Question about Zenith Z44SZ80 Television
TIMER THAT DETECTS THE SINGAL
IT WILL PLAY FOR 10 MINS. THEN OFF IT GOES. THE MENUE TELLS THAT IF THE TV DONT DETECT A SINGAL IT WWELL CUT OFF AFTER 10 MINS. HOW CAN I FIX OR
DISABLE IT.
THANKS
BAMA REPAIR MAN
Why does it shut down after it plays about 5 seconds of a VHS tape?
VCR's have an inbuilt computer that detects what the mechanism is doing. If for example a fault on the mechanical side has developed the systems will detect this and shut down the unit to prevent further damage.
If investigations into the mechanism reveal no faults. Then it could be the mode switch that is faulty. The mode switch is part of the mechanism and as the unit goes into each mode (play - fast forward etc) the switch will be in a position that tells the computer that the mechanism is in one of the modes. The switch can be out of position due to a mechanical fault, or it can give a false signal to the computer by being faulty itself.
Jan 07, 2016 | Televison & Video
The Netflix screen tells me I am not connected to the internet. What can I do to get reconnected.?
Go to your TV settings.... see if the TV detects the wifi signal.... if not try entering you wifi password to connect.
THE TV NEEDS TO DETECT THE SIGNAL FIRST. If not, try raising your modem to a window sill or a shelf, it may not be getting the signal. If it is getting the signal, call Netflix 800.585.7265....and explain your problem.
Good luck.
Oct 20, 2014 | My Local TV iPhone Apps
Why does sound cut in and out?
Sounds like the power amp is going bad..it might be a board for that repair...dont know alot about that model...
May 28, 2014 | RCA L46WD22 Television
How to take it off the timer
cut off the tv unplug it and plug it in after a few mins if the timer screen comes back again have a tech look on your tv,the problem is the eprom that needs to be unsolder out of the set and solder it back so it can reset it self.
Aug 30, 2012 | Sanyo Televison & Video
Screen goes fuzzy when i play games but dvds work.
It's a problem with the GPU. You should contact Microsoft for support.
Nov 21, 2009 | Microsoft Xbox 360 Console
Viewsonic n4290p shuts off after approx 30 minutes of viewing. help
i dont wont this to sound as if it makes you feel silly but find the settings within the main tvs menue and check the sleep timer
Aug 05, 2009 | ViewSonic N4290p 42 in. LCD TV
Play for only 10 mins then goes off
Most likely, it's overheating. I recommend buying an Xbox 360 fan.
May 11, 2009 | Microsoft Xbox 360 Console
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Zenith Z44SZ80 Television Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
