Robertshaw 2000Wi per-CL (160-15-L) is the name of the control. It does come back on after you unplug and replug, but it no longer comes on automatically.
You have the Robershaw wiper gas control valve.
Here are error codes and troubleshoot table for that gas control.
http://waterheatertimer.org/pdf/Robert-shaw-gas-control-error-codes-1610.pdf
Here is general service manual for power vent water heaters.
http://waterheatertimer.org/pdf/Power-vent-water-heater-service-manual.pdf
Here is general parts list for that water heater, 2009:
http://waterheatertimer.org/pdf/Rheem-power-vent-RS-parts.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: I have a Rheem 50 Gal. Power Vent 2 hot water tank
Don, if you have done this before go for it. If not call a pro,you will thank yourself later!
SOURCE: water heater rheem EverKleen Model
What you are hearing is the noise of the water percolating around the element. This usually is a sign that the sediment in the tank is getting close to the bottom element and limiting the flow of the water around the heating element. This causes the water to boil around the element.
Here is a tip about how to clean the sediment out of your hot water heater..
http://www.fixya.com/support/r4041115-clean_hot_water_heater
heatman101
