeep grand cherokee 1997
left rear of engine block,on transmission bell housing.best way from top under brake booster use a wrench,
1helpful
2answers
My 1995 dodge caravan trys to start but wont im getting no spark to my spark plugs
Hi mate start at the easiest point which will be to check your EARTH to make sure everything is earthed.
Location of Crankshaft sensor on 2005 Dodge Caravan SE: 2.4 Liter. Is crankshaft sensor location the same as 3.3 Liter?
The crankshaft position sensor mounts to the engine block behind the alternator near the oil filter.
1helpful
Crankshaft position sensor
1996 Dodge Truck Caravan 2WD 3.0L MFI 6cyl
The Crankshaft Position Sensor is located:Under hood, driver side, rear engine area, mounted top rear of engine .click here and enlarge picture,it's number 9,send picture to your library and you can enlarge even more.Here's the part.Here's how to remove.
Where is the crankshaft position sensor on a 2003 dodge caravan 33L V6 engine
Hi there:
The 3.3/3.8L crankshaft sensor is located on the rear of the transmission housing, above the differential housing (The bottom of the sensor is positioned next to the drive plate...
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
2005 dodge caravan 2.4 , location of crankshaft position sensor?
2005 Dodge Caravan SE 2.4L Engine. Crank Shaft Sensor is located on the front of the engine (side toward the radiator) and right below the starter.
Raise the vehicle on stands or ramps. From under the vechcle, unclip the wire plug. Loosen and remove the 8mm bolt. Pull out old sensor.
This CAN be done WITHOUT removing the starter. Easiest way is to use a deep 8mm x 1/4” drive socket and good lighting. I had to use vise grips to grip and pul out the old sensor. It is okay to twist and pull.
NOTE: I have seen many posts placing this sensor in all kinds of places. For this vehicle, this is where it is located. If you have a different engine or year, it could be located someplace else.
2helpful
2answers
Want to locate where is the crankshaft sensor on 2005 dodge grand carvan 3.3 eng
Hello brscwb,
Below is an image depicting the location of the crank sensor.
I hope this helps.
Regards,
natven
1helpful
2answers
Need to know where crankshaft sensor is located on 3.3L 2003 DODGE CARAVAN SE
The 3.3/3.8L crankshaft sensor is located on the rear of the transmission housing, above the differential housing.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
