Question about LG DLE5977 Stainless Steel Electric Dryer
LG DLE5977B (Black Electric Dryer)
Dryer is just now almost 3 years old and started making a lot of rackett when running. The drum turns and it sounds like something is either loose or knocking around. It's not the load... We've dried hundreds of loads in this dryer... it's been in use nearly every day since it was purchasd (with 3 kids and 5 people in household...). Anyone else have this issue? I phoned repair company today, but since it's Sunday, they're closed.
  • 4 more comments
  • Rob Bellomy Apr 02, 2007
    Thanks for the suggestions! It's just a home-model but with 3 kids and 2 adults, it gets used several times each week.
  • dbennett873 Oct 13, 2008
    I have the same problem with my LG Dryer... mine is only 1 year and 3 months old. It has a loud knocking sound when running.
  • Anonymous Dec 01, 2008
    I have the same issue with ours. It sounds like the drum bumps the side of the machine when it turs.
  • jagpizza1 Dec 15, 2008
    Drum make s a loud bump noise when it turns. Someone said the drum was cracked. Can anyone help
  • hiendo85 Apr 12, 2009
    i have this problem when it was 1 yr old. when it turn, it keep making noise like something is loose , and now finally the drum is crack and it is loose. will turn on and work as normal but afraid to use becuase it making a whole lot of loud noise now. i think i need to replace that part. dont know where to began though.. suggestions please
  • cybercliff Apr 27, 2009
    I have the same problem. I purchased LG washer TROMM and dryer DLE5977B, and noticed about a month ago that the drum has a crack of approx 1/2 inch. Dryer still works, but makes lots of noise. Can anyone recommend a fixed?
    President:
  • 300 Answers
Remove couple of screws from the top rear and slide back the top cover. You will see the drum. Slowly turn the drum and feel the drum knocks. Then turn it slowly until the knocking part comes on the top. Check for crack along the welded joint. If it is cracked, change it asap because it can damage the roller also. Call LG for part number and dealer information. If you are technical, you can replace it.
Have fun.
Posted on May 03, 2009
  • 3 Answers
Again this dryer is a POS! We had problems since get go...first lint filter. Then we just vaccum it out all the time. Then the loud noises and we found that tons of people have this problem and it has something to do with rollers that can be replaced, but the problem will come back and we have a crack in the stainless steel drum too! Oh and forgot to mention it takes me 5-10x's now to dry clothes and after the crack now it is chewing up all our expensive clothes! I feel with something we spent so much of our hard earned money on, they should do something about these problems they are not isolated issues.
Posted on Dec 31, 2009
    Scholar:
  • 62 Answers
I have serviced appliances for about 20 years now. My suggestion is that the drum rollers are worn or possibly a belt or bearing as mentioned earlier. To check it out requires almost a complete disassembly. Unless you are very mechanically and electrically inclined, I would leave this to a pro. It isn't a complicated repair. It is the tear down and reassembly that can be tricky for a novice. Parts should be inexpensive and it should only take 30 minutes or less for a professional, depending on the location, space etc.
Posted on Nov 04, 2008
    Problem Solver:
  • 18 Answers
Depending on the make, it could be a worn belt, bearings,tension spring or rod,check all holes in tumbler for stuck objects, screws, plastics, ect. Is it a commercial dryer where it is mounted to the floor? If so check the mounting bolts. Check the easy stuff first, till you hear from the repair co.
Posted on Apr 02, 2007
LG Tromm electric dryer model DLE5977B is making an extremely loud humming noise.
Humming is caused when the slow start capacitor on the motor fails. Better to buy a new dryer as the motor is usually around $160. Yours is $145. I suggest you take professional advice on such a high outlay rather than risking the advice of someone who hasn't physically checked the machine. I have two pro dryers in my hotel fail, and they buzzed.
LG Dryer Model DLE5977B Parts
Feb 02, 2017 | LG Dryers
2yr old maytag maxima dryer gets louder and louder after run 30min. prob. repeats after cool down and running again. Vent is clean new pipe, no error codes. Sounds like a surging vibration.
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Apr 06, 2015 | Maytag Dryers
My bosch Nexxt WTMC 3300 dryer makes a squeaking sound when the load is light -- drying a larger/wetter load less likely to make the noise.
I had a similar problem with a different model Bosch dryer. First I made sure the dryer was unplugged. I found, after taking the front and rear panels off, that one of the front wheels that supports the drum was broken. I replaced the wheel and it works fine with no squeaks.
Jan 01, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
My Whirlpool dryer works great but makes a clicking sound while running, it is almost 2 years old. Can someone help? It is driving me crazy.
It is probably something on the drum. You may have to remove the top and front and make sure the drum is set correctly. While the drum is out check to make sure the tensioner is not loose as that will constantly shift if not set properly(Iwould check that first just there is no way to adjust it without taking out the drum first
Feb 29, 2012 | Whirlpool Dryers
Severe noise - drum is jammed and won't turn - LG DLE-5977 dryer
A piece of clothing is probably caught in the blower wheel.
Remove lint filter.
Use flashlight to look into filter housing to the lower left.
You may be able to retrive the item if you can see it.
Try rotating the drum in both directions while looking.
Jan 07, 2010 | LG DLE5977 Stainless Steel Electric Dryer
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My lg dle3733w dryer is vibrating a lot
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Oct 19, 2009 | LG DLE3733 Electric Dryer
My Maytag dryer is 14 years old. Now it makes a
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Yes, replacing the drum rollers is fairly cheap especially if you do it yourself, saves you the price of a new dryer for a few more years maybe.
Good Luck,
I hope this helps
Oct 08, 2009 | Maytag Dryers
My dryer will be 3 years old next month and the seam of the drum has come apart and my cloths are getting caught. lg will not stand my their products. the dryer only has a one year warranty no mater what.i...
If you have to replace the drum in 3 years, then i would imaging another drum will wear out within 3 years. Sounds like garbage to me, I advise replace the dryer. Sell the LG on ebay for parts
Jun 14, 2009 | LG DLE5977 Electric Dryer
LG DLE5977 Stainless Steel Electric Dryer Logo
1,241 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Craig Butler
Craig Butler
Are you a LG Dryer Expert? Answer questions, earn points and help others
