GE Monogram SbyS Fridge temperatures keep cycling in freezer and fridge up and down during a day between 1F - 12F in freezer and 36F - 41F in fridge. Just No Consistency. Compressor Inverter was replaced, but problem persists days later. We already at $500+ of repairs without a solution. What else mechanically could be wrong?
SOURCE: GE PSW26M Artica Cooling and Ice Maker Problems
on the back of the frig is a small rectangle panel. inside that panel is the motherboard that controls the whole refrigerator. thoughs boards have been nothing but trouble. one of the problems it causes when it goes bad is the problem your having. replace the board to fix it
SOURCE: Refrigerator warm, freezer too cold
I had this same problem. You need to totally empty the fridge and freezer and allow it to defrost for 24 hours. Then put it back on and it will work. This happens if someone leaves the freezer door open and then it gets closed. The defrosted water freezes in the pipes and doesn't allow the cold air to move up into the fridge so the freezer gets even colder. This has happened to me twice!
SOURCE: GE Monogram will not accept freezer/fridge
My ge monogram gets warm every year this time of year. All of a sudden no ice and everything defrosts. We vacuumed vents up top last yr and it got cold again. What the heck???
SOURCE: Monogram refrigerator can't keep temperature constant
We need to look behind the rear panel in the back of the freezer and need to look at the mother board on both sides. Will need to unplug and begin. Let me know, Sea Breeze
