Question about Panasonic PV-GS31 Mini DV Digital Camcorder
No sd card works on my pv-gs31,what's wro
Have tried differ cards
5 Suggested Answers
SOURCE:
sandrew
  • 2961 Answers
SOURCE: mpeg recording to SD card
This may have something to do with the fact that the camera powers down before the battery is exhausted as the maximum run time is 140 mins which is roughly the time you say it stays on for.
Posted on Oct 05, 2007
  • 599 Answers
SOURCE: SD card unreadable
does card have notch / ...switch.... on side that needs slid to other position to be read?
Posted on Dec 21, 2008
Shadowmaru
  • 33 Answers
SOURCE: Panasonic PVGS-50D SD memory card
Check your manual for the max supported SD card size. Most likely it will either support a minimum of 2-4 gb :)
So yes you can get larger cards for your PV GS 50D
Regards,
Shadowmaru
Posted on Feb 11, 2009
  • 159 Answers
SOURCE: When I use different SD
Check with the instruction manual for the camcorder which type and capacity SD cards it will "support" and use only the specified cards. The camera will reject any card with a greater Gb capacity than it's system can support.
The more recent your camera the greater card memory capacity will be supported.
Posted on Sep 20, 2011
No display
try swapping or borrowing a different monitor first- doesnt work pull out video card turn on computer then shut it off, put back in video card- does not work- replace video card with borrowed video card - doesnt work.try different vodeo card in different slot.
Oct 05, 2012 | Dell OptiPlex 380 PC Desktop
My Sandisk 2GB micro SD card will not re-format and hence remove corrupted files using the Windows format tool. Plus files will not delete at all, and just reappear!!! Is the card gone for good?
To be honest, once you're getting this kind of problem, the card can no longer use. You need to buy a new card.
However, I would suggest to try different things first:
1. If you're trying to reformat the card using the SD adapter or card reader, you may want to try to use different adapter or different card reader.
2. You may try different computer as well.
If the same problem occur, then there's no other option but to buy a new one.
Thank you and good luck!
Nov 07, 2010 | SanDisk 2GB microSD Memory Card
Tried two different brand sd cards. c533 tries to
Try turning the camera off and then back on.Ensure that the memory card is the proper type for the camera. If the memory card is the proper type, try re- formatting the card using the Format option in the Delete sub-menu of the Playback Menu. If it will not format, it is probably corrupted. Replace the memory card
Jun 30, 2010 | Kodak EasyShare C533 Digital Camera
Dispaly
You haven't given us enough information to give a "good" solution.
Try the video-card in another computer.
Try connecting a different monitor to the video-card.
Try a different "data" cable between the video-card and the monitor.
May 26, 2010 | ASUS V9400-X/TD GeForce MX 4000, (128 MB)...
I cant figure out how to use the memory card reader, whenever I plug it into the computer nothing shows up. What do i do?
Make sure that the memory card is properly seated inside the card reader.
Try different cable.
Verify with the manufacturer, if this card reader is a Plug-n-Play or if you need to install a driver to the computer.
Try connecting it to different computer. Or try different types of memory cards (the cards should be supported).
If same problem occur, you need to contact the reseller, because the card reader could be defective.
Mar 15, 2010 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
Won't post, no beep. No display on monitor. Tried different AGP video card, different memory. I have unplugged everything but the AGP card and hard drive. The monitor works on a different computer so...
Basically, display card, RAM and processor are the ones affecting the display. IF trying different memory and video card doesnot help. Try changing the different processor. Thanx with regards Sajan
Jan 21, 2010 | Abit IC7-MAX3 Motherboard
It doesn't read when i plugged in any computer using card reader
You need to try different steps to isolate the problem.
1. Make sure that the card is properly inserted to the card reader.
2. Try connecting the card reader into different USB ports of the computer.
3. Try connecting it into different computer. If you get the same problem.
4. Try another card reader.
5. Make sure that there's no password set to your memory card. Because if there's a password set to it, there's no computer that could detect and read it.
Good luck and have a good evening!
Jan 19, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
Cant upload all photos from my camera They are all the same size & format. The camera has not been dropped or anything. This problem stsrted a few weeks ago.
Possible solutions:
Remember you need to turn the camera on when transferring.
Try a different USB outlet
Try a different cable
Try a different computer.
The card that you currently have might be faulty.
Format the card, note this will erase all pictures currently stored on the card.
Please also try another card.
Jan 02, 2010 | Kodak EasyShare One Digital Camera
E71 memory card unreadable
please check it with another battery
May 03, 2009 | Nokia E71 Smartphone
Panasonic PV-GS31 Mini DV Digital Camcorder Logo
81 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
