Question about HP Computers & Internet
Computer made pop noise then quit booting up
Power supply checks out used it to boot another computer
  • 837 Answers
Then check on the motherboard for "popped" capacitors. They look like small barrels upright (in case you didn't know what they looked like)
Posted on Dec 20, 2008
Computer booting problem
On some of these, there is an internal circuit breaker on the power supply. You can try unplugging it, hold the power button down for about 30 seconds, then plugging it back in. That can alow the power supply to reset.
May 08, 2013 | Computers & Internet
Acer Aspire M5201 Boot Problem
i understand you got moore then one drive.are you sure at you boots from windows drive.C:\
Apr 05, 2013 | Computers & Internet
Dl380 g6 server not boot after power cut
Check the back for a bad power supply. You should be using dual power with dual supply. It should have indicator light on somewhere. Connect to another source if no LED is on.
Oct 20, 2012 | HP ProLiant DL380 G6 Server
Computer wont boot up,
what computer? when you say added new power supply what state was the computer in before you added power supply ? do you know the new supply is a good one ?
S
Jan 24, 2012 | Shuttle Computers & Internet
My computer won't boot up and the orange light just stays on. The moniter is working, the fans in the power supply is working
Could be your motherboard. Does anything come up on the screen at all when you boot up? Do you hear a beep at startup? Also check to make sure your hard drive is spinning just to be sure.
Dec 09, 2011 | E-Machines Computers & Internet
My hp pavillion a1540n won't boot up. The power button is on but no boot menu on the monitor. Monitor is blank
I suggest you check the Power Supply. Bad Power Supply, weak Voltage power rail.
1) ALL the LED lights use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts
3) A typical Processor uses 51 to 125 Watts. Depends on what Processor it is. (Older one's use less)
The HP Pavilion a1540n specifications state it uses an AMD Athlon X2 4200+, processor.
(2.0GHz. Dual Core. Built upon the Windsor Core. Uses a Socket AM2 processor socket)
HP Support > Pavilion a1540n desktop computer > Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00679533&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=3184140&lang=en
Can use up to to 89 Watts,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors#.22Windsor.22_.28F2_.26_F3.2C_90_nm.29
Enough power for the LED lights, and fans, but Not enough for the Processor.
No Processor operating, No computer.
No computer, No Signal to the monitor.
(Video signal)
The Power Supply used is an ATX style, and 300 Watts.
A computer only uses the power it needs, and No more.
If you install a Power Supply with more Wattage than the original, it will be fine.
Jun 19, 2010 | Computers & Internet
Power Supply
If you are not getting even the Motherboard boot singal, then, its a power card issue. Please check the power cable to the monitor.
Regards,
HP
Aug 28, 2009 | Gateway GT5228 PC Desktop
Ac power alert when computer boots up.
You need to check your power supply. Most likely your power supply is going bad, but it could be your wall outlet too. If you have a multi-meter check the power at the outlet, but probably replacing the power supply will fix the problem.
Apr 24, 2009 | Computers & Internet
D4 Post code using tech aid diagnostic card
check power supply in back to see if you have on and off switch but you would'nt be the first with this problem from dell about the power supply going out meaning:
if you don't have nothing happening when your trying to boot the computer then it's the power supply, plug in computer power up and feel in back to see if the fan is blowing if nothing power supply is gone call dell.
Apr 05, 2009 | Dell Dimension 4400 PC Desktop
Power light flashing
not understanding your question ..need more info .. is the computer not booting ? Is it flashing red, green, orange? need more info
Mar 08, 2008 | Computers & Internet
Computers & Internet Logo
65 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
