Question about Frigidaire Affinity ATF7000ES Front Load Washer
Frigidaire Affinity front load washer will not spin
It does everything else. When it comes to the spin cycle, it will turn slowly, but not at the speed that it is supposed to spin. Also there is more noise than I expected. The unit is only 13 month old. There is no error code at all.
  • brolle Jan 22, 2009
    It fails to wring out some loads on wash settings. Appears to be related to "out of balance" condition because no single item will achieve full spin speed. Add a second similar item to the wash/spin and it will reach full spin speed. Some full loads will fail to reach high speed spin. Suspect an over-sensitive out-of -balance sensor.
    Does anyone have a solution?
    Problem Solver:
  • 12 Answers
Sounds like the impeller on the drain pump is blocked. Noise could be coins trapped in drum. Check filter thoroughly, if you cannot remove blockage you may have to remove tubes from pump to clear out any blockage.
Posted on Dec 20, 2008
Where is the pressure calibration switch on an affinity front load washer?
Hello garrett_lind, I appreciate your inquiry!
From my understanding you are searching for the pressure calibration switch on your Frigidaire washer due to the fact that it is not spinning on the last cycle. Some possibilities as to why your appliance is not spinning could be your timer or drain pump. I could not locate steps to access the pressure switch but for electrical components I would recommend having a professional come out to properly diagnose and repair the appliance. -Matt
Aug 12, 2014 | Frigidaire Affinity ATF7000ES Front Load...
Everything works but it does not spin
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies that the auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to address the issue. Click on the link below for the complete and detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Dec 29, 2010 | Frigidaire Affinity ATF7000E Front Load...
Will not spin during spin portion of cycles. it rotates slowly cw and ccw but no fast spin
It's either a bad door switch, or motor control board. Definitely easier and cheaper to try changint he door switch first, as it fails much more often. Part number is 131763202
Apr 06, 2010 | Frigidaire Affinity ATF7000E Front Load...
How to diagnose
Sounds like your motor is blown. That's going to require a repairman.
Mar 31, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Washing Machines Logo
612 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
