Question about Whirlpool Washing Machines
Water not being taken out. Appears the pump is not working.
    Problem Solver:
  • 12 Answers
Sounds like the impeller on the drain pump is blocked.Check filter thoroughly, if you cannot remove blockage you may have to remove tubes from pump to clear out any blockage.
Posted on Dec 20, 2008
I have a whirlpool WFS1073CD and getting a red light indicator saying clean pump. It appears to be washing normally but wont go into the spin cycle. I have drained the water via the filter plug under
Hi Maureen
Wow.... at least this model has an indicator light telling you what the problem is. Many machines don't!
I think the reason it won't go into the spin cycle is that the water can't exit through the pump.
The usual cause is that a sock or something is caught or blocking the pump.
Power OFF of course.
Follow the drain hose back to the pump & try unclipping the hose off either side to feel for a blockage with your finger.
Pump blockage is a common occurrence in washing machines.
Good Luck
Nov 26, 2014 | Whirlpool Washing Machines
Kohler whirlpool type tub will not pump water out of its jets or take water into the intake. Pump appears to operate fine. Water does not want to move. Suggestions?
When a bath pump turns on but does not move any water it is usually because there is an Air Lock and needs to be released.Try this.
  • Fill the tub with water
  • Turn the pump on
  • Unthread the discharge pump union until water starts to squirt out
  • when this happens you should hear a big 'swoosh'
if the bath pump starts to discharge water through the jets then you have solved the problem.
Rod
us parts center
888-521-6183
Apr 05, 2013 | Kohler Home
The washer shuts off by itself, a message of "F21" appears on the screen. It happens twice last week. Thank you for your help, Autumn Lin
Hello Autumn,
The F21 error code means the pump has taken longer to drain the water than usually time it takes to drain. Here is what you check to see if something is in the drain pump filter restricting the water flow into the pump. I know i have the Whirrpool Duet washer pictured . Whirlpool makes that washer so other that the name "duet" everything is the same
The most prominent cause of your DUET washer not opening after the cycle is done and door remains locked is going to be a blockage in the drain pump. Here is what to check in the pictures below.oldtech2332_3.jpgoldtech2332_4.jpgStart by unscrewing that just a little and use towel/tupperware tubs and catch the water that will come out. Once all the water is out remove completly and check for a blockage
Aug 18, 2011 | Maytag MHWE300VW Washer
Lay z spa pump has E02 code which is water flow problem,have changed filter.flushed through ,set reset button but fault code still appears.
If this is an outdoor spa near trees, its almost a guarantee that the impeller is blocked with debris (pine needles can cause this in a hurry)
If the impeller is clean of debris and this is still happening, replace you pressure/flow switch.
Apr 27, 2011 | Pool & Spa
Water pump
Hello drain the water from the radiator by removing the hose from the radiator to the water pump,after having taken out the hoses,then unscrew the bolts that hold the water pump.After having taken the pump,clean the surface where the pump is fitted on the engine.Now when putting,the new pump,put a clear layer of silicone gasket on the surface where the pump will fit to prevent leakage,now you screw the bolt to the same torque,then after put the hose back like it was before,fill your radiator ,do not put the cap now,because of an air lock in the water circuit,start the engine,you will see the water level lower,fill it to its level,then put the radiator cap.Hope that help you in changing the pump,good luck
Dec 26, 2009 | 2000 Nissan Maxima
I want to drain the pump as per the manual for storage
The best way to drain the pump is to lay the drain hose on the floor, and let the water run out that way, if you tilt the washer back, you will get more water out this way..
This is only suitable if the drain hose comes out of bottom of washer.
Plz rate my solution.
Thanks.
Jan 22, 2009 | Bosch WFMC 3200 Front Load Washer
LD.;....................
LD= Long drain if the unit has taken more than 5 min to drain out the water this code appears.. you eiter have a pump issue or a pressure switch issue.. does all the water go out of the unit??
Feb 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
20 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
